Cylinder Porting Cox_ba12
Cylinder Porting Pixel
by roddie Today at 1:34 pm
Cylinder Porting Empty
Cylinder Porting
Cylinder Porting Empty Cylinder Porting
Post  coxaddict Mon Jul 06, 2020 1:09 am
I have a few blank cylinders that need porting. Waiting listening and learning before I attempt cutting the ports. I do have the capability and tools to machine the ports. Any one with experience with the Kustom Kraftsmanship single port Tee Dees? How well do they perform?
coxaddict
coxaddict
Cylinder Porting Empty Re: Cylinder Porting
Post  franzkleber Mon Jul 06, 2020 1:23 am
Uaooo! This a very interesting question also from my side! I hope for detailed answer from cox engine experts Very Happy
franzkleber
franzkleber
Moderate Poster
Moderate Poster
Post  aspeed Mon Jul 06, 2020 10:41 am
I will add something until an expert answers. My flying buddy had a shnuerle TD motor made. Not KK brand though. An exhaust tube was brazed on the back for a pipe. Pretty sure he had the Canadian record for 1/2A control line speed for a while. Over 100 mph with lots of nitro at that time. From what I recall, the cylinder wore out fairly fast, and a new piston was installed to get the compression back for a short time. The cylinder is what wore out. It was revving fairly high for a steel piston. We then went to ABC motors which were coming out at that time. Stels, VA, Norvels and CS. I have been thinking of blocking the exh. port of a B Bee cylinder and making it into a schneurle. Something just to try. I doubt there would be much if any boost in power. Another friend machined a few spare cylinders with a bunch of shapes and sizes and they all performed similarly. IIRC he used an indexing fixture and screwed the cylinder on to another cylinder with the fins turned down to fit accurately in the 5C collet. We had some cylinders that were already turned down for some tight cowls on some speed models.
aspeed
aspeed
Post  davidll1984 Mon Jul 06, 2020 11:05 am
hi y have particular cylinder prototype in mind can draw a raw picturs of wat tink can work lets start explain how and wy tink 3 bypas single exaust port on bypas is it posible for u too machine to make boost port on eatch bypas mesurments of inside is hard for me to mesur use spec from venom bypas boost port not sur 3or 6 boost port like idea of 1 eatch
Post  davidll1984 Mon Jul 06, 2020 11:11 am
very fast drawing just to point in de right direction for u Cylinder Porting Image191
Cylinder Porting Image192
Post  davidll1984 Mon Jul 06, 2020 11:32 am
texaco cylinder for try block 1 exaust port with weld then machine two boost port on top exaust large bypass down block Cylinder Porting Image193
Cylinder Porting Image194
exaust port leave two bypass as is no modification
Post  davidll1984 Mon Jul 06, 2020 11:39 am
very crude way to explain my desing just copy inside venom boost port hight lenght size then copy 3 of them inside no spi for tuned pipe with spi for direct exaust use wasp .074 carb to get right fuel ratio hope u made som insane fast setup Thumbs Up
Post  coxaddict Tue Jul 07, 2020 12:42 am
4th of July Flag I have practiced milling a second port on number 2 cylinders varying port timing with mixed results I also used carbide bits with 30 degree chamfer whereas the stock port seems to be made with a ball mill. Maybe this would create more swirl in the combustion chamber. I planned on welding one exhaust port and have some carbon rods to insert into the bore to prevent the weld material from entering the bore.  Don't know if the cylinder would warp from the heat. Silver solder would be used. This all got put in the back burner when I became ill six months ago.
4th of July Flag
coxaddict
coxaddict
Post  davidll1984 Wed Jul 08, 2020 5:09 pm
just use piston inside cylinder after from outside exaust place som material prior the weld then heat cylinder befor weld use mig witout gas very low amp tic tac not continous weld dont go to far just block heather wil retain rest
Post  franzkleber Thu Jul 09, 2020 11:04 am
Hi everyone
I have always been interested in this topic on engines, it would be great to see the original construction drawings of the TD models .
I started a job last year but I was unable to carry it out , i had measured a TD 009 and drawn it as faithfully as possible in 3D.
Then taken from the impetus I designed a schnuerle variant based on the few fragmentary news and blurred photos that I found on the net adding something of my personal taste.
The result is what you can see in the attached images, only that making drawings is easy, building the pieces is a whole other story and of course I'm not sure this cylinder works properly.
I hope sooner or later to find the time to complete this small project , the displacement of 1.5 cc is my favorite but I must confess that for some time now I have been thinking of going down to 1 / A because these small 0.049 wasps impress me with their specific power. Very Happy
Cylinder Porting 0111
Cylinder Porting 0410
Cylinder Porting Timing10Cylinder Porting Cilind10
franzkleber
franzkleber
Moderate Poster
Moderate Poster
Post  happydad Thu Jul 09, 2020 12:06 pm
franzkleber wrote:Hi everyone
So it looks like what you are showing is the cuts need to be made at an angle? I no speak Italiano. No disrespect meant. The drawings are in Italian, I presume, and I am guessing at what they say. Length, width measurements speak for themselves.
    I hope that the members with the proper tools respond to your post. Very interesting.
Happydad  RC Plane 4th of July Flag sorry I don’t see your flag. Blow up Mad!  Blow up Mad!  Blow up Mad!  Blow up Mad!
happydad
happydad
Post  franzkleber Thu Jul 09, 2020 1:03 pm
hi happydad
YCylinder Porting Cox_td10
es i am Italian , i live in the northem of Italy near Monza and you are right , the ports are angled machined .
The idea was to give a direction to the transfer fuel to get them as far away from the outlet port as possible.
I practically tried to copy the solution adopted by COX on its latest versions of 015.
franzkleber
franzkleber
Moderate Poster
Moderate Poster
Post  coxaddict Thu Jul 09, 2020 2:59 pm
Wow franzkleber, your drawings and renditions are awesome! Is your cylinder design based on factory style cylinders or custom made cylinders. I see port bumps on the outside of your cylinder drawings.
coxaddict
coxaddict
Post  aspeed Thu Jul 09, 2020 7:36 pm
It is a bit hard to get an angle without a CNC. Some of the old TD cylinders would be a bit faster if the bypass ports were machined a bit deeper right into the threads. I don't think the bulge is needed. Here is a pic of an AP .09. The AP .15 is a bigger bore, and then the slots are cut right through the sleeve to the piston. Kind of backwards from the TDs. The boost port is usually a more gradual angle than the side ones.Cylinder Porting Ap_09_10
Cylinder Porting Ap_09_11
Cylinder Porting Ap_09_12
The Fora .049 is fairly similar to the AP, but has no boost port at all. A bit like the old Supertigers.
aspeed
aspeed
Cylinder Porting Empty You guys can figure this out
Post  happydad Thu Jul 09, 2020 8:09 pm
coxaddict wrote:Wow franzkleber, your drawings and renditions are awesome!  Is your cylinder design based on factory style cylinders or custom made cylinders. I see port bumps on the outside of your cylinder drawings.
  Coxaddict: I was hoping you were following all this porting stuff. Didn’t I see you mention you have an a NC machine and could do your own porting? Or was it someone else.
   If only we could find some blank cylinders. Hmmm. Huh... Huh... Huh...
Happydad RC Plane 4th of July Flag Old Bugger real old Old Bugger Sleeping at Computer
happydad
happydad
Post  coxaddict Thu Jul 09, 2020 9:19 pm
happydad,  How are you?  Yes I am eagerly following this thread as I have some blank cylinders that I purchased a while ago.  They are of the stepped wall style and have been bored and honed I think by Cox.  Just need to match the piston to the cylinder for the right fit.  I'll make a leak down gage to find the best piston fit something like Cox used to air gage the piston to cylinders during assembly.  Come to think about it I could probably use the gage on my other engines Huh...  I currently own a Sherline mini lathe and a mini mill that has digital read outs.  No NC although I could outfit them if needed. (Kinda costly)
coxaddict
coxaddict
Post  coxaddict Thu Jul 09, 2020 9:43 pm
aspeed, Thanks for the good info.  Does the Fora use SPI? As I learn more I am leaning towards cutting the ports on the outside of the cylinder then shrink fitting a tube to the cylinder to seal the ports.  This would allow for a better port window shape.  Just a brainstorm Shocked I think I'll practice on a single port cylinder first.  The sleeve would also allow blocking off one of the exhaust ports.  Just need to find the right material with same expansion rate as the cylinder.
coxaddict
coxaddict
Cylinder Porting Empty Nice machine I hear
Post  happydad Fri Jul 10, 2020 12:25 am
coxaddict wrote:happydad,  How are you?  Yes I am eagerly following this thread as I have some blank cylinders that I purchased a while ago.  They are of the stepped wall style and have been bored and honed I think by Cox.  Just need to match the piston to the cylinder for the right fit.  I'll make a leak down gage to find the best piston fit something like Cox used to air gage the piston to cylinders during assembly.  Come to think about it I could probably use the gage on my other engines Huh...  I currently own a Sherline mini lathe and a mini mill that has digital read outs.  No NC although I could outfit them if needed. (Kinda costly)
Seems like you and BB, mr. Beeson, have a lot in common. Seems like someone else just purchased a new Sherline. I hope you two can communicate some day. He has been very busy lately and asked not to be bothered for a while. We both have a magic birthday soon. I never thought I would make 50 and now....
Happydad RC Plane 4th of July Flag Old Bugger Old Bugger Old Bugger Old Bugger Old Bugger Old Bugger
happydad
happydad
Post  coxaddict Fri Jul 10, 2020 1:23 am
Haven't had a chance to work on my projects in a while, all I can do is look at them. Last project I worked on was cutting the slit exhaust and lowering the port to create SPI on surestart cylinders. I used a 3"x .081" slotting saw on my mill. That was 8 months ago.
coxaddict
coxaddict
Cylinder Porting Empty Oh, I see
Post  happydad Fri Jul 10, 2020 1:30 am
coxaddict wrote:Haven't had a chance to work on my projects in a while, all I can do is look at them.  Last project I worked on was cutting the slit exhaust and lowering the port to create SPI on surestart cylinders.   I used a 3"x .081" slotting saw on my mill. That was 8 months ago.
I see why you want help. In that case. Yes.  BTW how’s the surf? North Sore, Hawaii. C’mon. You gotta be a surfer.
   Or you could be one of the only guys who owns Cox engines that HAS to go to work every day. UGG.
  Hd RC Plane 4th of July Flag Old Bugger Old Bugger Old Bugger Old Bugger Old Bugger Old Bugger Old Bugger Two Cents Two Cents
happydad
happydad
Post  coxaddict Fri Jul 10, 2020 2:44 am
Ha Ha! North shore flat, South side 2-5 ft.  Last time I surfed was when I taught my son when he was 9. He's 41 now Laughing Laughing  Mostly fishing from shore nowadays.  Haven't worked since 2012 got my Medicare card last year Old Bugger Old Bugger  Beautiful weather with a few showers and lots of trade winds. Small Cox Logo  Downside hard to fly control line with such windy weather.
coxaddict
coxaddict
Post  aspeed Fri Jul 10, 2020 9:26 am
Very windy here too on the north shore. (Lake Erie) The Fora does have SPI. Have a pic here. http://aerohobby.ca/store/index.php?main_page=product_info&cPath=19&products_id=176&zenid=a8bi83gkjauqfs2i52u8svj1d6 I have a Taig lathe, although I seldom use it except for angles. My Hardinge chucker can not do angles other than form tools unless i buy an expensive attachment. Yes I passed the 60 mark as well. Retired 10 years ago after noticing that many of my friends were gone at 50.
aspeed
aspeed
Cylinder Porting Empty How did that 3inch blade clear the rest of the cylinder
Post  happydad Fri Jul 10, 2020 2:31 pm
I can’t imagine how a 3inch blade cut out the slit in the exhaust without hitting the cylinder walls. I have been tinkering with the idea for a while. Do you think the cheap harbor freight tools metal working lathe would hold the Dremel tool steady enough to do the cutting?  Macgrubber style? It’s a thought. The metal lathe is about $300 last time I thought about it, maybe more now.
Wow, I guess I miss surfing as much as you do and I live 40 to 60 miles away from my old surfing spots.
Blow up Mad! Blow up Mad! Blow up Mad! Blow up Mad! Blow up Mad! Blow up Mad! Blow up Mad!
happydad
happydad
Post  aspeed Fri Jul 10, 2020 4:23 pm
$300 is a great deal for the Harbor Freight lathe. I think the mill is better for cutting the slots though. That lathe has a lot of followers that like it after a good cleaning and adjusting mods.
aspeed
aspeed
Post  Ken Cook Fri Jul 10, 2020 4:50 pm
I own one of the TD's that was originally mentioned at the start of the thread. I believe this is also what David was trying to show as well. The cylinder has one exhaust port and three bypasses. My engine has a welded aluminum header which fits around the perimeter of the cylinder which is setup for a tuned pipe. I don't own the pipe. I've run the engine which is a chore in itself. I have a sewer pipe venturi which is essentially more or less a brass ring around the plastic carb body. This will not run on anything but pressure. The cylinder is not blued it appears to be nickel. When I've run this engine, I wasn't overly excited. I'm either trying to use too large of a prop or the timing requires the pipe or both. My engine has no needle valve so a remote setup is a must. In addition, the engine absolutely requires a bladder or it will not run. I hope to have it out again for a more secure rpm number.
