» Just found thisby batjac Today at 10:39 pm
» I Got Cheated!
by batjac Today at 10:35 pm
» WEN-MAC STORY
by GallopingGhostler Today at 10:09 pm
by Admin Today at 8:41 pm
by rsv1cox Today at 6:21 pm
» PSA propellors!!!
by roddie Today at 5:49 pm
» Wen Mac Aeromite/Challenger
by getback Today at 5:39 pm
by rdw777 Today at 12:05 pm
» COX FUEL ?????
Power requirements
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Power requirements
John Goddard wrote:The Aerobic states 020 power. Although physically it's nearly twice the size it does appear a VERY light build, with ally boom fuz (I'll swap for C/F) built up tail and surfaces etc. However
Bearing in mind it's an aerobat do you guys recon an 020 will have 'The Minerals' ?
I've got PeeWee and TeeDee 020's which would both be throttled or should I just bung a sure start up front?
Dont go for anything bigger than a TD .020 on the aerobic , they are quick on a TD 020
With the rainbow,as long as you are running 25-30% nitro it shouldnt be underpowered as long as you lean it out well, 30% nitro is good , ive always used 30% and never had a problem with wear as long as 20% castor is used
If you want more speed , try 1/16 balsa under the back of the wing, this speeds it up a lot, models i design ( such as the dipstick ) have much lower wing incedence than the ones Peter Kent designed, the Rainbow is a Miniature Aircraft Factory kit that we bought when we took them over, i prefer to raise the back of the wing a bit on his designs
My first mini rainbow had a .5cc diesel on it, that was quick
MiniatureAircraftFactory wrote:John Goddard wrote:The Aerobic states 020 power. Although physically it's nearly twice the size it does appear a VERY light build, with ally boom fuz (I'll swap for C/F) built up tail and surfaces etc. However
I'm being a bit thick..
Are we lifting the trailing edge where it sits against the fuz?
J
John Goddard- Diamond Member
nitroairplane wrote:What WS was the one with an AE .5cc?
12 inch, fitted with hitec 101 servos gem 2ch 27mhz rx and a 250mah nicad pack , weighed a lot! but the AE.5cc diesel on a 6/3 pulled it great and it flew in any weather
I cut a slot into the front bulkhead and fitted a 1/8 inch ply engine plate, cut a hole in the top sheeting and dropped in a 10cc tin tank for the engine
It was all covered in tissue, gave the wing a lot of strength unlike film
Last edited by MiniatureAircraftFactory on Fri Feb 10, 2012 9:09 am; edited 1 time in total
J
After its built and covered i stick a piece of 1/16 * 1/4 balsa strip , just a bit wider than the fuselage under the rear trailing edge, i just pop it in after the wings are rubber banded on , maybe start with 1/32 inch first time and see the difference
J
Thanks Big Guy
I meant to come and say hello at Ally Pally but forgot Doh!
Next Year....
J
John Goddard wrote:As above, the rumour has now gone round that John's gone 'a bit weird' and is flying odd small aeroplanes....
I've had several calls in the last few days from guys want'ing rid of stuff from their attics
amongst which is this,-
It's wing span is 55 ins weighs 585 grams (about 21 oz in 'old money') with it's esc and motor.
Will it fly with a sure start/texaco type thing?
J
Two questions.....
1. Why don't I ever find people who want to get rid of stuff like that!!!!
2. Why does that model look like a character out of "Cars"?
Ivanhoe- Diamond Member
J
!000 apologies Will.
I had the Mota running much better today (not quite as cold) and it was a spritely little rascal.
J
Yup it is getting warm over there in London
Page 2 of 2 • 1, 2
Page 2 of 2
