» Just found thisby batjac Today at 10:39 pm
» I Got Cheated!
by batjac Today at 10:35 pm
» WEN-MAC STORY
by GallopingGhostler Today at 10:09 pm
by Admin Today at 8:41 pm
by rsv1cox Today at 6:21 pm
» PSA propellors!!!
by roddie Today at 5:49 pm
» Wen Mac Aeromite/Challenger
by getback Today at 5:39 pm
by rdw777 Today at 12:05 pm
» COX FUEL ?????
Power requirements
Power requirements
Not sure if this is in wrong section or not boyz but here go's....
Having 'successfully' built and flown the Bacaruda http://www.fmkmodels.com/rainbow-model-plane-kit-010-micro-radio-control-rc-balsa-sma-cox-010-020-miniature-aircraft-factory-18-p.asp
I've now started on FMK's Aerobic http://www.fmkmodels.com/aerobic-020-fun-fly-rc-model-plane-kit-micro-radio-electric-ic-miniature-aircraft-factory-funfly-39-p.asp
The Rainbow Bacaruda is designed for an 010 but in various places quote 010 to 020. I wish I'd stuck an 020
on the front cos I'm not a 'marginally powered' kinda guy and IMHO it is underpowered at 131g FFAUW.
The Aerobic states 020 power. Although physically it's nearly twice the size it does appear a VERY light build, with ally boom fuz (I'll swap for C/F) built up tail and surfaces etc. However
Bearing in mind it's an aerobat do you guys recon an 020 will have 'The Minerals' ?
I've got PeeWee and TeeDee 020's which would both be throttled or should I just bung a sure start up front?
John Goddard- Diamond Member
Re: Power requirements
Keep it light and put a tee dee .020 up front.
What is the WS?
I will soon be building another rainbow and may try to add ailerons and a throttled .010 if possible.
Indra
What is the WS?
Indra
nitroairplane wrote:Keep it light and put a tee dee .020 up front.
What is the WS?
Indra
Span 22ins Indra.
If I built another Rainbow I'd Def stick ailerons on, I'd prob lose the dihedral as well.
Obviously the Aerobic will have 5 servos and a bigger Batt but I reckon sub 9oz
but the wing loading wil be shedload lighter.
John Goddard wrote:nitroairplane wrote:Keep it light and put a tee dee .020 up front.
What is the WS?
Indra
Span 22ins Indra.
Well 9oz if you put a throttled .049 you may have a 3d plane
John,
At 9oz I think the throttled TD .020 would be the best fit.
Yes Ron but have you seen the planes Johnboy flies?cribbs74 wrote:John,
Indra,
No, just the Barracuda. Something I should know? I was just going off weight and the knowledge of what a TD .020 can pull.
nitroairplane wrote:Yes Ron but have you seen the planes Johnboy flies?cribbs74 wrote:John,
Badly...
John Goddard wrote:nitroairplane wrote:Yes Ron but have you seen the planes Johnboy flies?cribbs74 wrote:John,
Badly...
Chat box?
Badly...
I watched couple vids, I wouldn't describe it as badly by any stretch.
cribbs74 wrote:John Goddard wrote:nitroairplane wrote:Yes Ron but have you seen the planes Johnboy flies?cribbs74 wrote:John,
Badly...
Neither would I!
Can't remember how to do it.
Sadly story of my life, just ask 'She who must be obeyed'
John Goddard wrote:Can't remember how to do it.
What kind of performance do you want from this plane though?
So are there an excepted
Weight to capacity figures for other sizes in the Cox range like the sub 7oz for an 010?
John Goddard wrote:So are there an excepted
Well pee wee sub 11oz and tee dee about sub 13oz.
Come to http://coxengineforum.forumakers.com/chatbox/index.forum? and we can figure it all out clearly.
nitroairplane wrote:John Goddard wrote:Can't remember how to do it.
Well I'm not expecting the same as your new Yak/which was 4 cell powered and decribed by
our 3 d expert as The Most Rediculously overpowered thing he'd ever flown,
But something that will pull out of a prop hang hopefully.
John Goddard wrote:nitroairplane wrote:John Goddard wrote:Can't remember how to do it.
Well maybe a throttled surestart is what you need!
Power requirements
[b]Just a thought, my micro stick, 22"span, 5oz with battery in ready to fly with a
TD 0.020, prop on backwards flew like a rocket and almost got away from me.
It,s a chubby little rascal with quite a thick Clark Y section.
Where can I get a throttle for my TD 0.020?
proctor- Gold Member
proctor wrote:[b]Just a thought, my micro stick, 22"span, 5oz with battery in ready to fly with a
EBAY or if it is thick walled cylinder you could easily make one.
nitroairplane wrote:John Goddard wrote:nitroairplane wrote:Keep it light and put a tee dee .020 up front.
What is the WS?
Indra
Span 22ins Indra.
You'll have a DIY Lawn-Dart.
OK Now the Balloons gone up
As above, the rumour has now gone round that John's gone 'a bit weird' and is flying odd small aeroplanes....
I've had several calls in the last few days from guys want'ing rid of stuff from their attics
amongst which is this,-
It's wing span is 55 ins weighs 585 grams (about 21 oz in 'old money') with it's esc and motor.
Will it fly with a sure start/texaco type thing?
J
J
John Goddard wrote:It's wing span is 55 ins weighs 585 grams (about 21 oz in 'old money') with it's esc and motor.
J
It's a cutie, alright.
At 55", it's probably has a pretty good wing area and, consequently, a fairly light wing loading. The big 1/2A Herr Cub has a 48" span, 328 sq. in. area and AUW of 20 oz, so your plane is in the ballpark. I think it will fly just fine and very scale like. You may find after flying for a while that a throttle is in order so you can putz around even more slowly. You will need to ensure the covering and exposed areas are fuel proofed.
Kim's BOT is bigger and probably weighs nearly twice as much and his flys like a scaulded goose (that's redneck for "really gets after it") on a TD.
Cheers Andrew
I reckon it's about 400 sq in and with a throttle will be about 22oz.
J
I may cheat and stick a Lipo in and take it for a blast tomorrow.
J
If the airframe was built to accommodate an electric motor, a glow motor may rip it apart. But a Texaco probably won't do much. (low RPM)
