Installing an Avatar
OhBee- Platinum Member
Re: Installing an Avatar
I like it!
As usual when it comes to tech stuff...took me awhile to figure it out. Better than a grey sillouette!....
..no offense!
..no offense!
OhBee: After and Before. You pushed me away from grey.
AWESOME!....But I bet it didn't take half the day for you to figure out how to do it! Looks mighty fresh! I'm feeling the need now to build a Voodoo to replace my old abandoned one. Everythings kinda on hold till I get moved to a new house.....with an entire basement for my hobbies!
OhBee if memory serves you are navigating this web forum on a cell phone and not a tablet or computer...if tru you are doing much better than I can. Web forums on cell phone are seriously frustrating for me
like your avatar
like your avatar
The most difficult part of building a Voodoo is sourcing the proper sized leading edge. I stocked up on a lot of these back in the day and I use them as I see fit. Sig still offers a solid leading edge but it's not really the same profile and accurate thickness but it's close enough. I prefer bladders over tanks so I don't install tanks in mine. That would be your next problem. While you can find a tank that fits, the tank needs to be reworked for several reasons. The original instructions on the Voodoo I believe recommends a Veco T-21 tank. My memory could be clouded as it's been a while. That tank is a wide wedge. Due to the hard maneuvers a Voodoo can generate, the fuel load runs away from the pickup tube which can cause disastrous results. Therefore, it was recommended to use backplate pressure to insure a continuous engine run. This requires a shotgun blast of the tanks internals and installing a pressure line.
Now, if your not up to doing the two step anymore in the center of the circle, a Fox .35, OS MAX.35 or a Mccoy or better yet your Enya .35 (Although much heavier) would work in stock form with little to no modifications. It may just need the tail booms lengthened a bit for the Enya. I just rebuilt a Wooten Sneeker which is setup using a tank. In my opinion, the name Sneeker name isn't as appealing as the Voodoo. The Voodoo seemed to steal all the glory but the Sneeker in my opinion is far superior to the Voodoo. The Voodoo doesn't maintain speed through the maneuvers, it flops and flounders through them as the speed bleeds off and the Sneeker while losing speed gracefully maintains good posture throughout.
My old Voodo had a wedge tank installed internally. Manuevers? I'd be happy to pull off an ocasional loop. Don't have the coordination or reflexes to fly the stunt pattern anymore anyway!
Fred...EVERYTHING on a cell phone is seriously frustrating for me! I don't have a computer,and the tablet I do have won't work in the hole I live in! That will change hopefully, as I am moving within a month !
» Installing an Olympic 15
» Installing a new canopy
» installing reeds and clips
» Skyray 35 Build - Faux Streak look
» Venturi without mesh screen (installation) --- Enya Rear Induction engines too!
