Cleaning Cyano Glue from Skin Cox_ba12
Cleaning Cyano Glue from Skin Pixel
by getback Today at 12:05 pm
Cleaning Cyano Glue from Skin Empty
Cleaning Cyano Glue from Skin Empty Cleaning Cyano Glue from Skin
Post  Levent Suberk Thu Mar 26, 2020 12:09 pm
I can not use cyano glue because it's fumes always burn my eyes. It is better to use cellulosic glue, epoxy and aliphatic resin glue. I found that cellulosic glue is better than cyano glue, because it also is gap filling. Sometimes I also use PVA glue, glue stick and contact adhesive in modeling. Epoxy fumes are bad, but it is tolerable.
Other than this, I found that opening clogged cyano glue bottles can be dangerous, because glue sputters everywhere. Be careful when opening clogged bottles and keep your face at a safe distance.
If you use cyano glue, then here is a good read about how cyano glue can be cleaned from skin:
https://www.medicalnewstoday.com/articles/323532
Last edited by Levent Suberk on Thu Mar 26, 2020 12:25 pm; edited 1 time in total (Reason for editing : Spelling)
Cleaning Cyano Glue from Skin Empty Re: Cleaning Cyano Glue from Skin
Post  andrew Thu Mar 26, 2020 1:15 pm
Levent Suberk wrote: .......Other than this, I found that opening clogged cyano glue bottles can be dangerous, because glue sputters everywhere. Be careful when opening clogged bottles and keep your face at a safe distance.........
I second this -- I once stuck my tongue to my lower lip (but, that's another story Embarassed ). In reality, I've stuck several body parts to other body parts and objects.
I really like to use PTFE spaghetti tubing (ultra small ID teflon tubing) for applying CA.  It allows me to reach further and I can apply a very small amount of CA where I want it.  However, blockage can be a problem over time.  I keep a small screw top Rubbermaid container (~ 1 cup) filled with acetone on my building area.  When I finish for the day, I drop the bottle spout and tubing in the acetone and put a new uncut spout back on the bottle.  Whenever I build again, the spouts and tubing in the container are completely clear of CA and ready to use.  Secondly, it seems that keeping the CA bottle sealed with an uncut spout when not in use helps extend its life.
Post  Dave P. Thu Mar 26, 2020 8:00 pm
Andrew beat me to it, everything he says.  I use old film containers filled with acetone to keep nozzles clean. They fit perfectly.  CA stays good for a long time in the freezer with a new unopened nozzle.
For emergency removal from skin, Mama's nail.polish remover works great.  Smells good too.
Cleaning Cyano Glue from Skin Img_2010
Dave P.
Dave P.
Post  getback Fri Mar 27, 2020 6:35 am
Will this remove old hardened CA also ?
Post  andrew Fri Mar 27, 2020 7:33 am
Yes. Acetone is an excellent solvent, but not good on porous surfaces since it's easily absorbed and evaporates very quickly in the open. However, when used in a closed container such as a film canister or food container, the parts will be CA free. You do need to change out the acetone periodically since the CA goes into suspension.
I use it to clean CA off my fingers, but it will also strip the oils from the skin and leave them white.
