Sig-ment and Ambroid Cox_ba12
Sig-ment and Ambroid Pixel
by roddie Today at 6:17 pm
by TD ABUSER Today at 2:13 pm
by Ken Cook Today at 1:41 pm
by Ken Cook Today at 1:37 pm
by getback Today at 11:52 am
by roddie Today at 10:43 am
Sig-ment and Ambroid Empty
Sig-ment and Ambroid Empty Sig-ment and Ambroid
Post  Cribbs74 Tue Apr 03, 2012 12:14 pm
Which one sands easier? Also does anyone have a good source for just regular Ambroid? I see it is available but, there are many variations.
Sig-ment and Ambroid Empty Re: Sig-ment and Ambroid
Post  RknRusty Tue Apr 03, 2012 12:22 pm
cribbs74 wrote:Which one sands easier? Also does anyone have a good source for just regular Ambroid? I see it is available but, there are many variations.
Ambroid was my favorite, but since I can't find it, I use Testors. It's okay. Can't answer your question, sorry.
Post  Cribbs74 Tue Apr 03, 2012 1:17 pm
I see it as available online but. There are variations nothing that says just "Ambroid" there is ambroid cement is that it?
Post  ahrma_581 Tue Apr 03, 2012 1:22 pm
Might try these people for Ambroid: http://www.wooden-canoes.com/material.htm (about middle of the page) Probably need to order half dozen tubes to spread out shippling/handling. Apparently it's still in demand for canoe repairs.
Didn't need/want that much, so I just stick everything together with Titebond.
ahrma_581
ahrma_581
Post  Cribbs74 Tue Apr 03, 2012 1:37 pm
ahrma_581 wrote:Might try these people for Ambroid: http://www.wooden-canoes.com/material.htm (about middle of the page) Probably need to order half dozen tubes to spread out shippling/handling. Apparently it's still in demand for canoe repairs.
Hey thanks for that! I didn't like the price but, the picture allowed me to figure out what I needed. You can get single 3.2oz tubes of it for around $3 or so from online hobby suppliers.
So are you an AHRMA member? If so what do you race? I have missed AHRMA's presence at Mid Ohio the last few years........
Post  ahrma_581 Tue Apr 03, 2012 6:46 pm
cribbs74 wrote:So are you an AHRMA member? If so what do you race? I have missed AHRMA's presence at Mid Ohio the last few years........
Umm, was, once. Too lazy to come up with a new screen name. Have an RD350 that I flogged in the vintage stuff. Past tense; can't afford race tires much less racing these days.
Always wanted to go to Mid-O, especially for the swap meet, and hit some of the other eastern road races. But found out they don't allow dogs at Mid-O and then there was that AHRMA meltdown couple years ago...
ahrma_581
ahrma_581
Post  Cribbs74 Tue Apr 03, 2012 6:50 pm
I see, I learned to ride on a '73 RD350. Not smart!
Yeah, the swap is a sight to behold and it's all I care for these days. When AHRMA left the racing sucked. What a shame.
Post  Kim Tue Apr 03, 2012 8:50 pm
"Duco Household Cement" is very similar to Sigment. I can still get regular Ambroid at Scheafers Hobbies in St. Louis and usually pick up a tube every time I'm there. I've never noticed a real difference in their sanding, though Ambroid is usually a lot thinner, and usually requires "pre-gluing" to get a good bond.
Post  SuperDave Wed Apr 04, 2012 10:00 am
Sigment has worked well for me on several planes upon which I've used it. I have several existing planes built in the 60's with Ambroid and they are structurally sound after all these years.
Modern CA has eclipsed the use of the above but they have their attendant complications. Concerns over CA's resistance to nitro have me leaning more toward expoxies and Sigment on my current build a Brodak "Baby Ringmaster/TD .051 combo.
SuperDave
SuperDave
Post  dankar04 Wed Apr 04, 2012 11:14 am
Just for kicks I bought a tube of Ambroid to build a FF 1/2A T-Bird. The glue is very thin and runs out hot and heavy but works fine. They ran out of Ambroid and bought Sig-ment. I like it much better. Ca is way to go unless you have no rush. Ambroid was glue back in the day. Duco also worked well and never liked Testors products.
dankar04
dankar04
Post  Cribbs74 Wed Apr 04, 2012 12:23 pm
I sure do like the smell of Sig-ment! Probably not a good thing........I have used some before, I like the bond over CA and I use it in high stress areas. I was mostly concerned with sandability. I have never attempted to sand the Sig stuff and CA is a bear to sand without destroying the balsa around it. Kim suggested Ambroid awhile back because it sands well.
Post  dankar04 Wed Apr 04, 2012 12:42 pm
Tite-bond works well also and easy to smooth out with little H2o. I do like smell of Ambroid and Sig-ment but don't stay to linger. I still have cheers Airplane alot of Areo-Gloss and found good thinner. Makes for some interesting fumes but again take models outside. Living in Tucson is great for painting with low humity. I once caught sight of vapors going into the air, like using ca. glue. Right now its 68* outside and will get warmer with mucho sunshine...he..he..
Dan
dankar04
dankar04
Post  Ivanhoe Wed Apr 04, 2012 12:48 pm
dankar04 wrote:Tite-bond works well also and easy to smooth out with little H2o. I do like smell of Ambroid and Sig-ment but don't stay to linger. I still have cheers Airplane alot of Areo-Gloss and found good thinner. Makes for some interesting fumes but again take models outside. Living in Tucson is great for painting with low humity. I once caught sight of vapors going into the air, like using ca. glue. Right now its 68* outside and will get warmer with mucho sunshine...he..he..
Dan
Hey, I'll swap you some of our rain for some of your sun!
Ivanhoe
Ivanhoe
Post  Cribbs74 Wed Apr 04, 2012 12:54 pm
Dan
Sounds like a good deal to me! It hardly ever rains here. I fight the sun all summer long for a few measely tomato's.
Post  SuperDave Wed Apr 04, 2012 1:12 pm
Been to Tucson and environs for a month-long visit when we took our travel trailer to visit friends.
Sure the sun shines quite regularly but there are also a bazillion other peope with which to contended. Just getting to a destination across town in Tucson can be a chellenge.
"Happy Trails" RV Resort. What a joke that is.
No thanks, not for me.
SuperDave
SuperDave
Post  Cz10 Wed Apr 04, 2012 7:18 pm
I just picked up a tube of Ambroid at my LHS... $4 + tax... I think for some things it might be a better choice then CA . Like bonding large areas like doubles....
I was in Tucson in February with my wife so she could go to the gem show. I chased trains and took pictures... Had a blast... But traffic can be a bear... On a previous trip, while waiting at stop lights, I fell asleep!
Sig-ment and Ambroid IMAGE_7F31955C-090C-4B90-AA0D-23F71C45F242
We'll be back next year...
Cz10
Cz10
Post  Mark Boesen Wed Apr 04, 2012 8:56 pm
Nice photo!
When I was into PAMPA Stunt, I used a lot of Aliphatic Resin Wood Glue, good o'l Titebond, light, strong and easy to sand.
Post  Kim Tue Apr 10, 2012 5:52 am
And...there was also a time when Ambroid sold a lot more than just glue :
Sig-ment and Ambroid Ambroi10
Post  PV Pilot Tue Apr 10, 2012 7:12 am
dankar04 wrote:. I once caught sight of vapors going into the air, like using ca. glue. Dan
Yah, first time I shot some CA with CA accelerator, I had the burst of fumes rising that I could see,,and feel the heat. Thought I had a alcohol type fire going on. The genie was released from her bottle (Barbara Eden, wink)
Isin't the Ambroid plastic stuff basically Testors?, the squeeze tube looks the same. Have never used Ambroid at all, or researched it. Other than reading about it on here.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Cribbs74 Tue Apr 10, 2012 8:01 am
Nice advert Kim!
If I ever came to visit you wouldn't think much of me as I would probably ignore you and read all your old issues of M.A.N.
Post  Kim Wed Apr 11, 2012 4:16 am
cribbs74 wrote:Nice advert Kim!
Fine with me ! It MIGHT make me finish organizing them! Every time I settle in to sort them, I start looking through them, and the whole project goes down-hill !! I'm STILL sorting through the box-full I bought at the Swap Meet 2 months ago, and when I pulled out my other boxes to check for duplicates, I found some I hadn't looked at yet. Got serious mental problems here....
Post  PV Pilot Wed Apr 11, 2012 7:36 am
Yah, "you have some serious problems you need to work out with yourself"
(Seth Enslow's buddy commenting on the Seth's ability to think straight after his sand dune overjump)
https://www.youtube.com/watch?v=PF4YwBO56uQ
PV Pilot
PV Pilot
Post  Cribbs74 Wed Apr 11, 2012 8:27 am
Well, unless you are in a hurry then just keep doing what your doing. We all have mental problems here so you're in good company.
Maybe the next rainy weekend you can knock it out......... Or pay some kid 10 bucks to sort them for you.
Sig-ment and Ambroid Empty Glue
Post  dankar04 Thu Apr 12, 2012 1:12 am
Forgot I bought a German made hand launch glider kit came with tube of glue called U-Hu. Very strong stuff and high quality. Glider is all wood and biggest one I have seen. 22" winspan is big for H/L/G. I was thinking a TD .010 as power pod but nay to that. Engine just to expensive to use in FF ship.
dankar04
dankar04
Post  JPvelo Wed May 02, 2012 5:22 am
http://www.a2zcorp.us/store/category.asp?Cguid={BE5496BC-0B6E-4AF8-86DB-7D5118504EE0}&Category=BuildingMaterials:Glue%20Plasticizer%20Dope
JPvelo
JPvelo
