» Throttles for Cox Tee Dee .049 / .020 / .010 engines --- videosby davidll1984 Today at 8:49 pm
» Green vent..
by roddie Today at 7:49 pm
by rsv1cox Today at 6:59 pm
by rsv1cox Today at 6:06 pm
by Cox International Today at 4:33 pm
» PSA propellors!!!
by robot797 Today at 2:39 pm
by roddie Today at 1:40 pm
by roddie Today at 11:42 am
by roddie Today at 10:51 am
by davidll1984 Yesterday at 6:15 pm
» OK Cub .024
by 049kid Yesterday at 12:31 pm
Muffler gasket?
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Muffler gasket?
Got it handled...made a gasket,found a torx bit that works great in a 2 mm allen head. No joy on finding any 2 mm lock washers around heare though ! Even with my thin gasket,and no lock washers, it now snugged up tight! Thanks guys!
OhBee- Platinum Member
Re: Muffler gasket?
Sorry for coming back late to the party, but was busy today and just got in a short while ago. Just tried out the allen keys, and my muffler bolt uses a 2.5mm allen key.
Re: Muffler gasket?
The threads in OS silencers from LA 15 through LA 46 are M3 and are mounted using a cross headed screw (philips). I usually use a thread sealant to prevent the srew loosening - Loctite 542 or similar. There are various grades of thread sealant - some more permanent than others.
To gasket or not to gasket?
As usual - there are many variables.
Nicely machined mating surfaces don't need a gasket for sealing and I prefer not to use one but .....
With an engine prone to vibration - this can be amplified by a larger silence stuck on one side. A gasket can dampen this down a little.
Sometimes, the mounting holes in the engine are too oversized and so the mounting bolts can movewith vibration. A gasket helps these bolts hold the silencer tight.
Silencer design can also play a part and this is where it gets tricky. I have a few engines where the silencer can cause overheating as the hot exhaust gases aren't swept away as in an unsilenced engine. I also have engines that are cooled by the silsncer and these two effects are complicated by the surrounding temperature.
A standard gasket can help or hinder insulating the exhaust port from the silencer. It is often a matter of trial and error and can slso be associated with the length of a typical engine run. The silencer can either conduct heat away from the engine or amplify the heat in the exhaust area.
I don't think any of this is evident in a six minute run but can be noticable in twenty minute RC runs. The exhaust connection of the silencer can either draw too much heat away or hold too much heat in proximity. (or be just right!)
I have also seen many gaskets supplied with new engines that reduce the size of the exhaust port.
Many variables - no definitive answer.
Page 2 of 2 • 1, 2
» Gasket material what do you use ???
» do i need to use a gasket?
» Atwood and Fury Engines from Ebay
» Thunder Tiger Pro .25
» Funny head gasket
» Funny head gasket
Page 2 of 2
