» Jim Walker Bonanza etc.
by Ken Cook Today at 5:03 pm
by rdw777 Today at 2:52 pm
by rsv1cox Today at 10:52 am
by roddie Today at 10:30 am
by roddie Today at 10:02 am
by TD ABUSER Today at 9:25 am
» 1940's?...............
by rsv1cox Today at 7:46 am
» Lesson learned
August-2024
Acceleration Control Ring.
Something simple, but so effective.
Very few pieces, optimal result.
Applicable to almost all Cox engines.
I admire the IDEA of the * Acceleration Control Ring *
So my question:
Anyone know, who was born the idea of the Acceleration Ring?
Was it some specific Cox staff? ...
I would feel very good if a friend can tell me the story of this great invention!
Thank you.
So my question:
Thank you.
MauricioB- Top Poster
Re: Acceleration Control Ring.
The basic idea and execution of an exhaust restriction throttle of one sort or another on the single collected lateral exhaust of glow model engines preceded any Cox effort by several years. The ringed exhaust restrictor was simply a refinement/adaptation to work with Cox's cylinder design. (and Cox's set up did indeed work considerably better) In the sub-miniature class engine category, the Anderson/Jim Walker Spitfire .065 and Wen Mac MK II .049s came out with lateral exhaust collector throttle restrictors before Cox did its "ring thing". AMF Wen Mac also came out with a "ring thing" throttle restrictor for use on its glow head Hot Shot series engine powered Lotus race car and Boeing Pea Shooter plane. (circa 1965) This throttle is also very effective, though I don't like the mechanics of its linkage system which needs hacking for practical use on a built R/C plane. I'll leave it to others to say who was first with the "ring thing".
My quickie research of archives and Hepperle suggests that Cox's first use of a "Ring Thing" throttle was circa 1969 on the Medallion R/C and then the early seventies on 190 and 290 series product engines. So AMF Wen Mac may have beat them to it circa 1965 Hotshot powered Boeing Pea Shooter and Lotus race car.
Having played with various COX RC and Tarnot RC carbs as well as with exhaust throttle rings, my experience shows the exhaust throttle ring provides the better rpm control, and if throttle ring is used and the stock carb remains on the engine the top rpm achievable with the stock TD carb is higher than with RC carb thanks to the more perfect atomization of fuel in a stock COX carb than in a COX RC or Tarnot carb...let alone the poorer fuel suction with the unscreened RC carbs. On top of this, no special glow head with hot plug to reach low and stable idle is required with the use of exhaust throttle ring.
So I tend to swap my RC carbs with stock carbs and use exhaust throttles instead, that are visually less appealing/elegant but work better for me. Maybe out of some nostalgia I will reswap them sometime soon but now I am having my exhaust throttle ring period..
The only downside of exhaust throttle rings is some have caused excessive abrasion on the lowermost cylinder cooling fin that finally detached. Maybe the vibration..To prevent this I bend a thin ring from a servo pushrod/ piano wire and pull it on the cylinder up to the lowermost fin to protect the fin from the continuous abrasion by the ring vibration..with a thin enough wire the throttle ring height is still OK..if not, the bottom of the ring is sanded a bit so that the ring should not get stuck when the cylinder is tightened in the crankcase.
Sorry that my post missed the historical details.
Andras, I think some mufflers have a kind of a ring you described, made of a rather "soft" wire.
I don't have much history data either, but I suppose that with the SPI the exhaust throttle works better than a "standard" R/C carburetor. The SPI would act the same way as an air leak in a manifold when the throttle is not in its wide open position.
Thanks for all the data and opinions ... very interesting!
A particular piece that we use often and becomes common among us, to think for a moment, who or who were his / her creators of this idea, is really great.
I really enjoy the Cox r / c engine models, and that piece is incredible, it works, and it works excellently.
Thanks to that idea, I was able to control my Cox .010 ... and I enjoy it very much!
Ticomareado: very interesting those stories
KariFS wrote:Andras, I think some mufflers have a kind of a ring you described, made of a rather "soft" wire.
Thanks Kari yes I observed the inefficient throttling by RC carbs on SPI engines and figured the same reason behind it as you described.
Because for performance reasons I prefer SPI to non-SPI, this is another reason why temporarily I concentrate on exhaust throttle rings and put my RC carbs away a for bit of time.
Peter Chinn discusses Wen Mac Hot Shot .049 with "ring thing" throttle in June 1965 M.A.N. review, so I guess Wen Mac was first to mass produce an .049 "ring thing" throttle.
http://sceptreflight.com/Model%20Engine%20Tests/Wen%20Mac%20.049%20Hot%20Shot.html
Excellent information!. It is very possible then that the system of acceleration by means of the ring is of Wen Mac and that its initial date is the decade of 60.
Thanks Ticomareado. It is good to know the history of beautiful and useful inventions!
» Acceleration ring Cox Tee Dee .010
» Acceleration control rings, exhaust choking and engine heating, and fuel and oil mixes
» Dragonfly or RC Bee control snap ring
» 3.8 Million RPM, 1338mph, 24.3M G's & Ultimate acceleration 0 to 2.1 million RPM in 1ms (0.001 second)!
» almost there with the b.. ring
