BH models Mosquito build Cox_ba12
BH models Mosquito build Pixel
BH models Mosquito build Empty
Page 1 of 4 1, 2, 3, 4  Next
BH models Mosquito build Empty BH models Mosquito build
Post  rsv1cox Sat Feb 04, 2017 10:01 am
Procrastinator in Chief.  I finally got through putting it off and started this kit that I have had for over a year.  Got another one coming.
Nice kit as usual for Black Hawk models.  Very complete with nice balsa.  You can just jump right in and build out of the box, but I decided to actually read and follow the instructions.  A variation will be substituting flat Dubro hinges for the cloth hinges provided.
First thing I did was lay everything out on the plans, lot's of little bits here that are not clearly identified, fillers I suspect.
BH models Mosquito build Bh_mos11
Then epoxied the connecting dowel to the elevators:
BH models Mosquito build Bh_mos12
BH models Mosquito build Bh_mos13
Then the wing using wood glue which is a little more forgiving than my 5 minute epoxy.  Six pieces brushed on glue on all connecting surfaces assembled and aligned.
BH models Mosquito build Bh_mos10
A waxed paper sandwich and flat glass weight.
BH models Mosquito build Bh_mos14
A little more weight never hurts.
BH models Mosquito build Bh_mos15
Fuselage and nacelles next.  Power will be two Enya .09's.  Can't wait.
BH models Mosquito build Empty Re: BH models Mosquito build
Post  getback Sat Feb 04, 2017 11:25 am
Looking GOOD ! Good to see someone is getting some building in , those BHM do usually go together pretty easy and fast . Be watching Popcorn
Post  rsv1cox Sat Feb 04, 2017 5:03 pm
getback wrote:Looking GOOD ! Good to see someone is getting some building in , those BHM do usually go together pretty easy and fast . Be watching Popcorn
Thanks Eric.
Who can resist a little "test fitting".
BH models Mosquito build Mosqui11
I'm looking at a lot of leading and trailing edge sanding and thought of roddies "sanding" thread. Found a short piece of PVC and cut it in half, a little contact cement and 150 grit used on a test sample may reduce the effort. If it works I will cut a longer piece.
BH models Mosquito build Pvc_0010
Post  Oldenginerod Sat Feb 04, 2017 5:20 pm
Great build Bob, particularly seeing that the original mosquito was also made from Balsa Wood. Pretty much the fastest aircraft of WW11. Watch out! Affraid or WOW!
The following is from www.fighter-planes.com
"Construction
The genius of the aircraft's construction lay in the innovative and somewhat unorthodox use of seemingly commonplace materials and techniques. The bulk of the Mosquito was made of plywood. Stronger and lighter than most grades of plywood, this special plywood was produced by a combination of 3/8" sheets of Ecuadorean balsawood sandwiched between sheets of Canadian birch plywood. Like a deck of cards, sheets of wood alternated with sheets of a special casein-based (later formaldehyde) wood glue.
Forming the fuselage was done in concrete molds. Left and right sides of the fuselage were fitted with bulkheads and structural members separately while the glue cured. Reinforcing was done with hundreds of small brass wood screws. This arrangement greatly simplified the installation of hydraulic lines and other fittings, as the two halves of the fuselage were open for easy access by workers. The two halves of the fuselage were then glued and bolted together, and covered with doped Madapolam fabric.
The wings were also made of wood. To increase strength, the wings were made as one single assembly, onto which the fuselage, once both halves had been mated, was lowered and attached. Metal was used sparingly in the construction of structural elements. It was mostly used in engine mounts and fairings, control surfaces, and of course, brass screws.
The glue used was initially casein-based. It was changed to a formaldehyde-based preparation when the Mosquito was introduced to fighting in semi-tropical and tropical climates, after some unexplained crashes led to the suspicion that the glue was unable to withstand the climate. De Havilland also developed a technique to accelerate the glue drying by heating it using radio waves.
The specialized wood veneer used in the construction of the Mosquito was made by Roddis Manufacturing in Marshfield, Wisconsin, United States. Hamilton Roddis had teams of dexterous young women ironing the (unusually thin) strong wood veneer product before shipping to the UK."
Post  MauricioB Sat Feb 04, 2017 8:59 pm
Bob, here I am looking at your work, I really like that step by step job.
I imagine the model with both Enya 09! .... is going to look great !, I was inspired to do something with my Cox 010, maybe in the future make a twin for the 0.010 !!! .... there will be some Flat ?, or will I have to do something on my own?!, Who knows !?
Look Bob, just in a page of my country there is an ENYA for sale zero kilometer, that is, new, that announcement made me agree to You !.
Greetings, Mauricio.-
http://articulo.mercadolibre.com.ar/MLA-651808463-motor-enya-19v-antiguo-glow-coleccion-_JM#D[S:HOME,L:HISTORY,V:6]
Post  KariFS Sun Feb 05, 2017 2:28 am
Well, that's a novel approach lol! Seems to work out great too Thumbs Up
Post  getback Sun Feb 05, 2017 8:23 am
Bob the test fit looks nice i think this is going to be a very fine model in the end , with a 28" W/S it should really schoot if you decide to fly it and i hope you do ! This Site Rocks!
Post  rsv1cox Sun Feb 05, 2017 9:55 am
It is with a great deal of trepidation and courage that I even attempt to start a build thread here knowing that for the most part I'm in the company of experts when it comes to model building.  That said I am not adverse to comments both positive and negative regarding this admittedly simple effort.  So I press on.  Smile
I tried out the PVC idea on the wings leading/trailing edges with mixed results but I quickly switched over to my long used sanding block and 100 grit to start with 400 grit finish.  Sanding sealer, primer, base coat, and finish coats yet to come.
BH models Mosquito build Mos_bu15
BH models Mosquito build Mos_bu13
BH models Mosquito build Mos_bu16
BH models Mosquito build Mos_bu17
Plans said the nacelles were fragile, and they both arrived broken in the package.
BH models Mosquito build Mos_bu10
BH models Mosquito build Mos_bu11
Picked out the engines, mounting structure looks weak, might have to strengthen it up a bit.
BH models Mosquito build Mos_bu12
I have no idea as to what to use for a fuel tank or how/where to mount it.  I guess a couple of 1-1 1/2 oz triangles would do. Cross that bridge when I get there.
Yes Rod,  I have been living on a youtube Mosquito diet.  Lot's of good information on an aircraft that I'm mostly unfamiliar with. A favorite for obvious reasons.
https://www.youtube.com/watch?v=MGvjQbBNEE0
Thanks Eric.  And Maurico thanks for the support and the link.  If that was $1300.00 USD I would run away.  Smile
Post  MauricioB Sun Feb 05, 2017 10:37 am
[quote  And Maurico thanks for the support and the link.  If that was $1300.00 USD I would run away.  Smile
Bob[/quote]
Oh no no Bob!, if they were dollars I would also run away! Haha , the account is like this:
$ 1300 / US$16.4 = US$ 79.26.
Post  akjgardner Sun Feb 05, 2017 10:42 am
Looking really good. also thanks for the lesson on the building of the real Mosquito.
Post  fredvon4 Sun Feb 05, 2017 11:04 am
Fueling ideas
But first...Bob...we have seen a lot of examples of your work and craftsmanship...you need Zero trepidation and have plenty enough courage
Tin tank..or tanks..begs where?
Two under wing inside of each engine pylon seem much too low from a pickup to C/L of venturi POV.. above wing is too high
Common tin tank on main Fuselage has same above or below wing VS venturi C/L and adds a LOT of fuel line to each engine
Pressure bladders make the most sense EXCEPT one is real fiddly and TWO would drive me nutz trying to start and go fly so I would opt for One central bladder
A third option is where I most likely would experiment with--- is a common balloon tank hiding outboard above wing center fuselage inside a cigar tube
Post  rsv1cox Sun Feb 05, 2017 12:56 pm
Thanks Fred, I have never ran bladders and would not know where to start.
I'm thinking two of the smaller wedges hung on the proper side under the wing on the nacelles.
BH models Mosquito build Mos_fu10
This small flat tank would work under the canopy inside the fuselage but that means long fuel lines.. Also the tank is a clunk and scheduled for my yet to be finished Corsair, and it should be used while upright.
BH models Mosquito build Mos_fu11
That small wedge tank would not allow for much air time, but with my dizzies that's not a bad thing. Looking for early spring finish time. Going to be some outside spraying and the weather must warm.
Post  roddie Sun Feb 05, 2017 10:25 pm
Looking good Bob! Those nacelles worry me though. Do you have any 1/64" plywood that you could "skin" the sides with?
Post  Oldenginerod Mon Feb 06, 2017 5:21 am
akjgardner wrote:Looking really good. also thanks for the lesson on the building of the real Mosquito.
Sorry to detract from Bob's build thread, but it really is a fascinating aircraft.  All wood for lightness, meaning greater speed.  Lack of skilled metalworkers or aluminium in Britain, but numerous craftsmen who were skilled in wood.  The air mistery completely rejected the concept of the plane but De Haviland pushed on privately without military funding to complete the project in 22 months from the first concept drawings to full production.  The air ministery were absolutely blown away with the aircraft's performance and embraced it, thankfully.
Post  rsv1cox Mon Feb 06, 2017 7:09 am
roddie wrote:Looking good Bob! Those nacelles worry me though. Do you have any 1/64" plywood that you could "skin" the sides with?
Me too roddie, in fact I woke up last night thinking about it as I'm working on those nacelles today.  They did supply 1/64" doublers and hardwood bearers in the kit but I'm not sure they are strong enough to handled the .09's.
BH models Mosquito build Mos_do10
Besides, the bearers are not a tight fit inside the balsa.
BH models Mosquito build Mos_do11
I have some thin luan plywood and have had good luck sanding off a layer or two to use as doublers in the past.  They say to trace out the doublers then cement on to the balsa and bearers, but I think I will just epoxy as a unit then trim to fit.  If I don't like the strength then I will back it up with one sheet of luan.
I am only going to very lightly sand the nacelles and may not even airfoil them or the fuselage.
Not a detraction at all Rod, jump right in the waters fine.  I'm learning respect for these "Wooden Wonders." They were made in Australia too.  Wasn't there a very similar "Beaufighter?
Edit add: I had to google my own question. Smile
https://en.wikipedia.org/wiki/Bristol_Beaufighter
Post  KariFS Mon Feb 06, 2017 7:16 am
Because of the way it was built, the Mosquito is also a lot smoother on the surface than many metal-clad planes. That obviously helps to improve the top speed. If a flat paintjob "costs" several mph (see http://www.wwiiaircraftperformance.org/mosquito/mosquito.html ), imagine how all the little rivets and gaps must affect to drag on high speeds.
Look at this Spitfire for example and compare it to the surface of a Mosquito:
BH models Mosquito build 414054
Post  rsv1cox Mon Feb 06, 2017 7:22 am
BTW Kari,  It didn't take me long to deviate from the plans. Sad
In the second paragraph they said to mount the wing on the fuselage then sand, I didn't like that at all so I sanded the wing au natural. Third paragraph regards the nacelles and you know what I'm doing with that.  10 more paragraphs to go. Smile
PS. Like the picture Kari. Reminds me of Jet pilots expression of "Kick the tires and light the fires." Applies to Spitfires too I guess. Smile
Post  rsv1cox Mon Feb 06, 2017 7:36 am
I love this picture of a Beaufighter cockpit partly because I had one of those Brit canteens, you could wet the fabric covering to keep the contents cool.
BH models Mosquito build Beaufi10
Isn't that a flotation device above the pilots head serving double duty as head padding?
Hijacking my own thread here. Smile
Edit add> Well, a similar canteen.
BH models Mosquito build P5130010
Last edited by rsv1cox on Mon Feb 06, 2017 7:44 am; edited 1 time in total (Reason for editing : Add picture)
Post  rsv1cox Mon Feb 06, 2017 5:12 pm
Today I cut the slots for the elevator hinges using my handy dandy slot cutter.  Cut a dozen slots accurately within two minutes, turned them over and cut again equalizing any irregularities.  Had to use the saw blade instead of the slightly thinner disks because of the harder dowel.
BH models Mosquito build Mos_hi10
BH models Mosquito build Mos_hi11
I round off the hinges glue and pin when installing.
Post  Marleysky Mon Feb 06, 2017 8:41 pm
Rod - Hey thanks for the movie. That's quite a story. Undereducated American, I always assumed the Misquito was just a downsized British version of the P-38 Lightning. Oop's was I wrong. Embarassed  I appreciate the history lesson.
Post  rsv1cox Tue Feb 07, 2017 11:41 am
Double that Rene. It showed the DH Dragon in flight, worth the price of admission alone.
Started on the nacelles, roughed them out and pinned them together for a final sanding. Also set up the engine mount cutouts along the thrust line.
BH models Mosquito build More_n11
BH models Mosquito build More_n10
Next step is to glue on all the ancillaries sand and finish.
Post  rsv1cox Wed Feb 08, 2017 7:04 am
I'm trying to figure out how to position the engines. Conventional wisdom says to mount them both outboard to the control line, but I kind of like both of them positioned inboard to the fuselage. What do you think?
BH models Mosquito build Mos_en11
BH models Mosquito build Mos_en10
Post  getback Wed Feb 08, 2017 9:10 am
I like this myself..  BH models Mosquito build Mos_en10
 My guess is you're NOT using mufflers on these? Can you change the NVA so they both point up ? With this configuration i would use some tip weight ! And as far as the tank one tank duel feed from a T ,better chance they cut out the same time , Just my Two Cents Popcorn
Post  rsv1cox Wed Feb 08, 2017 11:29 am
Nope, no mufflers Eric, extra weight and drag. The NVA's can be set up or down, I will position them up. First coat of sanding sealer on this morning, probably the only one I will apply.
Some one else agrees with us on engine positions. Smile
BH models Mosquito build Cox_mo10
I thought about just mounting a couple of Cox .049's on it, but I have all these Enyas going to waste.
Post  akjgardner Wed Feb 08, 2017 4:00 pm
getback wrote:I like this myself..  BH models Mosquito build Mos_en10
Me Too
