Olympic .15 crankshaft disassembly? Cox_ba12
Olympic .15 crankshaft disassembly? Pixel
Olympic .15 crankshaft disassembly? Empty
Olympic .15 crankshaft disassembly? Empty Olympic .15 crankshaft disassembly?
Post  Roland_H Sat Jun 25, 2016 5:14 pm
Hi
What is the best way to disassemble an Olympic's drive plate and crankshaft ?
Cheers
Roland
Roland_H
Roland_H
New Member
New Member
Olympic .15 crankshaft disassembly? Empty Re: Olympic .15 crankshaft disassembly?
Post  Jason_WI Sat Jun 25, 2016 9:25 pm
Arbor press. Turn in a socket head cap screw into the crankshaft as far as it will go. Then press the crankshaft off the drive plate. I have done this to an Olympic I replaced the drive plate on.
Jason_WI
Jason_WI
Post  1/2A Nut Sun Jun 26, 2016 1:44 am
1st remove back plate, cylinder and piston. Set crank case standing up on a hard solid metal surface with a none stock bolt (as they are too soft) screw
down all the way. You want a short bolt. Tap gently with a metal flat hammer increase tap strength gradualy till the prop plate backs off the front of the crank shaft. Soak the crank case and bearings in acid till the problem disapears. Laughing JK if you must remove bearings after a good soaking over night
in your favorite solution do to a bad bearing the front one comes out easy i have found the back one can be fussy. I did the soak trick then heated the aluminum crank case with a hot air gun, catching the inner lip of the bearing it tapped right out from the back of the crank case. Small Cox Logo
Olympic .15 crankshaft disassembly? Empty olympic bearings
Post  CarlC Sun Jan 29, 2017 4:30 pm
what size bearing are in the motor?
thanks
Carl
CarlC
CarlC
Beginner Poster
Beginner Poster
Post  ian1954 Sun Jan 29, 2017 5:46 pm
They are imperial size .250x.625x.196
http://www.bocabearings.com/bearing-inventory/Radial-Bearings/18258/0-2500x0-6250x0-1960-SR4AF2
ian1954
ian1954
Olympic .15 crankshaft disassembly? Empty olympic 15
Post  CarlC Sun Jan 29, 2017 5:59 pm
Thanks Ian
Will check on the high speed bearings for mine.
Like to use the ones with the Plastic (if you will) retainers.
and the front one with seal.
Carl
CarlC
CarlC
Beginner Poster
Beginner Poster
Post  ian1954 Sun Jan 29, 2017 7:00 pm
I used a shielded bearings  as original. These are the grim ones.
Olympic .15 crankshaft disassembly? Olympi10
and the new
Olympic .15 crankshaft disassembly? Olympi11
Have a look at these.
https://www.bocabearings.com/products/bearing-and-ball-types/radial-bearings?loadResults=true&ProductType=0&P_Id_equal=0.25&P_Od_equal=0.625&P_Width_equal=0.196&P_Retainer_Material=CHROME+STEEL&P_Enclosure_Type=REMOVABLE+%28S%29
and play around with the search settings
ian1954
ian1954
Olympic .15 crankshaft disassembly? Empty bearings
Post  CarlC Mon Jan 30, 2017 4:30 pm
thanks again Ian
Carl
CarlC
CarlC
Beginner Poster
Beginner Poster
