Disassembly of the re 1956 piston & conrod assy. Cox_ba12
Disassembly of the re 1956 piston & conrod assy. Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Disassembly of the re 1956 piston & conrod assy. Empty
Disassembly of the re 1956 piston & conrod assy. Empty Disassembly of the re 1956 piston & conrod assy.
Post  aeroland Sat Feb 09, 2019 12:01 am
Hello,
I have a pre 1956 Cox Thermal Hopper.  Lots of play in the small end.  Earlier attempts to tighten the small end joints of pre 1956 piston assys. using a swaging tool for the post 1956 design have not been successful.  Neither have my attempts to remove the wire circlip.
Has anyone devised a successful method of removing the wire circlip on the pre 1956 Cox 049 engines?
Regards -
aeroland
aeroland
Beginner Poster
Beginner Poster
Disassembly of the re 1956 piston & conrod assy. Empty Re: Disassembly of the re 1956 piston & conrod assy.
Post  coxaddict Sat Feb 09, 2019 2:02 am
Welcome to the forum.
Is there any reason for trying to repair the piston assembly? I have disassembled the rod to piston joint when it pulled apart trying to free up the piston that was stuck in the cylinder. Not a good result. Is the cylinder of the early type with the smaller glow head? Do you plan on running the engine? I may have a "three piece" piston assembly if you need one. No guarantee on the fit to the cylinder bore though. P.M. me if interested.
coxaddict
coxaddict
Post  aeroland Sat Feb 09, 2019 3:13 pm
Hello coxaddict,
Thanks for your reply and greetings.
Reason to take assembly apart is the excessive end float of the conrod. I'd estimate that to be about 0.025". I usually set up the swaged type to have no detectable end float but the rod can swivel freely in the piston.
Thanks for the offer of a pre 1956 piston and conrod assembly, but as the piston is an excellent fit in the cylinder and conrod on the crankpin I plan to repair the assembly.
All my engines have to run and be in a fully serviceable condition.
I make any part for any model aero engine so plan to make a new slotted cup piece. Current thinking is from hardened and tempered steel.
Did occur to me lying in bed at 3 am unable to sleep that I could set the piston up in the Milling machine set to highest revs. and using a small diamond bit grind the middle of the wire circlip to "break its back" then prise out the ends with something like a dental pick. Would need to make a soft collet to hold the piston and some wire puller to hold the conrod to one side. Was hoping others had already devised an easier fix!
Regards -
aeroland
aeroland
Beginner Poster
Beginner Poster
