.051 groove ring lowers power? Cox_ba12
.051 groove ring lowers power? Pixel
.051 groove ring lowers power? Empty
Thinking .051 groove ring lowers power?
Post  fredvon4 Fri Feb 19, 2016 11:41 am
While Answering another question I was on the Cox Wikki page I re-read through a few of the descriptions and saw this
1961 Tee Dee 051 (Cat#200 - Manufactured Oct 1961-Jan 1996)
The 051 was simply a Class A version of the engine, physically the same on the outside only the bore was different and the piston had a small groove in the skirt to bleed off just enough power to exactly equal an 049 so no trim changes would be required to free flight models (this groove also visually differentiates the 051 from the 049 but this was of secondary importance). The 051 also had a RED carb body.
I had never before heard that the grove was anything other than a way to externally Identify a .051 from a .049
I am not sure that the grove and where it is would bleed off any power
Any thoughts on this or any way to prove the claim?
Thinking Re: .051 groove ring lowers power?
Post  Mark Boesen Fri Feb 19, 2016 11:58 am
I've never heard that, the power difference between a .049 cubic inch engine and a .051 would not need any de-tuning to equalize the small difference in size.
Post  pkrankow Fri Feb 19, 2016 12:05 pm
I am incredulous. The power output difference of .002 CI is pretty low to start with. I see no reason to deliberately lower the power.
Post  balogh Fri Feb 19, 2016 12:28 pm
I tend to believe the groove was there only to mark the 051 design. Because the groove connects the outside atmosphere with the by-pass flutes in the cylinder, it may have a very small SPI-like effect i.e. allowing some fresh air into the crank before the piston hits the TDC.
But, given the groove's incomparably smaller cross section than that of the SPI gap, I doubt this will have any practical SPI impact. The manufacturing tolerance between two 051-s with a tiny difference between their SPI gaps would probably have an impact more noticeable than that of this groove.
Post  1/2A Nut Fri Feb 19, 2016 1:30 pm
It would have been great if they had upgraded the TD cylinder and piston to a .060 the extra power would have made
a big impact without adding much weight and could have performed better than the QB and perhaps Norvel.
Post  Cribbs74 Fri Feb 19, 2016 2:15 pm
The compression pinch occurs well above the ring in the skirt. It has zero effect. I agree with others. Visual only.
Post  KariFS Fri Feb 19, 2016 2:40 pm
Well, the difference in CID is only 2% 4%, probably less than the average difference between seemingly identical engines.
Theoretically, as the piston travels downwards, the groove will let a portion of the fresh charge escape from the bypass ports directly to exhaust ports, so that may reduce the power. Probably exactly 2%  4%Smile
But given the possible differences in power output between individual engines with the same specification, to verify this would require extensively testing with at least 10 NIB units of each kind...
"If I were a rich man,
ya ba dibba dibba dibba dibba dibba dibba dum.
All day long I'd biddy biddy bum.
If I were a wealthy man.
I wouldn't have to work hard.
If I were a biddy biddy rich,
Yidle-diddle-didle-didle man."
Last edited by KariFS on Fri Feb 19, 2016 2:51 pm; edited 2 times in total (Reason for editing : Got my percentage calculations mixed up)
Post  pkrankow Fri Feb 19, 2016 2:58 pm
How about something achievable like testing 10 unmolested, otherwise original or returned to original, .051 engines with the same intake, NVA, and prop against 10 unmolested, otherwise original or returned to original, .049 engines with the same intake, NVA and prop.
I have an .051 engine and an .049 engine I would be willing to volunteer as long as it gets returned in a timely manner...although they have aluminum intake bodies on so that may not be close enough to "stock"...
The tester would have to provide fuel, shared intake and NVA...
Post  Admin Fri Feb 19, 2016 3:07 pm
I believe Warren Leadbeatter (warrenlead) wrote most of those Wiki pages. Anyone still in contact with Warren?
Post  RknRusty Fri Feb 19, 2016 3:14 pm
Is That Warren Leadbetter's Wikipedia page? I wonder if he wrote that. Maybe it should have a "Needs Citation" note next to it.
Post  ian1954 Fri Feb 19, 2016 3:29 pm
The Cox Tee-Dee .051 was basically an .049 with a slightly larger bore. (Bore: 0.410", Stroke: 0.386") compared to the 049. (Bore: 0.406", Stroke: 0.386").
The groove was put in the piston to stop the unscrupulous passing it off as a 1/2 A engine by exchange the red plasticky bit for a black plasticky bit. The Tee Dee 049 was at the upper limit for the American 1/2A size.
So I am not really sure why they made the 051 but I very much doubt that the groove affects performance and may even be beneficial as an oil carrier.
ian1954
ian1954
Post  RknRusty Fri Feb 19, 2016 3:38 pm
ian1954 wrote:...may even be beneficial as an oil carrier.
If you stretch the imagination with that thought, it could be said to help prevent piston slap. I'm sticking with the "just for identification" crowd. Any power modification could have more effectively been done to the #5 cylinder.
Post  ian1954 Fri Feb 19, 2016 4:04 pm
I just stretched my imagination and thought that perhaps the machinist measured wrong when he went to part off the piston. He stopped just in time but thought it looked nice and then produced every one the same way.
ian1954
ian1954
Post  fredvon4 Fri Feb 19, 2016 4:09 pm
My TOTALLY unscientific experience is....
I have 7 .049 TeeDee engines and 5 .051 TeeDee engines all with various configurations of venturi size, crank shaft design, and plastic and aluminum carb bodies
NOT one of my .051s is any more or less powerful from a RPM bench run perspective with the same fuel and propeller...all my bench testing shows that the biggest power adder is Nitro and venturi size....up to a point
I did this last year after buying several of the so called high performance crank shafts and muddled the experiment with 4 different aluminum venturies that had been over bored and polished, so my experiment can not in any way determine if or if not the groove ring has any effect
Logic tells me, based on the groove rings location, that it an NOT have an effect--- and logic also tells me that even at similar RPM given a particular fuel and propeller the .051 produces some measurable torque gain that would only be found with a true engine dynometer
I am NOT an well enough accomplished flier to say the .051 or the .049 TeeDee in the air is any more or less powerful and the truth is I have so many different weight and constructed combat planes it is not an easy to determine in flight.
I am not that interested to take each engine and swap it into a particular plane, fly it with same fuel and prop to see which one is the best....I generally can tell by ear which ones need to be on my heavier planes
I just thought the wikki guy seemed to insist that the goove for identification purposes was Secondary to deliberatly lowering the power output, and I contend this is FALSE until at least one of the original designers weighs in and confirms this was indeed a design goal
Post  crankbndr Fri Feb 19, 2016 7:05 pm
The Killer Bee .051 has two rings, leads me to believe they were for ID only. Two Cents
Post  Surfer_kris Sat Feb 20, 2016 6:08 am
Well, anyone can write what ever they want on wikipedia, you can't trust anything that you read there...
Surfer_kris
Surfer_kris
Post  roddie Sat Feb 20, 2016 9:13 am
My Two Cents The .051 displacement simply places the engine in the "A" category. Detuning for "trim-purposes".. could have been accomplished in plenty of other ways. I always understood the groove in the piston-skirt to be for ID purposes only.. as most of us here would agree on.
Post  fredvon4 Sat Feb 20, 2016 9:18 am
In this case the wikki page for cox engines is really well written and this is the first time something funky grabbed my attention
Between the wikki and MH aerotool page on cox engines and toys there is a lot of agreement and I am generally impressed that someone went to the trouble
I have never relied 100% on any non documented source
Post  KariFS Sat Feb 20, 2016 9:35 am
Last night I just happened to work on my newly acquired Tee Dee .051. It's the first .051 I have ever seen "in person", and now that I saw the groove I have to agree that it most likely has no effect on the performance of the engine.
So the "A" class had a minimum engine displacement limit as well?
Post  roddie Sat Feb 20, 2016 9:44 am
Warren L. is a member on the Facebook page "Control Line Enthusiasts".. as well as myself and a few other CEF'ers. Check it out if you have a FB account. There's always something interesting happening there.
Post  roddie Sat Feb 20, 2016 10:01 am
KariFS wrote:Last night I just happened to work on my newly acquired Tee Dee .051. It's the first .051 I have ever seen "in person", and now that I saw the groove I have to agree that it most likely has no effect on the performance of the engine.
Yes. I believe the "A" class to be .051 thru .1525 cubic inch size. I've heard .020 and smaller to be referred to as 1/4A.. but the official range for 1/2A is .000 to .050 cubic inches. The actual #'s go into the 4th decimal point in displacement, between 1/2A, A, B, C and so on.
Here's an example that I found.
Wiki-model engine classes
