Does anyone have any experience with a Cox Mantis? - Page 2 Cox_ba12
Does anyone have any experience with a Cox Mantis? - Page 2 Pixel
by sosam117 Today at 10:25 am
by rdw777 Today at 9:17 am
Does anyone have any experience with a Cox Mantis? - Page 2 Empty
Does anyone have any experience with a Cox Mantis? - Page 2 Empty Re: Does anyone have any experience with a Cox Mantis?
Post  fit90 Sun Dec 20, 2015 6:17 pm
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis21
Here is the fuel tank vent as it comes out the bottom of the fuse. It is bent to point forward and slightly to the aircraft's right, to point into the prop's slip stream.
fit90
fit90
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis22
The plane originally came with a non-steerable tail wheel. I couldn't see the sense in installing a throttled engine without a steerable tail wheel.
fit90
fit90
Post  fit90 Sun Dec 20, 2015 6:18 pm
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis18
Here is a quick shot of the main gear and the fuel tank vent. With the tank vent on the bottom of the fuse the fuel will not get on the aircraft when I fill the fuel tank.
fit90
fit90
Post  fit90 Sun Dec 20, 2015 6:19 pm
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis23
This is a right side up pic of the whole thing up to this point.
fit90
fit90
Post  Oldenginerod Mon Dec 21, 2015 4:19 am
Very nice. Looks like you're really thinking this build through.
Post  getback Mon Dec 21, 2015 8:04 am
I like the way you have everything configured into logical presence , and adding the tail was good your right ,whats the use in throttle with out ground control . Looking good fit90. getback Rudolph
Post  JPvelo Mon Dec 21, 2015 12:08 pm
Looks good. Be carefull with that spring starter though. My experience is that Tee Dees eventually eat the spring, it would wrap up around that carb pretty good when it happens.
JPvelo
JPvelo
Post  fit90 Mon Dec 21, 2015 8:57 pm
Jim,
Thank you for the heads up on the spring starter. I have had that happen with the silver ones and have found that they can be re-bent a little to keep them away from the prop. I have not had any issue with the black springs, yet.
Thank you,
fit90
fit90
Post  fit90 Tue Dec 29, 2015 8:44 am
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis19
Finished wing
fit90
fit90
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis20
Everything together just waiting for final assembly
fit90
fit90
Post  fit90 Tue Dec 29, 2015 8:45 am
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis24
fit90
fit90
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis25
fit90
fit90
Post  fit90 Tue Dec 29, 2015 8:46 am
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis26
fit90
fit90
Post  fit90 Tue Dec 29, 2015 8:47 am
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis27
All the radio gear, including the battery and switch weighs just 2.5 ounces.
fit90
fit90
Does anyone have any experience with a Cox Mantis? - Page 2 Mantis28
Three JR SM22 servos, a Spektrum 2S 300 mAh LiFe battery, a SpektrumAR400 4 channel receiver and an unknown manufacturer's switch
fit90
fit90
Post  fit90 Tue Feb 23, 2016 8:38 pm
Got the servos installed tonight. Having a little trouble getting the throttle linkage working smoothly. I will post some pics after I get the throttle linkage sorted out
fit90
fit90
Post  fit90 Tue Feb 23, 2016 8:45 pm
I also made a new brass, leaf spring steerable tail wheel assembly. Hopefully pics tomorrow.
fit90
fit90
Post  fit90 Wed Feb 24, 2016 8:24 pm
Does anyone have any experience with a Cox Mantis? - Page 2 P111
Here are the servos
fit90
fit90
Post  fit90 Wed Feb 24, 2016 8:26 pm
Does anyone have any experience with a Cox Mantis? - Page 2 P210
And here is the new and improved tail wheel assembly.  That is a piece of fuel tubing over the tail wheel assembly wire.  It will be attached to the rudder with a strip of covering material.
fit90
fit90
Post  getback Thu Feb 25, 2016 7:36 am
Looking Good fit90 I like the improved tail wheel assy. Are you going to make a tray for the battery and rec. to sit in , I see the bottom is the wing right now . getback Babe Bee
Post  fit90 Thu Feb 25, 2016 8:07 pm
Kind of. I glued a piece of 3/32" balsa cross grain across the top of the fuselage to mount the receiver and battery to with Velcro. I will post a picture this weekend. I am hoping to completely finish the model and run the installed engine this weekend.
fit90
fit90
Post  fit90 Sun Feb 28, 2016 5:56 pm
I am waiting for some pics to go from my phone to my email. I will post them if and when they show up. I finished it! I went to run it and taxi it up and down my drive way but ran into some issues. The tee dee had a habit of just dying at idle. Plus, it idled way high. It ran like a kittle on the test stand. Guess things didn't move to the airplane as well as I hoped. I switched to a medallion which has an aluminum carb body, starter spring, carb and a coxengines.com "tee dee power" piston/cylinder. I am hoping the different intake in the crank shaft will tame the idle characteristics. I have registered with the FAA, re-joined the AMA and will send in my application and dues to re-join my R/C club this week. I would love to be able to maiden this plane in the next month or so. But, first, I need to get the engine sorted out thoroughly. Pics to come.
fit90
fit90
Post  fit90 Sun Feb 28, 2016 7:52 pm
Does anyone have any experience with a Cox Mantis? - Page 2 S1110
Here is the final radio installation.
fit90
fit90
Post  fit90 Sun Feb 28, 2016 7:53 pm
Does anyone have any experience with a Cox Mantis? - Page 2 S1010
Does anyone have any experience with a Cox Mantis? - Page 2 S1210
Here are a couple of the tail wheel
fit90
fit90
Post  fit90 Sun Feb 28, 2016 7:55 pm
Does anyone have any experience with a Cox Mantis? - Page 2 S1310
And here is one of the radio switch from the outside of the fuse
fit90
fit90
