building a Guillows kit P 40 Cox_ba12
building a Guillows kit P 40 Pixel
by getback Today at 12:05 pm
building a Guillows kit P 40 Empty
Page 1 of 3 1, 2, 3  Next
building a Guillows kit P 40 Empty building a Guillows kit P 40
Post  akjgardner Sun Dec 06, 2015 12:26 pm
url=https://servimg.com/view/19124486/61]building a Guillows kit P 40 Airpla13[/url]
building a Guillows kit P 40 Empty Re: building a Guillows kit P 40
Post  akjgardner Sun Dec 06, 2015 12:29 pm
url=https://servimg.com/view/19124486/62]building a Guillows kit P 40 Airpla14[/url]
Post  akjgardner Sun Dec 06, 2015 12:34 pm
url=https://servimg.com/view/19124486/63]building a Guillows kit P 40 Airpla15[/url]
Post  akjgardner Sun Dec 06, 2015 12:37 pm
Started building this Guillows P 40 and half way into it decided to post my progress. This is going to be a CL powered by a tee dee .051
Post  batjac Sun Dec 06, 2015 1:52 pm
Well, I'm really behind the times.  I didn't even know Guillows made sheet wing plane kits. Is that a 400 Series kit?  Looking good.  I'm looking forward to your progress.
The Uninformed Mark
Post  akjgardner Sun Dec 06, 2015 2:08 pm
batjac wrote:Well, I'm really behind the times.  I didn't even know Guillows made sheet wing plane kits.   Is that a 400 Series kit?  Looking good.  I'm looking forward to your progress.
The Uninformed Mark
  They don't Mark, I added 1/32 balsa for strength. Im still new to CL and need my planes to be x-tra strong,,,,and yes it is a 400 series kit
Post  roddie Sun Dec 06, 2015 2:54 pm
The Uninformed Mark
I thought the same thing. I like your idea. Are you following the dihedral angle on the plan? It's hard to tell from the pics. Are those lite-ply bulkheads? Any space in the nose for a fuel tank bay? It might be good to plan for an access-hatch and fuel-proof the whole inside of the nose. Maybe tack-in a smooth thin plastic-sheet "trough" for a balloon or bladder-tank to sit in.
Very COOL!
Post  akjgardner Sun Dec 06, 2015 3:58 pm
roddie wrote:
The Uninformed Mark
Very COOL!
Thanks Roddie. yes the dihedral is correct to the plan,The bulkheads are not lite ply, but i will beef up the front of the plane,great Idea on the accessible fuel tank and fuel proofing
Post  ARUP Sun Dec 06, 2015 5:08 pm
Cool build! I had one of these in the queue until a buddy begged it off me. I built a Guillows Zero per plan as a kid and powered it with a Cox 049. It was a real nice flying airplane although the flat bottomed airfoil would be better if it weren't! I guess it worked well for me at the time being a young, inexperienced kid and all. Now I'm just an old, experienced kid but still don't know much!
ARUP
ARUP
Post  roddie Sun Dec 06, 2015 5:13 pm
Yes, it probably wouldn't hurt to strengthen the nose framework. Do you have any thin CA adhesive? I see the tube of Ambroid on your bench. I love Ambroid.. but I use CA a lot now. Thin CA can add a surprising amount of strength to balsa.. without adding much weight. Areas that won't need sanding, (the inner framework of the nose) can be treated with it.. which also helps to seal the grain prior to fuel-proofing. You could try a test by saturating a scrap-piece of a balsa stringer with thin CA.. and do a break-test vs. an untreated piece. If you've never used CA/superglue, have a fan blowing on low speed to carry the vapors away from you. The vapors can cause an allergic reaction in some people. I had trouble with it.
Post  getback Sun Dec 06, 2015 5:26 pm
Looking Good Joe !!, that will really be nice all decked out , What was the power plant if I missed that ,,, Thanks for sharing your build . I have built some Guillows but has been a lot of years , I was just up stairs not long ago and was looking at all the pieces of difft. planes I have WOw. Eric Babe Bee
Post  akjgardner Sun Dec 06, 2015 5:33 pm
roddie wrote:Yes, it probably wouldn't hurt to strengthen the nose framework. Do you have any thin CA adhesive? I see the tube of Ambroid on your bench. I love Ambroid.. but I use CA a lot now. Thin CA can add a surprising amount of strength to balsa.. without adding much weight. Areas that won't need sanding, (the inner framework of the nose) can be treated with it.. which also helps to seal the grain prior to fuel-proofing. You could try a test by saturating a scrap-piece of a balsa stringer with thin CA.. and do a break-test vs. an untreated piece. If you've never used CA/superglue, have a fan blowing on low speed to carry the vapors away from you. The vapors can cause an allergic reaction in some people. I had trouble with it.
CA is my friend too, My loyalty to Ambroid made me put the tube there for the photo. lol
Post  akjgardner Sun Dec 06, 2015 5:45 pm
getback wrote:Looking Good Joe !!, that will really be nice all decked out , What was the power plant if I missed that ,,, Thanks for sharing your build . I have built some Guillows but has been a lot of years , I was just up stairs not long ago and was looking at all the pieces of difft. planes I have WOw. Eric Babe Bee
Thanks Eric. Iv'e always liked Guillows kits and now that I'm getting lazy . I like the laser cut kits even more. Power is coming from a tee dee .051. It's going to be a little heavy but I think a TD will do the job.
Post  Cribbs74 Mon Dec 07, 2015 1:21 pm
Something to consider is strength of the nose. Guillow select Balsa is really hit or miss, usually more of a miss. If built per plans the TD will rip the nose off. You may need to block between the formers or sheet the nose.
Do the plans call for a Pee Wee? If so you will be way nose heavy, which you already alluded to. You might have to add significant weight to balance.
Looks like a fun build!
Post  akjgardner Mon Dec 07, 2015 4:44 pm
Cribbs74 wrote:Something to consider is strength of the nose. Guillow select Balsa is really hit or miss, usually more of a miss. If built per plans the TD will rip the nose off. You may need to block between the formers or sheet the nose.
Hey Ron ,Thanks for the input. I am going to sheet between the formers with 3/32 balsa back to the cockpit and sheet the whole plane with 1/32. Also to compensate for the heavy nose the tail featers will be solid 3/32 balsa
Post  ARUP Mon Dec 07, 2015 7:15 pm
When I built the Zero I did as suggested and put all that infill balsa around the nose at firewall. If I were to do it again I would sand a 'rebate' in the structure then wrap with 0.75 oz fiberglass cloth sandwiched between 1/64 balsa sheets. Fiddly but light and strong!
ARUP
ARUP
Post  akjgardner Tue Dec 08, 2015 8:41 am
ARUP wrote:When I built the Zero I did as suggested and put all that infill balsa around the nose at firewall. If I were to do it again I would sand a 'rebate' in the structure then wrap with 0.75 oz fiberglass cloth sandwiched between 1/64 balsa sheets. Fiddly but light and strong!
Thanks ARUP. I might give that a try
Post  ARUP Fri Dec 11, 2015 7:22 pm
Your build inspired me to start the Nakajima B5N 'Kate' that I've been dreaming about for some time! Maybe some day we can fly them in the same circle and do our own mini battle! Both planes to survive and fly again, of course!
ARUP
ARUP
Post  akjgardner Sat Dec 12, 2015 8:48 am
ARUP. Glad you got inspired, actually I havn't worked on mine in a week, So you've Inspired me to get back on it.Yes a reenactment of the sky battle at Pearl Harbor would be fun.Up till now Iv'e been more of a RC guy but hav been building some half A control line for springtime flying.
building a Guillows kit P 40 Empty a little more progress made
Post  akjgardner Tue Dec 15, 2015 6:30 pm
url=https://servimg.com/view/19124486/64]building a Guillows kit P 40 02410[/url]
building a Guillows kit P 40 Empty tank installation
Post  akjgardner Tue Dec 15, 2015 6:35 pm
url=https://servimg.com/view/19124486/66]building a Guillows kit P 40 02911[/url]
Post  getback Wed Dec 16, 2015 7:04 am
Looking good Joe , there is quite a bit to the framing but should come out nicely , is it getting covering on the fuse or going to be sheeted ? getback I Love This Forum!
Post  Kim Wed Dec 16, 2015 7:20 am
Beautiful Work!
'Must-Resist-Clearing-Bench-And-Starting-New-Guillows-Project' !!!
Fighting Temptation Kim
Post  akjgardner Wed Dec 16, 2015 9:33 am
getback wrote:Looking good Joe , there is quite a bit to the framing but should come out nicely , is it getting covering on the fuse or going to be sheeted ? getback I Love This Forum!
I'm going to cover with 1/32 balsa and then synthetic tissue.......I think
Post  akjgardner Wed Dec 16, 2015 5:12 pm
Kim wrote:Beautiful Work!
Thanks Kim, Iv'e alwas liked Guillows kits.Now I like the laser kits even more.
