» Free Flight Radio Assist by GallopingGhostler Today at 1:54 pm
by akjgardner Today at 1:39 pm
by getback Today at 1:05 pm
by rsv1cox Yesterday at 4:21 pm
by 1975 control line guy Yesterday at 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
by getback Tue Nov 19, 2024 7:08 am
by roddie Mon Nov 18, 2024 10:05 pm
by TD ABUSER Mon Nov 18, 2024 12:30 pm
by rsv1cox Sun Nov 17, 2024 7:40 pm
by amurphy6812 Sun Nov 17, 2024 6:43 pm
020 glow head cleaning?
I have a 020 that runs fine with glow power but stops when power is removed. Is there any way to clean or refurbish this? Don
dontrinko- Moderate Poster
Re: 020 glow head cleaning?
take the head off and go in a dark room and connect the power to it if it glows brightly its good of it dose not glow then trough it away and buy a new one
cox24711- Platinum Member
or drill and tap it and fit i regular glow plug straight in
Your plug has probably lost the platinum coating of the filament.
Here's a clip I copied from http://www.fubarhill.com/GLOW.htm
------------------8<----------------------------------------------------------
Once the cycle has started, the power source can be disconnected, as with the heat generated at combustion the CATALYTIC Reaction generated between the methanol and platinum in the plug coils becomes sufficient to keep the process going. The catalytic reaction is a reaction whereby platinum will glow in the presence of methyl alcohol vapour. This will happen without any external power source being applied.
------------------>8-----------------------------------------------------------
Not sure about the actual science behind the phenomenom, what reacts with what and so on, or whether the explanation above is 100% correct. But methanol and platinum are both needed and it seems that you have a worn out plug. Fortunately these are still available PeeWee head is a bit "wee" for a standard plug conversion, but I suppose it could be done too.
While I feel the glow plug is certainly shot, what % nitro are you using? A plug that's on it's way out using low nitro in these engines can cool off immediately and shut the engine down. The smaller ones can run very well and be less finicky on higher nitro 35%-45% . This certainly keeps the fire lit. Bob Matte makes a Nelson drop in style plug for the TD .020. http://www.flyfreeflight.com/Site/Home.html Ken
This was with 10% nitro, I do have 33% nitro, i'll give it a try. Thanks; Don
Tried 33% nitro, Runs a few seconds after glow power removed. guess I need a new glow head. Don
What size prop are you using??
Look at the filliment, if it's dull it's probably shot. The coil should have a shiny chrome look to it.
could have a break as another possibility sometimes the coil needs to be recenterd, you don't want it to be leaning up against the inner wall it will reduce its ability to reach full glow.
I would recommend trying a new glowplug. They wear out the platinum plating but the base metal of the glow element (nichrome?) still glows with power applied. That may be enough to get the last little bit of plating to fire the engine but there is not enough plating to keep the fire lit because the plating is what keeps the base metal hot when the power is disconnected.
Unplated,
Forgetful John
Unplated,
Forgetful John
Forgetful John- Silver Member
» Cleaning Cox Glow Head
» Glow head ID
» O & R .049 glow head
» Tee Dee 049 / 051 Glow Head ID
» How hot does a glow-head get?
» Glow head ID
