Drive plate Stuck Cox_ba12
Drive plate Stuck Pixel
by Ken Cook Today at 3:23 am
Drive plate Stuck Empty
Drive plate Stuck
Help! Drive plate Stuck
Post  TopBannana Fri Jul 10, 2015 10:11 am
Ive got a .09 medallion where I'm cleaning and having trouble getting the drive plate off without ruining the parts.
Drive plate Stuck Cox_me10
I am also curious if I polished the crank and the cylinder/piston would it help in performance or decrees the performance.
Last does anyone know if there is a wrench (besides the cox spanner wrenches) that i could use for the medallion
Trevor Huh...
TopBannana
TopBannana
Help! Re: Drive plate Stuck
Post  TDbandit Fri Jul 10, 2015 10:32 am
Remove the drive plate by loosening the carb body retaining nut. As you unscrew the nut, it will butt up on the drive plate and act as a puller taking the drive plate with it, it may take a little effort to pop it loose. if it's extra stubborn you can leave the tension on the drive plate and gently use some heat from a heat gun to help it along careful not to melt the body in the process.
As far as polishing the crank and P/C set I would not try polishing the Piston with the cylinder, it's a precision matched set and any tampering will hurt it's fit ruining the set. Now you can polish the crankshaft to help reduce friction.
(Bandit)
TDbandit
TDbandit
Post  dankar04 Fri Jul 10, 2015 11:28 am
Motor looks used and all parts worn in. Polishing is wate of time. Good cleaning/ lube it up should be good to go. Cox wrenck has fitting for lock collar behind thrust washer. Maybe heat will loosen castor and make removal easier. Fireworks
dankar04
dankar04
Post  Cribbs74 Fri Jul 10, 2015 11:48 am
I've never been a big suppporter of using the lock nut to press off the driveplate. Mostly because it grinds away material as you work the driveplate off.
Not knocking anyones methods or anything. Just there is another way that is less invasive.
Well, two other ways, but one requires a press which not everyone has. So what I do is unscrew the backplate, piston and cylinder lay the back of the crankcase on a hard flat surface, preferably steel. Screw the prop screw back into the crankshaft and carefully tap the head of the screw until the driveplate pops off. It shoudn't require much force to remove it.
I would also dedicate a prop screw to this method of removal as you may marr the head with the hammer. Or you may not, I never do, but it could happen.
Post  Jason_WI Fri Jul 10, 2015 5:23 pm
http://www.harborfreight.com/1-2-half-ton-arbor-press-3551.html
The above link is what I use. Use hardened cap screws and thread in at least 4 or more turns into the crank then press the crank off of the drive plate. Works best if the arbor press is bolted down to a heavy workbench.
Jason_WI
Jason_WI
Post  getback Sat Jul 11, 2015 6:25 am
that's cool , I just was thinking bet that thing would crack some black walnuts ,I have quite a few trees , they sprout easily from the nuts . I am glad this came up I had used the spanner part of the wrench but ....no more , thanks Small Cox Logo
Post  roddie Sat Jul 11, 2015 6:30 am
Jason_WI wrote:http://www.harborfreight.com/1-2-half-ton-arbor-press-3551.html
Wow.. that's gone up in $$.. It was $28.00 USD less than 6 months ago! Shocked
