» Tee Dee .020 combat modelby roddie Today at 2:34 pm
by roddie Today at 2:13 pm
by sosam117 Today at 12:32 pm
by rdw777 Today at 10:24 am
by batjac Yesterday at 10:47 pm
by roddie Yesterday at 9:50 pm
by rsv1cox Wed Nov 20, 2024 4:21 pm
by 1975 control line guy Wed Nov 20, 2024 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
by getback Tue Nov 19, 2024 7:08 am
by roddie Mon Nov 18, 2024 10:05 pm
My head blew it's top!
Seriously it did, a first for me. .010 head brand new. Fired of ran for about 5 seconds and puff! Center post shoots up like a jack in the box. I push it all back in and tapped the collar down snug. The plug still glows but no compression. Ebay purchased......anyone experienced this?
Re: My head blew it's top!
Never. Do you think it was a Cox old stock part? It wasn't from Bernie or Matt was it?
cribbs74 wrote:Seriously it did, a first for me. .010 head brand new. Fired of ran for about 5 seconds and puff! Center post shoots up like a jack in the box. I push it all back in and tapped the collar down snug. The plug still glows but no compression. Ebay purchased......anyone experienced this?
Ron-Truely a "WT#" moment.
Never even heard of this happening.
Thinking about it, with the dissimilar metals/compression/heat, I'm suprised it hasn't happened more often.
I like the "jack in the box" reference. Funny visual.
Last resort, heat the head good and hot and press the post in tight with some sort of clamp or vise arrangement
and let it cool.(duh)
Hope there's some chimers in the wings.
dckrsn- Diamond Member
That sounds very unusual but as ha been said doesn't seem like it should be.
Maybe press it back in until it is at the point t should be and then maybe a little JB weld.
dckrsn wrote:cribbs74 wrote:Seriously it did, a first for me. .010 head brand new. Fired of ran for about 5 seconds and puff! Center post shoots up like a jack in the box. I push it all back in and tapped the collar down snug. The plug still glows but no compression. Ebay purchased......anyone experienced this?
The Last Resort +...send it to me, and I'll try to stick a glowplug in it !
RknRusty wrote:Never. Do you think it was a Cox old stock part? It wasn't from Bernie or Matt was it?
Rusty,
No, not from Matt or Bernie but, a new part in unopened cox packaging.
Yep, it did everything a jack in the box does except no "pop the weasel" music or boing sound!
It is comprised of a coil glow spring, packing/sealing gasket center post and beveled press fit collar to lock everything in place.
I push it back in the same way it popped out except now I can see air bubbles and castor coming up around the center post.
nitroairplane wrote:That sounds very unusual but as ha been said doesn't seem like it should be.
Good idea, except I already snapped it back together and It doesn't want to come apart!
Kim wrote:dckrsn wrote:cribbs74 wrote:Seriously it did, a first for me. .010 head brand new. Fired of ran for about 5 seconds and puff! Center post shoots up like a jack in the box. I push it all back in and tapped the collar down snug. The plug still glows but no compression. Ebay purchased......anyone experienced this?
Kim,
Seriously considered that but, a screw in glow plug is about 3/4 the diameter of a .010 head plus even if it worked I would have to purchase a new clip arrangent for that head only. So cost wise it may not make sense.
I put the old one with wrench marks on the fins and it works fine, looks crappy though. Kinda angry now that I am out $13.00.
Last edited by cribbs74 on Thu Dec 08, 2011 9:16 am; edited 1 time in total (Reason for editing : Language correction)
Ron,
It sounds as if the parts were not properly pressed. It happens on rare occasions. It will be nigh impossible for you to re-press same without the special tooling.
BTW any items you (or anyone else) purchase from us are unconditionally guaranteed to function, meaning that if someone bought a glow head that malfunctioned on first attempt, we would replace it.
Bernie
www.coxinternational.ca
Bernie
Cox International wrote:Ron,
Bernie
Bernie I may try heating it and see if I can get it to seal. Good to know you stand by your products. In future I may buy all my parts through the "real Cox distributors" like you and Matt. Sometimes deals come up on ebay that are too good to pass up. For example I found a new in cox package .020 head for 2.95 buy it now. I snatched it quick......
Sounds like a defect with the core and/or assembly as Bernie mentioned.
Same thing happened to be on an 049 engine a while back. Apparently the assembly wasn't pressed correctly and the glow head core was broken in two before running. After a minute of running part of the core got loose. No nearly as extreme as your case, but it happens I guess, albeit rare.
Matt
Matt
This has never happened to me.
Infact i rarely even burn glow plugs I guess i am lucky with them.
I can attest to Bernie's credibility when replacing faulty glo-plugs. One that I got from him didn't want to thread properly.
Sent a note to Bernie and he replaced the plug. I was curious that the package had been opened but then realized that Bernie had checked the threading on the replacement plug prior to sending it.
With sevice and consideration like that I am a dedicated fan of Bernie!
SuperDave- Rest In Peace
I have only made 1 or 2 orders from Bernie and it/both arrived quickly and i recieved 2 .020 springs and not one.
What is the black material around the center? Could it have become brittle?
microflitedude wrote:What is the black material around the center? Could it have become brittle?
I suppose it could but I don't think that would make it pop out.
The upper and lower insulators are made of either Nomex or Quinargo; in between the 2 is a steel washer.
Bernie
Bernie
Actually...I had this happen on a PeeWee when they first came out. Got it home, fired it up, and POOF, no compression. The insulation had blown. It still glowed. I went back to my LHS and bought a new plug... $0.49.
I chalked it up to being a new product. That's the only time I had that happen on ANY type plug.
Edit: Additional thought. When I got that engine, the props had not come in. I cut down a 5x3 Tornado Plasticote and balanced it with my primative razor blade balancer that most of us used at the time. Those were the days...
gcb- Platinum Member
George,
I think the .010 heads are different as they have no insulator, just a locking collar, center post, packing disc and the glow wire. At any rate I heated the head back up and gave a tug on the center post and it came out so quick that I ripped the glow wire off.
So I may take the route Kim took and see if I can convert it to a regular thread in type glow head. Not sure about compression issues though.
Ron,
I believe the packing disk is an insulator. The center post must be electrically isolated (insulated) from the rest of the plug or you will have a short which will cause the wire to not glow.
gcb wrote:Ron,
Yes, you are correct. It is an insulator, as in it does seperate the bottom portion of the post from the head except the metal snap ring that holds the whole assy in place touches the post and the head. Let me go take a pic real quick......
Ron:
Considering the tiny size of the .010 I doubt if you'd find a standard glo plug small enough to fit.
New .010 glo-heads are available from Bernie @ $12.95 IIRC.
No you would not as the smallest glow head is the .010 one but you could turn down a .020 head to fit and the first runs of the tee see .010 were made with a turned down .020 head.
» What is this going to be? (ans: Blew Angel 38)
» Introducing the Blue Bee, the Blew diesel Medallion, and the disappointing OK Cub diesel.
» Tee Dee Head vs Medallion Head
» What head is this ?
» Off the top of your head?
