» TEE DEE Having issuesby balogh Today at 7:42 am
by rsv1cox Today at 7:36 am
1/2A stunt trainer design
Page 2 of 9
Page 2 of 9 • 1, 2, 3, 4, 5, 6, 7, 8, 9
Re: 1/2A stunt trainer design
rogermharris wrote:good to know phil!
it was so long ago that i don't recall if it was that way when first built or over time got worse
I expect it got worse over time. That type of thing always does.
While the dope is a factor to that problem, wood choice and dope selection is as well. Using the correct type of grade can eliminate cupping caused by dope. Many times the model is painted usually top side first and then the underside and left to dry on it's gear. The top side of the model flashes off while the underside is still wet. Applying more dope to the one side opposing the cup can sometimes reverse that in minutes. One thing to remember is that thinned dope is going to strengthen your wood far more than enamel will not to mention there's little to no weight penalty in using it. Using the proper dope is also important as there's 2 types taughtening and non taughtening. Sig Lite Coat is a plasticized dope which shrinks very little and won't cause issues on planked surfaces as pictured. It's used on free flight stick and tissue models. It also provides the highest resistance of fuel out of any of the dopes on the market today. Ken
Ken Cook wrote:While the dope is a factor to that problem, wood choice and dope selection is as well. Using the correct type of grade can eliminate cupping caused by dope. Many times the model is painted usually top side first and then the underside and left to dry on it's gear. The top side of the model flashes off while the underside is still wet. Applying more dope to the one side opposing the cup can sometimes reverse that in minutes. One thing to remember is that thinned dope is going to strengthen your wood far more than enamel will not to mention there's little to no weight penalty in using it. Using the proper dope is also important as there's 2 types taughtening and non taughtening. Sig Lite Coat is a plasticized dope which shrinks very little and won't cause issues on planked surfaces as pictured. It's used on free flight stick and tissue models. It also provides the highest resistance of fuel out of any of the dopes on the market today. Ken
thanks for all the info ken!
i guess i need to order some lite coat dope
should i use a mid grade balsa for the wings?
rogermharris- Platinum Member
Using C grain balsa is going to result in improving your chances in lessening warps. Sig Lite Coat is also the ticket. 8 oz. jar of Sig Lite Coat equates to painting a lot of 1/2A models. While Sig Lite Coat can be used for tissue applications, it will not shrink the tissue to the degree that Sig Supercoat will if you decide on using it for this application. You must use Supercoat first or more followed by the Lite Coat to prevent further shrinkage. It's thick as syrup in the jar and it needs to be reduced with at least 60% thinner prior to use. I highly recommend using no other thinner than Sig. It's expensive but well worth the $$$. You will need twice the amount of thinner as the dope. You will find that when brushing outside from a open container you will need to replenish the thinner as it's evaporating from the jar during application. Don't use retarder with this dope even though Sig makes it. Sig thinner is a slow drying dope. It does improve overall finish due to this as the brush strokes melt away. Ken
Interesting comments here regarding flaps. This is the way I hooked up mine: Is there a better way?
with a link to the throttle on this Enya 15:
Throttle advances full on up, flaps go down, elevator goes up. Makes for interesting flying as I recall. But it hasn't seen air time for years. Seen here before. I scratch built it using a horizontal stab from a crashed R/C model.
i was going to run the push rod from the bellcrank to the control horn on the flaps and then select a different home in the flap control horn and run another push rod back to the rudder. yours looks fine as well. i built a similar model back in the day with a carbureted engine and ran it with a third line. was specially fun for take offs and landings, touch and goes ect.
duke.johnson wrote:If you get into the laser cutting biz, you might get really busy. I'd send you work for cutting ribs, I hate cutting ribs. Depending on the price, I'd be in for a beginner ringmaster bipe too.
If you need something cut, let me know. I have full use of our laser cutter whenever it's free.
Surely as throttle goes on the flaps would go UP. More speed - less flap needed. Less speed (landing approach) - more flap needed.rsv1cox wrote:Throttle advances full on up, flaps go down, elevator goes up. Makes for interesting flying as I recall. But it hasn't seen air time for years. Seen here before. I scratch built it using a horizontal stab from a crashed R/C model.
ok... looks like $18 plus shipping for a Ringmaster Beginner Bipe kit. this is for the balsa and plywood parts. wings and fuse will be cut from C grain Balsa.
i will order the material when i sell three
looks like this...
if you want the hardware, i will look into that as well.
Heck what a deal. I'll take one. Let me know when you have three ordered.
duke.johnson- Diamond Member
You KNOW I want one too !! I have some thing else I am wanting too when I get time I will get with you , right now my Damn water pump is out and heading down to basement to see whats up with it
Come on guys! Just one one more! These look like great little kits and the ringmaster flyathon will be here before we know it.
rogermharris wrote:duke.johnson wrote:If you get into the laser cutting biz, you might get really busy. I'd send you work for cutting ribs, I hate cutting ribs. Depending on the price, I'd be in for a beginner ringmaster bipe too.
Roger
I have some ribs I wouldn't mind having cut. How do we input them into the laser cutter? Do I just send you the template and you figure it out? I don't know.
Duke
Ok, I'm in. I love Bipes and that looks like a nice one and a simple build.
duke.johnson wrote:
Roger
Duke
duke,
you can send me pretty much any format and i can work from it. depending on the file format i may need some dimensional info. also if you can give me an idea of how much material i need and the thickness, i will add it to the order for the bipes
getback wrote:You KNOW I want one too !! I have some thing else I am wanting too when I get time I will get with you , right now my Damn water pump is out and heading down to basement to see whats up with it
sorry to hear that! but, know the feeling... i had to replace my water heater a couple weeks ago. narrow steps and a dirt floor basement... really beat me up along with being muddy. not sure how long it had been leaking.
looks like we have three takers.. it's not going to weigh much so lets say $5 s&h
you can paypal me to my email address
i will also cut some 1" wheels to throw in.
if anyone else is interested i would be more than happy to add to the order
Roger
I'm not sure what I need for ribs yet. How soon do you need to know. I'm trying to get ready for a trip this weekend.
Duke
Duke
duke.johnson wrote:Roger
Duke
what's the thickness you need? 1/16" ?
i will make sure i have the material on hand
I see if I can dig out some planes tonight and check.rogermharris wrote:duke.johnson wrote:Roger
Duke
If not no worries. Like you said. Your getting ready to go away
[quote="rogermharris"]
Roger. I would be interested in a Ringmaster as well but you will need to be willing to do some homework for me on shipping to Australia, and pack securely. Our dollar sucks at the moment (great for exports ) so it's gonna cost me a fair bit more. If you can figure out a good shipping cost that would be great. If it's too much effort then I understand fully. I realize you're only doing this as a favor and it's not a commercial proposition.
Besides, I already have enough kits sitting around unfinished.
getback wrote:
Looks like we have three takers.. it's not going to weigh much so lets say $5 s&h
You can paypal me to my email address
I will also cut some 1" wheels to throw in.
If anyone else is interested i would be more than happy to add to the order
Hi Rod
Did a quick look up on shipping. As a guesstimate it looks like $10 to ship to you but I won't know for sure till I get a kit cut and packed. I can cut the wing in half with some sort of glue joint to make the package smaller
Thanks Roger. I was going to suggest that with the wings because it will be the length that determines the cost more than the weight. If it works out good I might grab a couple as the shipping will probably work out the same.
Cheers.
Cheers.
Oldenginerod wrote:Thanks Roger. I was going to suggest that with the wings because it will be the length that determines the cost more than the weight. If it works out good I might grab a couple as the shipping will probably work out the same.
Cheers.
here are the "export" wings
» Scientifc Stunt Trainer
» Cox Crusader Stunt trainer
» finally took the stunt trainer out today.
» Ace+ c/l trainer.
» Finally...War Dog and Stunt Trainer Get Some More Attention !
» Ace+ c/l trainer.
Page 2 of 9
