Broken Cox Babe Bee Crankshaft Cox_ba12
Broken Cox Babe Bee Crankshaft Pixel
by rdw777 Today at 9:35 am
Broken Cox Babe Bee Crankshaft Empty
Broken Cox Babe Bee Crankshaft Empty Broken Cox Babe Bee Crankshaft
Post  NEW222 Sun May 24, 2015 5:21 pm
Ok. So went out and flew this weekend and had a ball doing so. I now remember how much fun this is. Anyways, I am now the proud owner of a Babe Bee engine that now sports a broken crankshaft. Sheared off the splines at the propeller end. Is there any way this thing can still fly, or do I need to look around for a used crankshaft? My Man-Win trainer was a hit, until.... Sorry that I do not have any pictures of it, as I forgot it at the cottage.
Broken Cox Babe Bee Crankshaft Empty Re: Broken Cox Babe Bee Crankshaft
Post  pkrankow Sun May 24, 2015 5:48 pm
Get a replacement crank.
Coxengines.ca
exmodelengines.com
should have for the bees. You probably were using a screw that only held a few turns in. Switch to a stud that is seated all the way in with a cone of some type on it, or use a screw that is sized to go in nearly to the bottom. This will prevent breaking the shaft on the spline-shaft stress concentration.
Post  TDbandit Sun May 24, 2015 5:58 pm
If the splined portion is completely sheared off you've got to replace the crank, Bernie at Cox international has the cranks don't try and tighten the drive plate against the crank face in an attempt to run it, it will throw the prop in short order. (Bandit)
((Edit)) Phil kinda beat me to it but as he said make sure the screw is long enough, it will prevent that from happening again.
TDbandit
TDbandit
Post  Admin Sun May 24, 2015 7:28 pm
A few years ago I bought a box of engines and this was one of them included in the box. When I flipped the prop over, to my surprise the whole drive plate screwed off LOL!
Broken Cox Babe Bee Crankshaft Babe_b10
Broken Cox Babe Bee Crankshaft Engine10
Broken Cox Babe Bee Crankshaft Plate_10
Broken Cox Babe Bee Crankshaft Unrepa10
Broken Cox Babe Bee Crankshaft Things10
Broken Cox Babe Bee Crankshaft How_to10
Broken Cox Babe Bee Crankshaft Ready_10
Broken Cox Babe Bee Crankshaft Ready_11
Broken Cox Babe Bee Crankshaft Broken10
Broken Cox Babe Bee Crankshaft Broken11
Broken Cox Babe Bee Crankshaft Set_as10
Broken Cox Babe Bee Crankshaft Engine11
Broken Cox Babe Bee Crankshaft Cly_of10
Broken Cox Babe Bee Crankshaft Apart_10
Broken Cox Babe Bee Crankshaft Case_w10
Broken Cox Babe Bee Crankshaft Prop_h10
Broken Cox Babe Bee Crankshaft Screwi10
Broken Cox Babe Bee Crankshaft Ready_12
Broken Cox Babe Bee Crankshaft How_to11
Broken Cox Babe Bee Crankshaft Crank_10
Broken Cox Babe Bee Crankshaft Oil_th10
Broken Cox Babe Bee Crankshaft Ready_13
Broken Cox Babe Bee Crankshaft Ready_14
Broken Cox Babe Bee Crankshaft Finish10
Post  GallopingGhostler Mon May 25, 2015 7:33 am
TDbandit wrote:If the splined portion is completely sheared off you've got to replace the crank, Bernie at Cox international has the cranks
http://coxengines.ca/cox-.049-crank.html $5.95 US
Broken Cox Babe Bee Crankshaft Cox%20049%20Crank%201-01
Post  TDbandit Mon May 25, 2015 2:14 pm
Thanks I meant to add a link and neglected to do so sorries (Bandit)
TDbandit
TDbandit
