Spacebug-Style Crankshaft Repair Cox_ba12
Spacebug-Style Crankshaft Repair Pixel
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Spacebug-Style Crankshaft Repair Empty
Spacebug-Style Crankshaft Repair Empty Spacebug-Style Crankshaft Repair
Post  G.O. Stang Thu Feb 27, 2014 8:21 pm
So last week I won this dead Thermal Hopper.
http://bit.ly/1fuMONt
It suffered from the all too common broken off threads on the crank. I wanted to bring it back to life.
Most would assume just replace the crank, but those are a rare commodity on their own. So I hatched a new plan. I had a small threaded rod I got from another engine that was the proper thread. So what now? Weld it. I clamped the rod and the crank(wrapped in electrical tape to protect the bearings) and put a small gap to assure good penetration and a couple zaps with a mig welder. Then I used a file to carefully true up the weld and make it more uniform.
Here's the results.
Spacebug-Style Crankshaft Repair 4666C55F-2C6D-40C3-924E-02B058352AF5
You care barely tell.
Spacebug-Style Crankshaft Repair 0CFC06EA-01FA-4D77-86AB-CCD0C802217F
It's not perfect or beautiful, but it'll work.
Spacebug-Style Crankshaft Repair AF102C06-0DF1-439D-8F6E-11D229469757
Also ignore the incorrect head/cylinder. Just what it came with. But it's great to see it in one piece again!
So if you've got a broken one, don't fret. It can be saved!
G.O. Stang
G.O. Stang
Spacebug-Style Crankshaft Repair Empty Re: Spacebug-Style Crankshaft Repair
Post  Cribbs74 Thu Feb 27, 2014 8:28 pm
It's great to see it back in one piece. Not sure if you ever plan on running it, but if you do wear glasses!  Very Happy
Post  G.O. Stang Thu Feb 27, 2014 8:31 pm
Cribbs74 wrote:It's great to see it back in one piece. Not sure if you ever plan on running it, but if you do wear glasses!  Very Happy
I don't think it'll break. Atleast there. I tried to purposely break it by bending and couldn't. But I will use caution regardless!
G.O. Stang
G.O. Stang
Post  Jason_WI Thu Feb 27, 2014 9:28 pm
Might want to stand behind the test stand when yo fire that one up.....  Affraid or WOW!
Jason_WI
Jason_WI
Post  ian1954 Fri Feb 28, 2014 2:30 pm
I admire the ingenuity and determination to bring one of my favourite engines back to life.
If your approach doesn't work then is is a relatively quick job to bore out the crankcase, shorten it and fit a bog standard cox crankshaft. I have done this a few times now.
Spacebug-Style Crankshaft Repair Therma11
ian1954
ian1954
Post  G.O. Stang Fri Feb 28, 2014 2:47 pm
ian1954 wrote:I admire the ingenuity and determination to bring one of my favourite engines back to life.
See the problem with this hopper is it has the Oilite(?) bronze bushing. Although to wouldn't call it a problem as I've been looking for an example of this.
G.O. Stang
G.O. Stang
Post  ian1954 Fri Feb 28, 2014 3:13 pm
Some have bearings and some don't.
Here are four - two do and two don't.
Spacebug-Style Crankshaft Repair Oilite10
Spacebug-Style Crankshaft Repair Oilite11
The middle two do the outer two don't.
These are all original and not bored out. (But will be!)
ian1954
ian1954
Post  Cribbs74 Fri Feb 28, 2014 5:25 pm
Ian,
Great job shortening the snout on that Thermal. It looks factory made.
Spacebug-Style Crankshaft Repair Empty one day left for this case and crank
Post  fredvon4 Sat Mar 01, 2014 7:43 am
http://www.ebay.com/itm/Cox-Thimble-Drone-049-Crankcase-Crankshaft-/221380404845?pt=US_Radio_Control_Control_Line&hash=item338b4ce66d
Post  G.O. Stang Thu Mar 06, 2014 7:02 pm
Well this dual needle thing is pretty neat.
Spacebug-Style Crankshaft Repair 7B6968E4-9191-4770-ADA3-C79E673CF190
G.O. Stang
G.O. Stang
Post  Cribbs74 Thu Mar 06, 2014 10:22 pm
Did you have an assembly? Or is that something new?
Post  G.O. Stang Fri Mar 07, 2014 6:35 am
Cribbs74 wrote:Did you have an assembly? Or is that something new?
Came in the mail yesterday. So it's something new.
G.O. Stang
G.O. Stang
Post  Cribbs74 Fri Mar 07, 2014 9:35 am
Looks good.
Post  JPvelo Fri Mar 07, 2014 9:51 am
I've never understood the dual needle.
JPvelo
JPvelo
Post  Cribbs74 Fri Mar 07, 2014 11:03 am
Me either.
I think it's a FF thing. You adjust the needles for different types of fuel and then you just switch the fuel feed line when you change fuel.
That's my best guess....
Post  stevej Fri Mar 07, 2014 11:22 am
Dual needles were for throttle. You would set one for high rpms, the other rich to slow the engine down for low speed when both needles were in use.
stevej
stevej
Post  G.O. Stang Fri Mar 07, 2014 11:26 am
From my understanding, it was designed for radio control. Atleast that's what the package says. But can be utilized in control line and free flight. Something will release a soft line for the second needle effectively richening the mixture. That something is whatever you design or use to make it happen. It's a primitive throttle. Alternatively, I've heard of them just being ran with the dual needle and one Y-ed line.
G.O. Stang
G.O. Stang
Spacebug-Style Crankshaft Repair Empty Space bug crank repairing
Post  frenchomebuilder Mon Mar 17, 2014 8:41 am
Here is my method
http://www.rcgroups.com/forums/showthread.php?t=2057675
frenchomebuilder
frenchomebuilder
Beginner Poster
Beginner Poster
Post  Jason_WI Tue Mar 18, 2014 6:07 pm
That is a neat way to repair it. I have one where the threads are broken off. I can save the knurled part and cut off the broken shaft from there.
Welcome to the forum!
Jason_WI
Jason_WI
Post  frenchomebuilder Wed Mar 19, 2014 6:38 am
Jason_WI wrote:That is a neat way to repair it. I have one where the threads are broken off. I can save the knurled part and cut off the broken shaft from there.
Thank you for welcoming ..
I think you can drill through the knuled part . If I had that part, i had tried to ..
Good luck !
frenchomebuilder
frenchomebuilder
Beginner Poster
Beginner Poster
Spacebug-Style Crankshaft Repair Empty If the end of the crank is bent not broken:
Post  iamplanecrazy2 Tue Mar 25, 2014 10:04 am
Excellent repair!
I have not tried repairing a broken crank but have a few that I will have to make an attempt at.
I have straightened out a few that were bent.
Several years ago I started a thread showing how on the MECOA model engine forum.
Pulled it up and found the photos were not working so fixed that and now the
post has photos again. Here is a link for anyone interested:
http://www.modelengine.org/phpbb3/viewtopic.php?f=19&t=4521
iamplanecrazy2
iamplanecrazy2
Silver Member
Silver Member
Spacebug-Style Crankshaft Repair Empty I sent the image sequence
Post  frenchomebuilder Thu Mar 27, 2014 6:17 pm
Spacebug-Style Crankshaft Repair A6340331-22-REPARATION%20VIL%20SPACEBUG
frenchomebuilder
frenchomebuilder
Beginner Poster
Beginner Poster
Spacebug-Style Crankshaft Repair Empty I ran this motor
Post  frenchomebuilder Wed Apr 02, 2014 2:07 pm
Spacebug-Style Crankshaft Repair A6344119-216-SPACEBUG%20VILO%20REPAREYesterday I ran this repaired motor, that was a pleasure .. The prop remained well fixed !
frenchomebuilder
frenchomebuilder
Beginner Poster
Beginner Poster
