» Free Flight Radio Assist by rdw777 Today at 9:24 am
by getback Today at 7:14 am
Reed Speed
Reed Speed
Hi New to forum and need some help locating a speed chart to be used in Reed Speed, any and all the help I can get will be great.
mrem
mrem
mrem- Moderate Poster
Re: Reed Speed
mrem wrote: Hi New to forum and need some help locating a speed chart to be used in Reed Speed, any and all the help I can get will be great.
mrem
Do you like math? Go here:
https://www.coxengineforum.com/t6535-speed-calculations?highlight=Speed+calculator
I think the linc to the UK site is expired, but the rest of the info is a good place to start.
Speed-on
OOPS, forgot to say" Welcome to the forum" !!!
Re: Reed Speed
mrem
Welcome to the forum mrem!
The online calculator I was using is no longer available.
I asked on Stunthanger and got this formula:
The full derivation is:
(2 x Line Length(ft) x #Laps x 3.14159 / time (sec)) x (3600 (sec/hr) / 5280 (ft/mi))
I did the math and it works out.
What are you building for Reed speed?
JPvelo- Diamond Member
speed chart
Hi JIM, Thank you for the info on speed timing ,I can get my grandaughter to worker it out for me. the model I am working on is a p 51 Mustang with a old Cox .o49. I have a AMA Speed chart but it does not show low enough
for my use.
mrem
for my use.
mrem
Re: Reed Speed
Bill Lee on Stunthanger was kind enough to post a link to an online calculator:
http://www.nclra.org/Programs/Speeds.php
Mrem,
You should post some pictures of your build here:
https://www.coxengineforum.com/t7115p320-cef-speed-contest-design-discussions
Mrem,
reed speed
I will post photos of the p51 as I go with this project , the only thing I have is the templates now. I will try to send in some photos when I complete some work on it. mrem
Re: Reed Speed
JPvelo wrote:Bill Lee on Stunthanger was kind enough to post a link to an online calculator:
Thanks for posting that link to the calculator. It's great, and even caters for us 21st century types by having KPH
Re: Reed Speed
Then there's this:
Or the more simple and commonly-used formulae:
3600 divided by the one mile time.
1800 divided by the half mile time.
3600 divided by the one kilometer time.
Admittedly, my formulae are inaccurate by a factor of 0.0395%.
A one inch difference in a 60' set of lines is .139%.
reed speed
Happy Easter to all, I checked with my son who is a speed flyer about the chart and he said the same thing to use the one on stunt hanger, or go fast enough to use the AMA chart was this a good answer?
Mrem
Mrem
Reed Speed
I have a photo of a P51 that I would like to post on this forum but I need some help in doing so, could some one tell me what to do to make the post? all info will be a big help for getting me started sending photos.
mrem
mrem
Re: Reed Speed
Posting photos can be a little confusing to the newbie, but isn't that hard once you know how. I can't find them, but there are specific threads telling you how to do it. If no-one chimes in with a thread location, I'll offer a simple explanation if you like.
Reed Speed
I thank you for any info you can give me.
mrem
mrem
Reed Speed
Mark, Thank you for the speed chart I am sure it will be used a lot of times,I have all the templates and wood to build a plane for the Reed Speed event. I will start cutting soon, thank you foe the info.
mrem
mrem
Re: Reed Speed
mrem wrote: I thank you for any info you can give me.
mrem
Here is a link,its found in FAQ, the last step is 'cut and paste'
https://www.coxengineforum.com/t367-how-to-post-an-image-in-a-topic
crankbndr- Top Poster
glow head adaptor
I am looking for a glow head adaptor that will take a glow plug, and the Eng. will not loose RPM'S that will fit a Cox .049. if some one knows where I can bye one could you let me know on this forum . it will on .049 on a reed speed plane. thanks for any help.
mrem
mrem
Re: Reed Speed
You can get from
http://coxengines.ca/
http://www.exmodelengines.com/
however you will have to experiment with both different glow plugs for temperature and different gasket counts. The drop-in style with a head clamp offer better performance with less fuss.
glow head adaptor
Thanks Phil, I will check it out. mrem
glow head adaptor
:I would like to thank all the great people on this forum for all the help you gave me on the Glow Head adaptor I needed to fly in reed speed for 2015 , I talked to Joey over on Stunt Hanger and he is sending me one. mrem
Re: Reed Speed
Dad the Merlin 1/2 a clamp ring and plug inserts work very nice just remember to add a pile of head shims. When it needles easily and you are not blowing a plug every run you will know it is happy. We tend to over prop and over compress both are bad for engine longetivy. Let me know if it does not work for you and I will send you a Nelson head and plugs to go with it. The cox heads that get drilled out and tapped for a standard glow plug wind up with to much volume and performance will drop a lot. Joey.
joey mathison- New Member
Re: Reed Speed
Re: Reed Speed
Start with 5 gaskets with a drop-in for 25% nitro. You'll be in the ballpark. Try adding or removing one at a time and see if it improves.
Reed Speed
With the help from the good people on this forum I have a complete P51 Mustang ready to test, now the weather here in VA is the hold up but will change soon. I will send photos when we can start flying the plane.
mrem
mrem
Re: Reed Speed
Cool Mrem will be awaiting pics and videos if you can , Good luck on the Maiden !!!
reed Speed
I am lucky enough to have a 15 year old grand daughter who can do the photos and post them for me, she is playing fast pitch soft ball fore her high school now so I must fit in some time. I will post what ever she takes .
mrem
mrem
» To Jim R - JPvelo re. Reed Speed event
» Reed Speed Roll Call!
» Reed Speed Results!
» Reed Speed prizes and raffle.
» Mark’s Reed Speed Failures
