muffle/exhaust 049 Cox_ba12
muffle/exhaust 049 Pixel
by Ken Cook Today at 3:23 am
muffle/exhaust 049 Empty
muffle/exhaust 049
Wanted muffle/exhaust 049
Post  robot797 Sun Feb 01, 2015 12:43 pm
hello
who has a exaust for me
i am working on a little cox diesel generator
but i realy would like for the oil to be collected in one place
so does anybody have a exhaus/muffler that allows me to reroute the oil and fumes
(the firsth one on this page would be the bomb http://www.mh-aerotools.de/airfoils/cox_3rdparty.htm)
robot797
robot797
Wanted Re: muffle/exhaust 049
Post  roddie Sun Feb 01, 2015 6:34 pm
robot797 wrote:hello
PM sent to you
Post  robot797 Mon Feb 02, 2015 2:51 pm
not found yet
robot797
robot797
Post  ian1954 Mon Feb 02, 2015 5:11 pm
It sounds like a nice project but I think, the link doesn't work for me, that you are referring to the Hiscott muffler. This is a rare item and, if you find one, will not be cheap. It was designed to be installed on the Cox Medallion 049
The only alternative I can think of would be
http://www.google.co.uk/imgres?imgurl=http://www.densmodelsupplies.co.uk/media/uploads/muffler_1292270355.JPG&imgrefurl=http://densmodelsupplies.co.uk/digest.php?view%3D35%26active_page%3D1&h=534&w=400&tbnid=2XBnnu9wfrouJM:&zoom=1&docid=zGne7Izl901oLM&ei=UAPQVOyrEMreao6HgMAG&tbm=isch&ved=0CCEQMygAMAA
or this and add a homemade muffler
http://www.google.co.uk/imgres?imgurl=https://i.servimg.com/u/f49/17/19/84/93/imag0514.jpg&imgrefurl=https://www.coxengineforum.com/t1195-wanted-muffler-for-049&h=475&w=800&tbnid=g-inxp2knAokgM:&zoom=1&docid=bWanm5zDGFNPbM&ei=4QHQVOmXMsbvaueXglg&tbm=isch&ved=0CC4QMygmMCY4ZA
These (if you are using a TD) may also need a spacer on the venturi.)
Which Cox engine have you dieselised?
ian1954
ian1954
Post  robot797 Mon Feb 02, 2015 5:18 pm
i have a custom sure start diesel with heavy duty crankshaft
i have both exausts you show
but they but have problems
the 1sth one leaks becaus of the throttle ring
i can weld this shut but then i have to enlarge the opening to keep a good flow
the second is just sheit
i have no good words for it Razz
and about the link your right the ) should be removed
robot797
robot797
Post  Oldenginerod Mon Feb 02, 2015 5:22 pm
Ian.  The original link just requires the ")" to be dropped from the end to work.  I wonder whether a Cox exhaust collector could be used as a manifold to direct the exhaust into a "catch-can" type muffler.
muffle/exhaust 049 Pictur12
These are pretty common & easy to find.  Ex Model Engines generally has them but they're currently out of stock.  The priming hole would need to be plugged, but a pipe could easily be attached to the outlet.
Post  Oldenginerod Mon Feb 02, 2015 5:24 pm
Sorry, Robot797 posted as I was. If you're using a throttle ring then forget my suggestion.
Post  robot797 Mon Feb 02, 2015 5:26 pm
that is the point i dont want to have a trothle ring
but this exaust has one
i also have one of those and i actualy do not want to modifie it (becaus it was expencive)
robot797
robot797
Post  roddie Mon Feb 02, 2015 5:39 pm
2nd PM sent.
Post  akjgardner Mon Feb 02, 2015 6:20 pm
hey,I just saw one on ebay for ten bucks.I just typed cox engines.
Post  ian1954 Mon Feb 02, 2015 6:31 pm
There is always the Tatone muffler
muffle/exhaust 049 Tatone10
ian1954
ian1954
Post  roddie Mon Feb 02, 2015 6:34 pm
Question: Do dieselized Cox engines with SPI cylinders suffer from the use of a muffler, like the glow ignition engines do?
Post  ian1954 Tue Feb 03, 2015 6:24 am
roddie wrote:Question: Do dieselized Cox engines with SPI cylinders suffer from the use of a muffler, like the glow ignition engines do?
They do and for exactly the same reasons.
It also depends on what you call "suffering" - I have engines that were designed for use with a silencer and that silencer was developed with the engine. Some of these engines don't throttle happily without the silencer/muffler attached.
The introduction of the requirement for silencers killed the performance of many engines. SPI or not, added weight and ruined a previously perfect engine/model combination.
The Cox wrap around mufflers are not great and I have never been an advocate of throttling by restricting the exhaust.
If you are happy with reduced performance, for SPI and non SPI, the engine can still be set to run at a single speed. Throttling and SPI can be unsuccessful.
The addition of a diesel head to a Cox engine also brings additional problems. It also needs the venturi reducing or it glugs diesel like I drink beer. They run rich and this also compounds SPI and muffler issues.
In the strictest sense the Cox muffllers produced for the Bees don't muffle enough. They are still too noisy for such small engines to be allowed at most flying fields in the UK.
The Cox RC .05, .09 and the Queen Bee are passable. By far the best is the Hiscott/medallion 049 combination. All have no SPI.
ian1954
ian1954
Post  roddie Tue Feb 03, 2015 6:58 am
Thanks Ian. You've answered quite a few questions that I had.
Post  GallopingGhostler Tue Feb 03, 2015 7:14 am
ian1954 wrote:There is always the Tatone muffler
Ian, I have one of those, bought it in the 1970's. I wasn't too happy with it as it was restrictive enough to reduce power significantly. I think the legacy Cox car engine muffler (photo provided by Rod) would have the same effect.
The annular ring Cox muffler isn't as restrictive, although it does cut some top end off.
Bernie's got an aftermarket he's designed and selling, which is reasonably priced:
http://coxengines.ca/cox-.049-muffler.html
muffle/exhaust 049 049%20Muffler%201
Post  Surfer_kris Tue Feb 03, 2015 8:15 am
There is a discussion here about muffler and Sure starts on diesel; RCU
Seems the already feeble Sure start engine will lose most of it's power....
A dedicated diesel, with muffler, would be much better to work with, such as the MP Jet .061 or one of the PAW engines (mufflers are optional for their smaller engines)
Surfer_kris
Surfer_kris
Post  robot797 Tue Feb 03, 2015 11:27 am
that is one nice exhaust
the reason why i want an exhaust is becaus i want the fumes and oil to be collected in a diverent spot instead of the whole generator
robot797
robot797
Post  GallopingGhostler Tue Feb 03, 2015 11:50 am
Surfer_kris wrote:There is a discussion here about muffler and Sure starts on diesel;
RCU
Yes and no. Yes, it will lose some top end, depending on the muffler and amount of silencing required. In the video, I noticed the modeler was testing the engine, which had SPI. Cox made silenced engines had no SPI, to prevent dilution of the intake gases with inert exhaust gases.
The aftermarket Tatone muffler was more restrictive. I only used it a short time because of that.
Mufflers are a fact of life in many places nowadays. In that case, one then chooses their power needs. A muffled reed valve engine may be more appropriate on slightly smaller airframes/lighter airframes that can get by with less power. It's all about matching the available power to the right airframe.
Post  Surfer_kris Tue Feb 03, 2015 2:00 pm
Yes, I'm aware of that and I do have mufflers on all my engines.
I thought the link on RCU would be instructional in terms of the power, and power loss, one can have.
In the early 80-ties I made my own mufflers for cox engines. The trick is to have a large volume and no restriction right at the exhaust port. Plus no SPI of coarse.
muffle/exhaust 049 Cos_be10
Surfer_kris
Surfer_kris
Post  robot797 Tue Feb 03, 2015 2:05 pm
even that type of exauhst would fit my need Smile
robot797
robot797
Post  GallopingGhostler Tue Feb 03, 2015 2:26 pm
Surfer_kris wrote:Yes, I'm aware of that and I do have mufflers on all my engines.
I thought the link on RCU would be instructional in terms of the power, and power loss, one can have. In the early 80-ties I made my own mufflers for cox engines. The trick is to have a large volume and no restriction right at the exhaust port. Plus no SPI of course.
Wow, Surfer_kris, that is quite an engineering feat you have there! I call that 1) determination, 2) hardwork, and 3) success! Thumbs Up
Post  ian1954 Tue Feb 03, 2015 4:45 pm
There is the cheap and cheerful way. Take a piece of aluminium tube, slice out a section in the middle, bend it around the cylinder and hold it tight with a nut and bolt.
muffle/exhaust 049 Roddie14
Not quite but it does direct the exhaust! This was a standard muffler for DC engines.
ian1954
ian1954
Post  robot797 Wed Feb 04, 2015 11:44 am
that is awsome
that is whet i will try
robot797
robot797
Post  Surfer_kris Wed Feb 04, 2015 1:46 pm
That trick doesn't work on cox engines as the ports are larger/longer. You will not be able to seal the rear part, unless you use more than just the tube in that area.
Surfer_kris
Surfer_kris
Post  robot797 Wed Feb 04, 2015 3:30 pm
ah crap that is to bad
robot797
robot797
