pee wee .020 identification help needed. Cox_ba12
pee wee .020 identification help needed. Pixel
pee wee .020 identification help needed. Empty
pee wee .020 identification help needed. Empty pee wee .020 identification help needed.
Post  nemoskull Thu Dec 01, 2011 6:14 pm
so i got a 'thimble drome' froma friend a long time ago. taking calipers, it measures.337 inch, or 9.26mm O.D. below the fins. there is no cut out for the tool to remove the cylinder.
i got off ebay a pee wee .020 that is claimed to be from the 70's, the cylinder measures 10.5mm or .410 inch. the parts are interchangable.
buy i am wondering, why the thinner walled cylinder?
when was this one made?
nemoskull
nemoskull
Silver Member
Silver Member
pee wee .020 identification help needed. Empty Re: pee wee .020 identification help needed.
Post  nitroairplane Thu Dec 01, 2011 6:16 pm
The thinner wall was on earlier engines I will have to check for dates.
nitroairplane
nitroairplane
Post  nemoskull Thu Dec 01, 2011 6:21 pm
that would be cool.
have you heard of any problem with strength on the thinner walled cylinders?
nemoskull
nemoskull
Silver Member
Silver Member
pee wee .020 identification help needed. Empty Q
Post  Jaspur_x Thu Dec 01, 2011 6:45 pm
is it the truly thin walled cylinder you are asking about, or the one with portion below the exhaust ports shaved down for weight savings(thats what I was old the reason for cutting down was)
I am not very certain on years about this matter,however my 1978 cox radio controlled cub came with a peewee020,(natural aluminum colored tank) that had the relief cut below the exhaust ports.
Meanwhile, I have a teedee, AND a (red tank)peewee that I bought new in the late 80`s both have the "uncut" cylinders
I will have to look over my "stash" of peewee`s &teedee`s to see which has what and what timeframe they are from.
Jaspur_x
Jaspur_x
Banned
Post  Admin Thu Dec 01, 2011 6:55 pm
I could probably help you out a lot more if you can show me a picture or link me to the eBay auction page (if it has a picture on it).
If you don't have a picture then please answer the following...
1) Does it have a tank or a backplate that requires an external fuel tank?
If it has a backplate that requires an external fuel tank, skip to question #7
2) If it does have a tank, is it plastic or metal? If the tank is plastic (it is very well most likely a TD .020 - if it is metal, then it will be a Pee Wee)
3) What color is the tank? Red or Silver?
4) Does the tank backplate say COX on the back of it?
5) Does the tank say "THIMBLE DROME" around it?
6) Does the tank have 1 or 2 filler tubes on the backplate?
7) What color is the driveplate? Red or Silver?
8 ) Is the driveplate round or hex shaped?
9) Is the crankcase neck straight or curved (thicker near the cylinder and thinner near the driveplate?
10) Choose the cylinder that looks like yours (look closely at the design, not condition or color of the cylinders in the pictures):
A:pee wee .020 identification help needed. Cylind10 This cylinder was used from 1957 to about 1968?-1970?
B:pee wee .020 identification help needed. Cylind11 Used between 1977? to about 1982?
C:pee wee .020 identification help needed. Cylind12 This cylinder was used from 1968?-1970? to about 1977?. Cylinder "B" was used until this cylinder was brought back around 1983? to the end of production in 2005.
(the dating for the cylinder types may be off by a few years, if someone (hint hint: Mud) could correct these dates for me, that would be great!)
11) Does the engine have a throttle ring on the cylinder? If it does then it is most likely a R/C Pee Wee made between 1983 and 1995-96. The throttle ring could have been added as a part somewhere down the line.
I hope I have asked all the questions for me to be able to picture the engine in my mind and to help you out with dating and information.
Post  nemoskull Thu Dec 01, 2011 7:20 pm
its pictuer A
red metal tank, says 'thimble drome'
crankcase 'neck' has a curve to it.
nemoskull
nemoskull
Silver Member
Silver Member
Post  Admin Thu Dec 01, 2011 8:02 pm
nemoskull wrote:its pictuer A
I would say it is from the 60s, it sounds like a 60s engine with the Thimble Drome on the tank, thin neck and the thin cylinder.
Post  nemoskull Thu Dec 01, 2011 8:05 pm
yay!
you know, its kinda wierd holding something in my hands that was new and in the air when my grandmother was chasing her small kids around the yard......
nemoskull
nemoskull
Silver Member
Silver Member
pee wee .020 identification help needed. Empty initial findings
Post  Jaspur_x Thu Dec 01, 2011 8:10 pm
My radio comtrolled cub trainer/s peewee engines are a 50/50 mix of both B & c(pictured) i was given the timeline or 1978 on my most recent purchase of these. The ones without relief cuts had a metal ring around them,that looks like a portion of a chrome plated hose clamp, the others with relief cutouts do not.
Admin`s timeline dates your thimble drome model as a good bit older than any of mine for certain, now I want one lol!
Jaspur_x
Jaspur_x
Banned
Post  nemoskull Thu Dec 01, 2011 8:19 pm
i decide to get rid of it. it needs a piston reset BADLY. but seems pretty good otherwise. glow plug is coil type, not W style. it works.
you want it?
nemoskull
nemoskull
Silver Member
Silver Member
Post  Mark Boesen Fri Dec 02, 2011 12:37 am
my $.02
1956 to 1970+/-
Thick wall 1975-79
Stepped cylinder from 1971+/- to 1975
Post  Admin Fri Dec 02, 2011 2:47 am
Mark Boesen wrote:my $.02
1956 to 1970+/-
Thick wall 1975-79
The stepped cylinders I know were used all the way up to the last Pee Wees produced by Estes.
Post  Admin Fri Dec 02, 2011 2:56 am
nemoskull wrote:i decide to get rid of it. it needs a piston reset BADLY. but seems pretty good otherwise. glow plug is coil type, not W style. it works.
you want it?
Get a reset tool! You can never have too many tools! http://coxengines.ca/product.php?productid=366&cat=41&page=1 You can always list the engine in the For Sale/Wanted section, there is always someone looking for some parts especially the backplates. On just about every RC forum, there is someone looking for Pee Wee backplates.
Post  nemoskull Fri Dec 02, 2011 5:19 am
why the backplates?
nemoskull
nemoskull
Silver Member
Silver Member
Post  Cribbs74 Fri Dec 02, 2011 8:02 am
nemoskull wrote:why the backplates?
They are not sold anywhere and do not show up on ebay often. The biggest reason though is that the mounting tabs are prone to cracking and falling off due to their thin wall construction.
Post  nemoskull Fri Dec 02, 2011 9:57 pm
oh, i can see how a metal backplate would be a good thing.
nemoskull
nemoskull
Silver Member
Silver Member
Post  microflitedude Fri Dec 02, 2011 10:02 pm
I would love it if Bernie or Matt would start producing nylon .020 backplates.
Add that to the enormous wish list. Very Happy
microflitedude
microflitedude
Post  Jason_WI Fri Dec 02, 2011 10:33 pm
With tooling costs and minimum production runs yoiu looking at $15k to $20k for the one part. And that is sourced in China. That's a boat load of backplates you have to sell to pay for the NRE costs.
Jason_WI
Jason_WI
Post  nemoskull Sat Dec 03, 2011 3:42 am
well, i figure if we spread the .020 love enough, people will want it, then it will be proftiable to produce them. personally, i think there is an entire generation that has no idea of the fun of 1/2A, and the .020 over looked in the past as 'too small' by current UM Parkzone standards, is wonderful. the noise and the poison methanol is the only draw backs. but then again, people drive car and use posionous gasoline into them.
nemoskull
nemoskull
Silver Member
Silver Member
Post  nitroairplane Sat Dec 03, 2011 6:01 am
nemoskull wrote:well, i figure if we spread the .020 love enough, people will want it, then it will be proftiable to produce them. personally, i think there is an entire generation that has no idea of the fun of 1/2A, and the .020 over looked in the past as 'too small' by current UM Parkzone standards, is wonderful. the noise and the poison methanol is the only draw backs. but then again, people drive car and use posionous gasoline into them.
Thats what i said but when you think about it if they were to re make even the surestart it would retail for about $40 and thats the cheapest one.
nitroairplane
nitroairplane
Post  microflitedude Sat Dec 03, 2011 9:03 am
Which may become feasible as Bernie and Matt's raw stock dry up.
microflitedude
microflitedude
Post  nitroairplane Sat Dec 03, 2011 9:05 am
Getting a surestart made?
Yes i think it would be.
nitroairplane
nitroairplane
