049 medallion crank & hub
cox 049 medallion crank and hub
Re: 049 medallion crank & hub
Bernie:
http://coxengines.ca/cox-.049-medallion-crank.html
http://coxengines.ca/cox-.049-drive-plate-tee-dee.html
Matt has TeeDee cranks:
http://www.exmodelengines.com/product.php?productid=17605&cat=266&page=1
Just making sure you looked.
for some stupid reason no I did not look at retailers , my neck was hurting from reading and I guess I had a brain well u know Thanks as always
There are several people who would rather deal with disused parts from other people, instead of buying new parts. I get the "recycle, reduce, reuse" part of that mentality...
Thanks Phil ; I have been looking for the correct way to take apart and reassemble the medallion and cat find it I know or think I have seen this somewere but I cant find it ... I am wanting to drill out the pressure port . If you can help I think you in advance I ll keep looking
crankbndr- Top Poster
http://coxengines.ca/engine-and-fuel-guides.html
The original instructions are here.
I have taken a couple TeeDee's apart by using a cox wrench on the collet to push the drive plate off. Use a stud and spinner with a prop to reassemble being careful to fit the drive plate into the original splines.
If it doesn't go easily, STOP. Soak in some kind of lubricant (fuel?) to penetrate. Maybe use some heat from a blow dryer if it is clean and lubricated (Make sure no fuel is present!) and heat the drive plate without heating the rest of the engine.
man its just been one of those day things that goes for more than one Thanks Phil & Crankbndr , that was were I seen the Info
I do have one, I bought it here. I'd sell it for the same price.
» TD crank in Medallion case
» .049 Medallion crank shaft
» Tee Dee crank
» I found 2 09 medallion crank shafts I put them up on ebay
» Wanted: Tee Dee .049 crank case and crank
» Tee Dee crank
