Shrike Instructions Cox_ba12
Shrike Instructions Pixel
by sosam117 Today at 10:25 am
by rdw777 Today at 9:17 am
Shrike Instructions Empty
Shrike Instructions
Shrike Instructions Empty Shrike Instructions
Post  WingingIt74 Mon Jan 27, 2014 11:06 am
Anyone have a copy of the instructions? How do you make the pivot point that they circle around?
WingingIt74
WingingIt74
Shrike Instructions Empty Re: Shrike Instructions
Post  craig bernard Tue Jan 28, 2014 7:54 pm
I beleive you just use a nail about 3 inches long and drive it in the pavement with string attached to your shrike! But i am not an expert its what Ive heard never owned one.
craig bernard
craig bernard
Post  roddie Tue Jan 28, 2014 9:55 pm
Hey Travis, If I had a small tether-car (and no instructions..) I would cut a circular pc. of 1/2" plywood (about the size of a 5 gal. bucket lid) and attach a 3" long hardwood dowel (broomstick diameter) on end in the center (using a wood-screw from the bottom).. Drive x4 equally-spaced 3/4" long drywall screws "down" through the plywood.. about one inch from the edge.. so that they protrude 1/4" through the bottom of the plywood. Use a 10 lb. dumbbell weight-plate over the dowel.. and attach a suitable hook/ring with retainer on top of the dowel for the tether-line. The 4 screws will "bite" into asphalt with the weight of the dumbbell. This way.. you won't damage any pavement... and it "should" be adequate weight to hold the base from moving, while the car is screaming around the circle!  Affraid or WOW!  ... and it's a quick/go-anywhere set-up.
I will clarify if needed.. just ask!
Roddie
Post  WingingIt74 Wed Jan 29, 2014 7:26 am
good idea....
WingingIt74
WingingIt74
Post  ekitten2 Wed Jan 29, 2014 4:20 pm
i totaly made my own pivit point
i posted ina thread some time about this very subject but no one knew/replyed...even about the line lenth...nothin so i went with my own thoughts
Shrike Instructions Pict0024
i simply drilled the matching holes in bitcumen an epoxyed plastic masionry plugs in
ekitten2
ekitten2
Post  ekitten2 Wed Jan 29, 2014 4:23 pm
oops this is what the second one should have been sorry
Shrike Instructions Pict0026
ekitten2
ekitten2
Post  ekitten2 Wed Jan 29, 2014 4:27 pm
i hope it helps
ekitten2
ekitten2
Post  WingingIt74 Wed Jan 29, 2014 4:35 pm
Thanks! What do you attach it to?
WingingIt74
WingingIt74
Post  ekitten2 Wed Jan 29, 2014 10:20 pm
i simply use some braided stainless steel control line wire (i had some old stuff handy) hence the use of those scissor clips oh an i use 3 meter length (about 10 feet)
ekitten2
ekitten2
Post  roddie Wed Jan 29, 2014 10:28 pm
ekitten2 wrote:i simply use some braided stainless steel control line wire (i had some old stuff handy)  hence the use of those scissor clips oh  an  i use 3 meter length (about 10 feet)
I think that "Travis" (and myself..) are questioning what you use as a "base"... (size/weight etc..)
Thanks,
Roddie
Post  ekitten2 Wed Jan 29, 2014 10:50 pm
well it is screwed to the pavement via 3 plastic masiony plugs...its as it was on my recent video (in anouther thread)
ekitten2
ekitten2
Post  roddie Wed Jan 29, 2014 10:59 pm
Travis, here is some cool stuff to read about. It explains how a regulation "center-post" must be constructed... although; for "your" purposes... it's not necessary to build one that strong.
http://www.tethercars.com/technical-regulations/
Roddie
Shrike Instructions Empty re: Shrike Instructions
Post  happydad Sat May 03, 2014 8:29 pm
WingingIt74 wrote:Anyone have a copy of the instructions?  How do you make the pivot point that they circle around?
Travis: did you ever find the Shrike Instructions? I just won a red plastic Shrike on ebay. I will refurbish to resell.
edited 5-3-2014 6;35P.M. PST I found a sheet on the Shrike. PM me if you need it as I am not sure I can publish the link.
happydad
 RC Plane Futaba Radio RC Plane
Last edited by happydad on Sat May 03, 2014 8:35 pm; edited 1 time in total (Reason for editing : edited to add link to .pdf file for Shrike)
happydad
happydad
Post  WingingIt74 Sat May 03, 2014 10:36 pm
I don't think I did.
WingingIt74
WingingIt74
