Encased in carbonite! - Page 2 Cox_ba12
Encased in carbonite! - Page 2 Pixel
Encased in carbonite! - Page 2 Empty
Encased in carbonite! - Page 2 Empty Re: Encased in carbonite!
Post  pkrankow Wed Jul 17, 2013 11:47 am
It looks like you could have sawed off more...but the picture could be misleading because these engines are so small.
I was flat shocked holding a .049 teedee next to a stunt tanked reedie. The teedee is tiny, but really it is comparing the tank to a lack of tank in that case.
Post  sdjjadk Wed Jul 17, 2013 7:13 pm
dinsdale wrote:Acetone won't have any ill effect at all on the metal.  It'll probably eat any plastic bits though, and might effect any "O" rings.
Luckily, Bernie sells replacement parts. I'll be watching this. Popcorn
sdjjadk
sdjjadk
Post  Jason_WI Wed Jul 17, 2013 7:47 pm
The only replacement parts might just be a carb body of which I have a couple of spares. The entire bottom of the crankcase is exposed and 3/4 of the venturi. Just one glob stuck around the cylinder yet.
I changed the acetone as the old stuff looked like ghostbusters slime!
Jason_WI
Jason_WI
Post  sdjjadk Wed Jul 17, 2013 8:36 pm
Jason_WI wrote:The only replacement parts might just be a carb body of which I have a couple of spares. The entire bottom of the crankcase is exposed and 3/4 of the venturi. Just one glob stuck around the cylinder yet.
sdjjadk
sdjjadk
Post  WingingIt74 Fri Jul 26, 2013 8:32 am
Any update?
WingingIt74
WingingIt74
Post  Jason_WI Thu Aug 08, 2013 11:17 pm
Freed from the carbonite tomb.
Encased in carbonite! - Page 2 8d7f4d55bab7b830214a59629f29bcd1_zps3bf54aa8
Jason_WI
Jason_WI
Post  pkrankow Thu Aug 08, 2013 11:19 pm
Pretty! Have you run it yet?
Post  Jason_WI Thu Aug 08, 2013 11:25 pm
pkrankow wrote:Pretty!  Have you run it yet?
Not yet but soon. I'll post a video
Jason_WI
Jason_WI
Post  RknRusty Fri Aug 09, 2013 12:13 am
Are the innards clean?
Post  Jason_WI Fri Aug 09, 2013 12:22 am
Spotless. None of the resin was in the crankcase.
Jason_WI
Jason_WI
Post  RknRusty Fri Aug 09, 2013 4:03 am
What a beauty, I'm glad you liberated it.
Post  sdjjadk Fri Aug 09, 2013 8:59 pm
Sweeeet! Looks like a new engine.
sdjjadk
sdjjadk
Post  Cribbs74 Fri Aug 09, 2013 11:06 pm
For some reason I can't see the whole picture. Just the top half. I assume it looks good judging by the comments. Let's hope it runs well! Good job Jason.
Post  Jason_WI Wed Aug 14, 2013 9:16 pm
Tried for an hour tonight to get this engine to run. Mad  Changed glow head, NVA and the fuel. Would pop and run backwards as if it was flooded. It wasn't flooded. I took it totally apart tonight and looking at the crank the crank pin is on the wrong side of the intake port. The carbonite engine has a right hand crank (clockwise) installed! No wonder it always wanted to run backwards. I don't have any reverse pitch props so I will swap out the crank and retry tomorrow.
Jason_WI
Jason_WI
Post  duke.johnson Wed Aug 14, 2013 9:44 pm
Reverse rotation engines are great for keeping the lines tight. I have a couple Wiley .36 carrier engines like that.
duke.johnson
duke.johnson
Post  pkrankow Wed Aug 14, 2013 10:01 pm
Pair it up with a regular rotation and go RC twin!
Post  Cribbs74 Wed Aug 14, 2013 10:31 pm
What are the odds of that? I have never seen one of those funny cranks. I guess when you have a billion engines you are bound to run across a few.Wink
Post  Jason_WI Wed Aug 14, 2013 10:41 pm
Cribbs74 wrote:What are the odds of that? I have never seen one of those funny cranks. I guess when you have a billion engines you are bound to run across a few.Wink
I don't think Cox made a billion engines. lol! I do have my fair share though.
The spare crank I have is the later thicker crank web version for the later engines and this is an early crankcase..... DAMMIT!
Jason_WI
Jason_WI
Post  WingingIt74 Thu Aug 15, 2013 7:42 am
Flip a standard prop around and make it a pusher Smile
Randy's F-15 (sister plane to his Mig that Jeremy converted to electric) is set up like that with a RR-TD.
I may have a crank, I'll look tonight.
WingingIt74
WingingIt74
Post  Cribbs74 Thu Aug 15, 2013 10:04 am
I have several pusher props if needed. I have no use for them.
Post  Jason_WI Thu Aug 15, 2013 8:09 pm
It runs and the right way now. Too dark for a tach and the sound cut out on the phone for some reason.
Jason_WI
Jason_WI
Post  Cribbs74 Thu Aug 15, 2013 10:40 pm
Sounds strong.
Post  kpriddle Fri Aug 16, 2013 11:49 am
That engine does sound strong!  A great accomplishment for sure. Smile
KP
kpriddle
kpriddle
Bronze Member
Bronze Member
Post  Admin Fri Aug 16, 2013 12:37 pm
cheers IT RUNS!
Post  microflitedude Fri Aug 16, 2013 1:28 pm
That's amazing. Well done!
microflitedude
microflitedude
