Encased in carbonite!
Page 1 of 3
Page 1 of 3 • 1, 2, 3
Picked this up today. Not too bad of a price. Was there one company doing these as I have seen them before on eBay.
http://www.rcgroups.com/forums/showthread.php?t=1920243
Jason_WI- Top Poster
Re: Encased in carbonite!
You need to affix a little hammer to it along with a sign that reads "Break in case of emergency"
cribbs74 wrote:You need to affix a little hammer to it along with a sign that reads "Break in case of emergency"
THAT is a great idea!
Nooooooooo!!!!!!!
The Traumatized Mark
batjac- Diamond Member
Piston is at TDC, good chance it survived the freezing process.
Set it free Jason!
Engines looks just as good in air as they do in a block of plastic.
Man! Bet you gonna' catch heck trying ta' hand crank this one!! L.O.L.!!
Propaplace- Moderate Poster
These things have always kinda creeped me out.
Don't ever wanna see a Venom like that.
dckrsn- Diamond Member
That's neat. But why would someone do that to what looks like a perfectly good Tee Dee?
And I second the "Break In Case Of Emergency" sign.
sdjjadk- Platinum Member
Hopefully the crank port wasn't open when they poured the resin.pkrankow wrote:Piston is at TDC, good chance it survived the freezing process.
It will not be removed. Will make a good conversation piece. I bet one could remove it if needed without destroying it. The carb body might be the only casualty.
nitroairplane wrote:Set it free Jason!
I agree, in fact they look better! Plus you can put the spinner on it.
Claim the engine shown is encased in Krytonite from Superman's home planet and watch the value soar on Flea-bay.
SD
SD
SuperDave- Rest In Peace
The more I look at this the more I want to set it free and run it. The pour job was poorly done and the cube is more like a parallelgram. The NV is crooked which looks bad anyway.
I have looked and liquid nitrogen can freeze, hit it with a hammer and it will break open. Acetone will also dissolve the lucite.
Any suggestions?
Any suggestions?
I can't remember/don't know what type of resin that is, likely a polyester?
I do remember DIY hobby kits you could buy to do this with that were popular in the 70's, likely what this is...some kid probably did it over Christmas vacation.
I'd saw off as much excess as you could and plunk it in a jar of Acetone and let it set for several days, done!
+1 on that. That'll clean it inside and out. Even if you bust it out, it'll probably still need an acetone soak.Mark Boesen wrote:...I'd saw off as much excess as you could and plunk it in a jar of Acetone and let it set for several days, done!
Definitely saw it first, this will save acetone. Be careful, the refraction is going to mess you up while cutting, so take it slow.
Places that do that kind of encasement may also be able to set it free (to a degree...)
Slowly melting it away. Might need more acetone. Should be done in a few days. Then fire it up. What a gooey mess.
It only took the princess just a few seconds to remove the carbonite from Han Solo...
Looking forward to seeing it run, I wonder how far into the case that stuff seeped in to.
Probably seeped into the crankcase. It will take some time to get it all cleaned out. Acetone is some nasty stuff.
Acetone won't have any ill effect at all on the metal. It'll probably eat any plastic bits though, and might effect any "O" rings.
If you get a 5 gallon bucket and a chemical pump, flowing acetone will probably eat it away quicker. Magnetic mixer would work too.
Page 1 of 3
