McCoy Duro-Glo .049 Diesel Cox_ba12
McCoy Duro-Glo .049 Diesel Pixel
by KariFS Today at 1:56 pm
by bsadonkill Today at 11:31 am
by MauricioB Today at 10:49 am
» Octura engines?
by UncleLumpy Today at 8:16 am
» Tatone EM-7
by sosam117 Today at 7:50 am
» Honoring All Who Served
by roddie Yesterday at 8:59 pm
by rsv1cox Yesterday at 3:30 pm
by TD ABUSER Yesterday at 1:41 pm
by balogh Yesterday at 1:36 pm
» K&B .09 Torpedo Engine
by LooseSpinner99 Yesterday at 12:01 pm
» 3D printing of parts?
by UncleLumpy Yesterday at 9:08 am
» L4 Grasshopper
by bottomgun Yesterday at 7:58 am
McCoy Duro-Glo .049 Diesel Empty
McCoy Duro-Glo .049 Diesel Empty McCoy Duro-Glo .049 Diesel
Post  ian1954 Fri Apr 19, 2013 7:39 pm
McCoy Duro-Glo .049 Diesel Mccoy_10
ian1954
ian1954
McCoy Duro-Glo .049 Diesel Empty Re: McCoy Duro-Glo .049 Diesel
Post  Godsey3.0 Fri Apr 19, 2013 8:30 pm
Those are neat. I have heard the cranks tend to be a bit fragile. I have the .09 Diesel version. Very nice runners.
RR
Godsey3.0
Godsey3.0
Post  ian1954 Fri Apr 19, 2013 8:44 pm
The first cranks were definitely fragile - the inlet hole was drilled and then a flat square area milled over it.
The later ones were like this - a circular milling around the hole.
McCoy Duro-Glo .049 Diesel Dura-g10
ian1954
ian1954
Post  RknRusty Fri Apr 19, 2013 10:47 pm
Godsey3.0 wrote:Those are neat. I have heard the cranks tend to be a bit fragile. I have the .09 Diesel version. Very nice runners.
RR
What planes are you flying your diesels on, and do you have any distinct preference between glow and diesel?
Post  MrGoodwreck Sat Apr 20, 2013 12:55 am
I picked one of those up a year or so back.
Paid $8.00 at a swapmeet. Looks brand new.
Now I just need to figure out an old timer FF bird to set it up for, and learn how to run one.
MrGoodwreck
MrGoodwreck
Silver Member
Silver Member
Post  ian1954 Sat Apr 20, 2013 6:50 am
RR
I haven't flown or built a glow or diesel engined plane for many years. I now only clean, restore and run the engines.
When I was able to (local bye laws now prevent this in my area!), for free flight - DC engines (Diesel and Glo but mainly diesel), control line (combat and stunt) - PAW and Oliver Tiger (All Diesel), RC (very limited experience) - Enya (All Glo). I flew control line for 16 years (pre RC affordability) then "on and off" for a further six as sites closed.
I have taken up RC again but all electric! Most of my engines are not suitable for RC and some are debatable for control line. The Duro-Glo Diesel is one of these - the angled needle valve is limiting for control line - it is not really reversable.
My preference is Diesel! The smell, the mess and the noise! Only need fuel and a finger to start it.
ian1954
ian1954
Post  Godsey3.0 Sat Apr 20, 2013 8:07 am
Currently I only have one plane with a diesel on it. It is a Sig Skyray. We flew it on a 25 La-S and got around 7 second laps. We then put on a Thunder Tiger 25 GP diesel we got 3 second laps. It flew about 5 minutes on less than two ounces of fuel. The pull was enormous. This was the only CL plane I have had that actually made my arm tired.
My first diesel flights were with a Guillows Trixter Trainer with a Marz 2.5cc Diesel. That plane could barely fly with any engine that fit. It is only good for getting rid of the dizzies. Which it did for my dad.
I much prefer diesel over glow. 1) The ease of starting. Couple flips when you know how to do it. 2) The torque. The Thunder Tiger GP swung that 10x6 at just under 11,000rpm. It swung an 11x4 at 10,000rpm. I have a PAW .15 (2.5cc) that spins a 10x6 at 8,800 rpm. Not bad for a .15 plain bearing engine. There is not much rpm difference between large props with diesels. So it seems like most generally give them larger props. But not everyone uses them for torque. 3) Diesel engines typically use less fuel. Somewhere on the Davis site there is a claim that diesel burns 1.8x more efficient. This allows for longer flights with much less fuel.
4)The last I thing I have time to type for is that smell! I absolutely love it!
I have run through gallons of fuel on the test bench. Just to see them run and hear that sound and to whiff that beautiful aroma.
Godsey3.0
Godsey3.0
Post  gcb Sat Apr 20, 2013 8:21 am
I have one each of the square and round hole cranked radial mounted .049's and a beam mounted .049 and .09. All run well (so far) except the .09. I got the .09 from an auction site and I believe it was assembled from parts. A couple of gaskets are missing. I just haven't gotten around to making them.
I understand that it is best to not under-prop them. I use 6x4 minimum for the .049.
If you have trouble with compression, the contra piston is sealed with an "O" ring.
gcb
gcb
Post  Godsey3.0 Sat Apr 20, 2013 9:04 am
I have always been interested in the .049 McCoy. The .09 I have was actually supposed to be an .049 but, the guy grabbed the wrong one. He was going to hang onto one from me. He had a box full of them. It turned good for me though. Only payed $15 for a sweet running McCoy.
RR
Godsey3.0
Godsey3.0
Post  ian1954 Sat Apr 20, 2013 9:14 am
gcb wrote:I have one each of the square and round hole cranked radial mounted .049's and a beam mounted .049 and .09. All run well (so far) except the .09. I got the .09 from an auction site and I believe it was assembled from parts. A couple of gaskets are missing. I just haven't gotten around to making them.
The Dura-Glo 049
McCoy Duro-Glo .049 Diesel Duro-g10
The 09
With the exception of PAW and COX engines - I have been trying to restrict myself to sub 049 and preferably sub .5cc.
McCoy Duro-Glo .049 Diesel 0910
ian1954
ian1954
Post  ian1954 Sat Apr 20, 2013 9:46 am
Godsey3.0 wrote:Currently I only have one plane with a diesel on it. It is a Sig Skyray. We flew it on a 25 La-S and got around 7 second laps. We then put on a Thunder Tiger 25 GP diesel we got 3 second laps. It flew about 5 minutes on less than two ounces of fuel. The pull was enormous. This was the only CL plane I have had that actually made my arm tired.
The smell, the aroma of mixing your own blend (smaller diesel engines need thinner fuel up to 40% ether) ...........
Now I am going to make you jealous
McCoy Duro-Glo .049 Diesel Diesel10
This was chauffer driven to me last week by the Rt.Hon. John Goddard (diesel beginner - despite lengthy instruction, the loan of extremely prime diesel engines - he still hasn't managed to start one!)
ian1954
ian1954
Post  Godsey3.0 Sat Apr 20, 2013 12:49 pm
Dang. Pure ether. I have to use John Deere cans or Davis Diesel. I prefer self mixing. That way I truly know what is in my fuel.
It is the druggies that made it hard to get ether here.
RR
Godsey3.0
Godsey3.0
