Question for Bernie
Question for Bernie
You said you had a set of special engine tools made up, really nice ones.
Any chance you have a picture of them someplace? I'm very curious to see them.
I always used to wonder how cox assembled the engines, especially the cylinders without leaving a scratch in the oxide coating. And, those old cylinders that had no flats, how the hell did they torque those down??
I used to hate it when no matter how careful I was, I couldn't tighten a cylinder without leaving at least a small mark in the oxide.
MeerschaumSteve- Gold Member
Re: Question for Bernie
I too want to know this!
Bump! back to the top of the latest topics panel with yee
shell shock- Gold Member
I don't really know but I would assume that they tightened the cylinder and head together by the head slots.
Motra- Gold Member
Wrenches fit in the exhaust ports typically, then they went to the double slit exhausts and relieved the top fin of the cylinder to put a wrench on.
how would they prevent burring of the exhaust slots? I damaged a babe bee cylinder like that
Bernie may correct me, but I am going to take a shot at this anyway.
Due to the design of the engine I doubt the factory assembly tools were much different than what we use currently. They were most likely a little more easy to grip on to.
If you are marring parts when assembling then either the tool fit is too sloppy or you are using too much force. Since we don't have a torque specification for these things, the best bet would be to snug parts as opposed to torquing them down. Go through your wrenches and find the ones with really good fits and use them exclusively.
Sometimes I make tool marks during dissassembly. Once the castor goo takes hold the parts like to fuse together. This can be lessened if you use heat and soaking methods. Most times I can do it without leaving a mark.
Poor wrench fit can be temporarily helped with a piece of paper or card between the wrench and the part. Cut the paper into a strip and fold the part in it, then slide the wrench over the paper. You may use several layers if it helps, but there is a limit to this. The limit usually is 2 or 3 pieces max before the paper is too thick to allow the wrench to work properly.
Soaking in fuel or denatured alcohol overnight followed by heat from a hair dryer or heat gun can really help with freeing used parts that are gummed with castor.
I would expect the factory tools were more fitted and hardened steel, like a wrench instead of a universal tool.
The screwdrivers were properly fitted to the screws, they would also be flat-sided and fill the slot entirely. This would prevent the screw from being damaged by the tool.
Finding a screwdriver that fits in this manner is not very difficult. Take a clean engine to the store and expect to pay $5 or more for a single screwdriver. If it is not a perfect fit don't buy the screwdriver. If you cannot test the fit, don't buy the screwdriver. Lowe's Kobalt brand fit pretty good.
I also recall when I was young taking apart my older brother's NIB Cox engine on his birthday with my bare hands, so they may not have even used wrenches to assemble the cylinder and glow head, expecting the customer to do this with the included wrenches. This would be the late 1980's.
I use a Craftsman 5/8" open end wrench on the cylinders with flats. It's not a perfect fit, but the closest I've found. I've been meaning to grind a smaller wrench to the right size, but haven't marred a cylinder yet, so haven't gotten around to it.
The old standard Cox wrench theoretically works perfectly for the exhaust ports. When brand new, the forks do not touch any of the inner facing. But they are weak metal and immediately spread and gall the inner face causing the burr. To prevent this, even with an old wrench, you can trap the wrench in the jaws of your vice so that the forks cannot spread(not too tight or they will bend and close). Then holding the engine upside down, slide the cylinder ports into the jaws and turn the crankcase to loosen the cylinder. With the forks trapped, they cannot spread and come in contact with the inner face of the ports to gall them.
That's a genUine Cox service dept tool.
John Goddard- Diamond Member
Any part reluctant to come free from an engine should first be soaked for a period of time then mildly heated before force is applied.
Being in a rush is the biggest source of engine damage. Once you develop PATIENCE and EXPERIENCE this all becomes standard practice.
SD
SD
SuperDave- Rest In Peace
Here are some pics of the tools we had made. Don't have my SLR camera in the office today and Blackberrys only have so much pic quality lol.
Daaayyuummm...
You ever consider offering a set like that for your greatest fans?
MeerschaumSteve wrote:Daaayyuummm...
EXACTLY!
Bernie, You should have had those mass produced! I would buy a set and I'm sure many others around here would too!
Hand-made by a local machine shop. Cost $250 / retail $495. Ain't gonna happen
Now that's a Cox tool, fits perfectly and never flexes at the wrong moment!
At near $500 a pop, I'll stick with Cox wrenches in used tandem.
Haven't damaged a Cox part in a long while either.
For a run of 100 I am sure retail price could drop to $100 but still. If we have $5,000 to spend on product it will be on less expensive items that are expected to sell in large numbers at higher margins.
I imagine anyone could take their standard tools to a machine shop and have them made as Bernie did. I also imagine you could shop around and have it done on the cheap.
We went to a local welding / machining outfit and asked for commercial grade tools. They charge $85/hr and 3 hours later we have tools that have now taken apart in excess of 20,000 engines and still going strong.
If one is in the Cox business the expense is justified long-run.
For the hobbyist however that's not the case and I believe that's evident from the money involved. Over the years I've freed up lots of parts using solvent, Cox wrenches. mild heat and PATIENCE.
So who's in a hurry anyway? Certainly no me.
SD
SD
Mudhen- Gold Member
All great advice but it seems like the original question hasn't really been answered, and I'm interested to learn this. On the new engines assembled at the factory, is a tool used to tighten the cylinder or is the cylinder and head tightened together by the head? It seems like there would be some kind of tool marks on the black oxide, especially on the early thin walled cylinders that have no wrench flats other than the exhaust ports.
Motra- Gold Member
» Cox International wish list
» The history of the Cox .049 Die Cast crankcases
» Name our new engine!
» HUGE lot of Cox items for sale!
» Great news!
» Great news!
