Build Log: Converting a 31" Super Cub to .049 Power (revisited)
Page 2 of 7
Page 2 of 7 • 1, 2, 3, 4, 5, 6, 7
Re: Build Log: Converting a 31" Super Cub to .049 Power (revisited)
Servo mounts finished. One cracked, filled the crack with epoxy and CA.
nitroairplane wrote:Cool What throws are you using?
No idea. I usually use about 60% for first flights if it's a twitchy looking plane. Tiny bit of exponential.
Hey, check this out! http://www.rcgroups.com/forums/showpost.php?p=19733293&postcount=34
I was talking about it over on RCG then somebody tried it in the larger version with a Golden Bee.
I did that to the phase 3 cub and flew the [bleep] out of it.
But is was a less flexible foam with a plastic body and it eventually became mor glue and fuel than plane.
Got the tail wheel done up. VERY pretty tail, eh?
nitroairplane wrote:steerable i presume
Correct. Doubt the little plastic wheel will do much in grass.
microflitedude wrote:nitroairplane wrote:steerable i presume
I'd be surprised if you could even take off from grass with that plane
nitroairplane wrote:microflitedude wrote:nitroairplane wrote:steerable i presume
With some smaller wheels it would do ok in a grass/sand mix. If not, we have an electric runway.
looking real good so far. can wait to see this fly!
SS
SS
shell shock- Gold Member
Well I got the throttle tube in, works great. I also ran and evaluated the motor - healthy runner. Little too much power, won't idle as low as I'd like.
Shot a video but good 'ole Youtube sucked the audio out. And we all know such videos are worthless without the engine's music.
See link ~ http://coxengineforum.forumakers.com/t566-good-day-for-me-also
Here's the new video ~
I don't think that muffler does anything.
That's a really nice idle, I didn't know they would run that slow and smooth.
RknRusty wrote:That's a really nice idle, I didn't know they would run that slow and smooth.
Nice!! Cant wait to see her in motion.
Hi shell shock we are in live chat if you want to join us.
Thanks. Some of my other engines with that throttle will idle much lower and still run good. I was having too much fun blipping it up and down.
My TP .46 is giving me more grief than this thing ever did.
It appears I have a very healthy runner. It must have been broken in properly and well cared for. (I am not the original owner) Completely airtight as it shuts down as soon as vent are plugged. I also did not use up all the fuel, so I should get some good flying times as I will be flying in low RPM.
I cut the throttle tube down to size, and crammed the receiver in back. Bought some struts that are way too big, (hobbystore closed that carried the strips) and some grommets for the servo. They conveniently did not come with the little metal inserts.
It is HEAVY. More so than i planned.
microflitedude wrote:I cut the throttle tube down to size, and crammed the receiver in back. Bought some struts that are way too big, (hobbystore closed that carried the strips) and some grommets for the servo. They conveniently did not come with the little metal inserts.
How heavy?
with a plane this size you really want under 15oz.
nitroairplane wrote:microflitedude wrote:I cut the throttle tube down to size, and crammed the receiver in back. Bought some struts that are way too big, (hobbystore closed that carried the strips) and some grommets for the servo. They conveniently did not come with the little metal inserts.
How heavy?
10.1 oz. Not counted some extra dabs of glue and fuel.
That should be exiting
That would fly with pee wee .020 so the black widow may be 3D.
nitroairplane wrote:That should be exiting
I probably would have if I had one.
I made a rock solid strut system. Looks ugly and needs refining, but I am not known for building pretty airplanes.
Another question to decide - Should I use a 72mhz radio without rates and expo? Or should I wait and order a JR 2.4? I have a 2.4 parkflier RX, not sure how much I would trust it on a plane with an engine.... :?:
Somebody said, "If you wouldn't fly yourself in the airplane, bring it back in the pits and fix it"
Folks have flown 72 MHz for years without problem. Actually, one of my 1/2A installations is 72MHz AM and it works just fine. I would not worry about the radio at all - just install, range test it and fly.
» Lil satan build, cant decide on a power plant
» Super Satan build
» Cox Super Power Fuel
» Super Clown racing build
» Super mouse build thread
» Super Satan build
Page 2 of 7
