Cox katydid arf build Cox_ba12
Cox katydid arf build Pixel
by batjac Today at 10:05 pm
by gkamysz Today at 9:29 pm
by roddie Today at 9:22 pm
Cox katydid arf build Empty
Cox katydid arf build Empty Cox katydid arf build
Post  mitchg95 Sat Dec 22, 2012 7:36 pm
Cox katydid arf build 78NRT
I have had this plane for over a year now, and it is finally time to actually do some work on it
so far what i have done is attach the elevator, rudder and glue the two wing halves together
please feel free to give tips on how you might go about finishing a plane
P.s. im going with out l.g's because I have a perfect grass feild by my house that I intend to fly in
thanks
mitchg95
mitchg95
Cox katydid arf build Empty Re: Cox katydid arf build
Post  Cribbs74 Sat Dec 22, 2012 8:05 pm
Put an engine in it. Plumb it with electrics and go fly.
I like your T-Shirt!
What did you want to know specifically?
Post  mitchg95 Sat Dec 22, 2012 8:10 pm
cribbs74 wrote:Put an engine in it. Plumb it with electrics and go fly.
thanks for the compliment on the shirt Smile
im buying at engine from happy dad for the plane, i probably do have the electronic's that i need but i will have to look as i have not checked my supply in a while
I was wondering if there are any special considerations that I should take when I am building, and how it flies.
It says on the box that AUW should be around 24oz which is on the heavy side of what i want to get this thing to way, i assume they were using standard size servo's and i could probably save a few ounces by using servos that way around 9grams, but with a wingspan of 42'' should i use 9g servos?
mitchg95
mitchg95
Cox katydid arf build Empty re: servos
Post  happydad Sat Dec 22, 2012 11:38 pm
based on the size of the rudder and elevator surfaces i would use something in between the 9gram and standard servos. they used to have one called a bantam midget i used for wings, etc. up to 36inches. and a 72inch wing plane would require standard servos or heavy duty steel geared servos.
it all depends on what you will be doing with the plane. if you try to do loops and aerobatics you would NOT want your servo to stall or quit on you. Two Cents happydad Small Cox Logo
RC Plane Futaba Radio RC Plane
happydad
happydad
Post  mitchg95 Sat Dec 22, 2012 11:41 pm
thanks for the input, with me loops and other basic aerobatics is going to happen, i will opt for standard servos then
mitchg95
mitchg95
Post  Surfer_kris Sun Dec 23, 2012 1:58 am
Well, at 24oz you will not be doing much aerobatics with an engine that pulls about 12oz. I think you started of correctly, you do need to keep the weight down. The load on the servos comes from the size of the rudder surfaces and the speed of you plane, and you do not need standard servos that are usually used with .40 sized engines.
The HS-65HB has carbonite gear and will take any beating you can give it (in the air). Use only lightweight stuff, tank and batteries etc are also important, and you will be rewarded with a lightweight well flying plane.
Surfer_kris
Surfer_kris
Post  Jason_WI Sun Dec 23, 2012 2:09 am
Hextronix 9 gram should work from Hobby king. Value hobby has the power HD servos that are supposed to be good also. They have some metal gear 9 gram servos.
Jason_WI
Jason_WI
Post  mitchg95 Sun Dec 23, 2012 3:21 am
Surfer_kris wrote:Well, at 24oz you will not be doing much aerobatics with an engine that pulls about 12oz. I think you started of correctly, you do need to keep the weight down. The load on the servos comes from the size of the rudder surfaces and the speed of you plane, and you do not need standard servos that are usually used with .40 sized engines.
i think i have a hs-65hb, I will have to check
thanks
mitchg95
mitchg95
Post  John Goddard Sun Dec 23, 2012 4:18 am
Ditto the Hitecs.
I use them in all my lekky aerobats albeit the
MG's.
In my Old Timer (55 in 26oz) I use no name nines
No problems so far. IMO the place to save weight is
The battery I use a 150mah in mine (8 grams) if you're
Using 3 servos you could use a 210mah which are about 15 grams.
You can get them on Fleabay for a few bucks.
Very Happy
John Goddard
John Goddard
Post  mitchg95 Tue Dec 25, 2012 12:39 am
i have not gotten much done to the plane over the past day, been mainly working on my dirtbike just maintaining it Smile
the things that i have gotten done, i cut the servo mount strips down to size
i have a hs55 servo, which is all plastic gear, is there much price difference between the hs 65 and the 55?
mitchg95
mitchg95
Post  John Goddard Tue Dec 25, 2012 4:30 am
If you're intent on using it Mitch it'll be
Ok although I'd leave it off the elevator.
The 65's are half as powerful again but the
55's are a couple grams lighter.
I've got 55's in my Bacaruda which has 'arrived'
Several times without damaging them when
Similar incidents wrote off no name 5 gram'ers.
The thing to watch out with small plakky geared
Servos is not to knock the control surfaces when
Transporting and storing the plane cos this is what
Strips the gears.
Very Happy
John Goddard
John Goddard
Post  ChaseBanner Wed Nov 24, 2021 1:08 pm
mitchg95 wrote:i have not gotten much done to the plane over the past day, been mainly working on my dirtbike just maintaining it Smile
i have a hs55 servo, which is all plastic gear, is there much price difference between the 65 and the 55?
go with the 65's, u can get a pair for 45 bucks and put a cheap-o on the throttle
ChaseBanner
ChaseBanner
