» Tee Dee .020 combat modelby getback Today at 7:14 am
by getback Today at 7:02 am
Question regarding Measuring and setting head clearance
Other than by guess and by gosh then run it how are you guys setting the head clearance on the cox motors? Are you doing it the same as the larger motors are is there a more accurate way? I don't like using Plasti-gage or solder. This link is the process I use on the bigger motors but this tool makes use of the liner and the Cox isn't setup that way. http://www.darrolcady.com/Accessories/LinerTool/newlinertool.html
If this has been covered already please steer me to the link as my search didn't find it.
Thank you,
Lane
Thank you,
Lane
Lane Puckett- New Member
Re: Question regarding Measuring and setting head clearance
Lane:
On Cox engines it is usually done by either adding or subtracting thin copper head gaskets.
SuperDave- Rest In Peace
That's pretty much the case. We Cox users change the compression to account for fuel mixture, prop size, and wide variations in temperature. There are rules of thumb that work pretty well, such as adding a head shim(washer/gasket) for every 10 percent of nitromethane, starting with 1 shim for less than 20%(a poor formula for a Cox), 2 for 20%, 3 for 30%, etc. Cox parts were made with extremely reliable tolerances, so this may be the reason you're finding no information on the subject.SuperDave wrote:Lane:
On the other hand, every engine has it's own performance characteristics, so experimentation on each one to find its happy compression spot isn't uncommon. There are lots of head and plug configurations that can be tried to tune an engine to its peak.
As far as decking the heads, the only reason I've ever done it it to ensure a good seal against the copper shims. Some people change the timing by shimming the cylinder height at the crankcase. There are various reasons for this, including eliminating sub piston induction so you can use a muffler, but for the most part it usually isn't helpful, and more than not it's hurtful to performance.
That's all I've got. Maybe someone with more engine knowledge will come along with a better answer. Paul Gibeault is probably our best expert at squeezing every last bit of power out of Coxes. If you PM him, he'll answer. Also see his Mouse Racer article pinned at the top of Cox Discussions.
This thread has some info: https://www.coxengineforum.com/t1372-timing-vs-compresion
Search tip: use the 'Google' button to search on thread content, not just title.
ahrma_581- Gold Member
I somehow missed the last part of that thread. It may be helpful to Lane. Thanks Mark, for posting it, and Ahrma for dredging it up.
That link has what I was looking for. I can measure from there.
I have a bunch of glow plug gaskets in many thickness(2,4,6, and 8 thou) so I can get the right clearance. Just needed a means of measuring the thing.
Appreciate the information.
Thank you,
Lane
Thank you,
Lane
» Glow head question
» .049 Glow Head Question
» Cox Tee Dee high-compression glow head question
» Re-setting a piston?
» Another Bees Nest
» Another Bees Nest
