What Killer Bee is it (1996 or 2002) Cox_ba12
What Killer Bee is it (1996 or 2002) Pixel
by getback Today at 8:14 am
by getback Today at 8:02 am
by batjac Yesterday at 10:47 pm
by roddie Yesterday at 9:50 pm
by getback Yesterday at 1:05 pm
by rsv1cox Wed Nov 20, 2024 4:21 pm
by 1975 control line guy Wed Nov 20, 2024 9:17 am
by rsv1cox Tue Nov 19, 2024 7:35 pm
by Cox International Tue Nov 19, 2024 1:01 pm
by getback Tue Nov 19, 2024 7:08 am
by roddie Mon Nov 18, 2024 10:05 pm
by rsv1cox Sun Nov 17, 2024 7:40 pm
What Killer Bee is it (1996 or 2002) Empty
What Killer Bee is it (1996 or 2002) Empty What Killer Bee is it (1996 or 2002)
Post  aungmyatoo Wed Oct 10, 2012 8:19 am
I found this on ebay, the price is abit expensive without box, may be used one. But I can't resist my curiousity and bought it.
http://www.ebay.com.sg/itm/190727314505?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
What Killer Bee is it (1996 or 2002) Ebay10
aungmyatoo
aungmyatoo
What Killer Bee is it (1996 or 2002) Empty Re: What Killer Bee is it (1996 or 2002)
Post  aungmyatoo Wed Oct 10, 2012 8:26 am
it arrived today.
What Killer Bee is it (1996 or 2002) 110
Its backplate & needle. Needle looks like from old KB loosing it yellow plastic extension.
What Killer Bee is it (1996 or 2002) 210
Lightened crankshaft with drilled crank pin.
What Killer Bee is it (1996 or 2002) 310
The reed valve is not stainless steel. Cylinder has SPI.
What Killer Bee is it (1996 or 2002) 311
aungmyatoo
aungmyatoo
Post  aungmyatoo Wed Oct 10, 2012 8:35 am
The piston weight 3.2 gram.
What Killer Bee is it (1996 or 2002) 510
The cylinder have 2 ports with 1 booster port on each one.
What Killer Bee is it (1996 or 2002) 610
the cylinder do not have tapered grind so the piston can pass through.
What Killer Bee is it (1996 or 2002) 710
This last fact make me confused. this KB has all features of 1996 KB but no tapered grind is 2002 KB features. How to decide ??? Also another question is the dot at the middle of upper surface of piston???
aungmyatoo
aungmyatoo
Post  Cribbs74 Wed Oct 10, 2012 9:41 am
The "pip" at the top of the piston is just leftover from the milling process. Most pistons have that.
Other than that I am not well versed on the KB particulars.
Post  Cox International Wed Oct 10, 2012 10:00 am
I would say that you have an engine that was assembled from various parts.
It has the "real" KB crank but a #325 head and what looks to be a non-KB piston.
The cylinder seems to be the correct one, as well as the backplate. The needle is missing the stem but we have those in stock.
Cox International
Cox International
Official Cox Dealer
http://www.coxengines.com
Post  mitchg95 Wed Oct 10, 2012 10:02 am
cribbs74 wrote:The "pip" at the top of the piston is just leftover from the milling process. Most pistons have that.
what makes that "nipple" (what we call it in my machining class) is that the lathe bit was not centered completely, so when you go to "face" off a part and the bit is not centered, you will always get that little "nipple"
mitchg95
mitchg95
Post  aungmyatoo Wed Oct 10, 2012 10:32 am
Thank for the info you guys provided. I found correct needle with yellow tube extension among my old things and replaced it. So according to Bernie, I nee dto get correct head and piston. I know piston have to be lightened and tapered grind. But what is the correct head looks like? thanks
aungmyatoo
aungmyatoo
Post  microflitedude Wed Oct 10, 2012 10:37 am
You need a 1702 high compression head.
http://coxengines.ca/cox-.049-tee-dee-glow-head.html
microflitedude
microflitedude
Post  aungmyatoo Wed Oct 10, 2012 11:04 am
I have NOS high compression head. Is this the correct one for KB?
What Killer Bee is it (1996 or 2002) Img_1610
aungmyatoo
aungmyatoo
Post  Cox International Wed Oct 10, 2012 12:35 pm
Yes, that is the correct head.
Good luck with the piston as I have been looking for one for over a year now as well.
Cox International
Cox International
Official Cox Dealer
Post  Admin Wed Oct 10, 2012 1:57 pm
I almost want to say you have a "transition bee". A transition bee is an engine that was produced in the exact beginning when Estes took over operation. Perhaps there was leftover stock of all the parts except for piston/cylinder assemblies. After looking into the extra costs of having different lightened tapered pistons for only that one engine, they made it so those pistons would be interchangeable with all the other .049 engines as well. So for transition engines, you will sometimes see Black Widows that use the correct parts but maybe a tank or crankcase or maybe the whole engine would be "silver".
Post  WingingIt74 Wed Oct 10, 2012 4:17 pm
So you were the one bidding against me lol!
WingingIt74
WingingIt74
Post  aungmyatoo Wed Oct 10, 2012 7:09 pm
Yup, I told that it is in expensive side but I can't resist to bid it. Because of curiosity, how the KB crank looks like in person (I never had one).
Yes transistion Bee theory might right. BTW can I use piston from old TD0.049 for this?
aungmyatoo
aungmyatoo
Post  WingingIt74 Wed Oct 10, 2012 7:19 pm
aungmyatoo wrote:Yes transistion Bee theory might right. BTW can I use piston from old TD0.049 for this?
I would leave it like it is.
WingingIt74
WingingIt74
Post  Cox International Wed Oct 10, 2012 7:42 pm
This is a KB crank:
http://coxengines.ca/cox-.049-killer-bee-diesel-crank.html
Cox International
Cox International
Official Cox Dealer
Post  aungmyatoo Wed Oct 10, 2012 10:19 pm
Bernie, is your KB crank made in USA or where?
I would say I proud to own made in USA things, and love to buy them.
but made in ----- things, I really hate them, what ever their performance is (I can't help, but its my personal feeling).
aungmyatoo
aungmyatoo
Post  aungmyatoo Wed Oct 10, 2012 10:22 pm
I'll replace the head and needle extension. For piston, cylinder, I'll leave it like that. One extra number for my collection "Killer Bee in Transition"
aungmyatoo
aungmyatoo
Post  Cox International Thu Oct 11, 2012 9:50 am
aungmyatoo wrote:Bernie, is your KB crank made in USA or where?
Our KB cranks are made in the USA and are identical to OEM product as they were made to the OEM Cox drawings.
Cox International
Cox International
Official Cox Dealer
Post  aungmyatoo Thu Oct 11, 2012 11:20 am
How it looks like after replacing with correct head & needle straw.
What Killer Bee is it (1996 or 2002) Img_1611
All 1996 KB parts except piston!!! "Transition Killer BEE"
aungmyatoo
aungmyatoo
Post  WingingIt74 Thu Oct 11, 2012 11:23 am
looks good Smile here's my 051 KB
What Killer Bee is it (1996 or 2002) Img_2312
WingingIt74
WingingIt74
Post  aungmyatoo Thu Oct 11, 2012 11:38 am
Nice 051 KB you have. I found Estete 051 KB up for bid in ebay now but it is in 049 box. So I feel something not right to bid
http://www.ebay.com/itm/Cox-049-Killer-Bee-New-in-the-box-nice-/271075938795?pt=LH_DefaultDomain_0&hash=item3f1d6291eb
and asking $90 for buy it now.
How do you think?
aungmyatoo
aungmyatoo
Post  aungmyatoo Thu Oct 11, 2012 11:40 am
What Killer Bee is it (1996 or 2002) T2ec1611
aungmyatoo
aungmyatoo
Post  WingingIt74 Thu Oct 11, 2012 11:40 am
Ya, I seen that one... not sure what that is. The needle valve is wrong and not even sure if it's a 049 or 051. 049 should have a black backplate, both should have the needle valve you put on yours.
WingingIt74
WingingIt74
Post  aungmyatoo Thu Oct 11, 2012 11:46 am
The needle valve looks like from Estete era. I check with cox museum website. The red back plate is for 0.051. But the box said 0.049. May be Estete mixed up everythings.
aungmyatoo
aungmyatoo
Post  aungmyatoo Thu Oct 11, 2012 11:48 am
I going to ask the seller what the date in the box. Usually there will be date stamped underneath the paper supporting engine.Smile
aungmyatoo
aungmyatoo
