Pressure on a TD .051
I have a TD that has a pressure tapped backplate and the pressure tap on the plastic carb body is closed off.
What is the difference between using one or the other?
Matt1967- Moderate Poster
Re: Pressure on a TD .051
Matt:
The previous owner may not have realized that the pressure tap on the plastic venturi body must be drilled out to work so ke installed a tap on the backplate????????
Either way should work fine.
SuperDave- Rest In Peace
Convenience: may be easier to get to bleed on back of engine or on side, depending.
Getting fuel line to stay on carb mount nipple can be difficult, so I've read. No barb. Maybe intended by Cox as an anchor for starter spring and then turned into pressure port by ambitious types later?
ahrma_581- Gold Member
ahrma_581 wrote:Convenience: may be easier to get to bleed on back of engine or on side, depending.
Ok Sounds like it they are the exact same function.
Question #2 While on the subject, I thought I once read that you should not use crank pressure on a throttles engine, only muffler pressure with a throttle. Is that valid?
You have to add a barb like the ones I have for sale.
jsesere- Rest In Peace
The nipple on the carb body was always intended for a pressure tap. The springs didn't appear until later. You can get timed pressure in pulses every time the intake valve opens, or you can tap the backplate to get steady pressure. Use whichever best suits your fuel system, they have different applications. There are a few members here that know enough to give you more specific answers, so check back after the weekend. It gets pretty quiet here on Saturday and Sunday because everyone is out playing.
We used to use the TD 049 and 051's for 1/2 A pylon racing here in Australia many years ago. The main use for the pressure tap is to enable the use of a larger venturi which will give more power.
We were using some pretty trick fuels back in the day, 50%- 60% nitro with some propylene oxide and all Klotz oil. Propped for 19000 - 20000 on the ground, any more and the rods became vulnerable.
Getting back to the pressure nipple, we all universally used the back plate pressure nipple. The timed pressure from the crankcase nipple was just too much and made needle tuning that much more of a hassle.
If you have a pressure back plate, I'd use that and leave the one on the carb body alone. We used the Kirn Kraft back plates along with the fine thread KK needle valve assemblies and the check valves too. Also used the Glow bee button heads with the clamp rings.
happy days, biggest shame was when the rule makers said you couldn't get 049/051's and went to 10's then 11's and then 1/2A as a class died.
raglafart- Beginner Poster
<< rembers the good ole days out at SSME
http://www.ssme.org.au/
ekitten2- Gold Member
im concidering useing both rear pressure and a tuned pipe set up for a future rebuld of my mini hydroplane
can any one advise on a sutable tuned pipe??
and would pressure be helpfull as it wont be doing aerobatics or such (just low level speed runs) ?
your help is always well appreicated fanks ...Gazza
Question on pressure fueling":
If an engine is turning, at say, 18K RPM, what's wrong with using the "pulse" from the venturi body?
Seems that would produce an plenty adequate flow of fuel.
» Tee Dee pressure tap ??????
» .049 muffler pressure
» Tee Dee on non-pressure bladder
» TD 051 pressure backplates
» Tee dee .049/.051 crankcase pressure
