Correct procedure to start a 0.10 tee dee engine? - Page 2 Cox_ba12
Correct procedure to start a 0.10 tee dee engine? - Page 2 Pixel
by roddie Today at 1:34 pm
Correct procedure to start a 0.10 tee dee engine? - Page 2 Empty
Page 2 of 2 Previous  1, 2
Correct procedure to start a 0.10 tee dee engine? - Page 2 Empty Re: Correct procedure to start a 0.10 tee dee engine?
Post  RknRusty Tue Sep 18, 2012 8:48 pm
casalejuan wrote:.... yesterday I bought an aluminum carburator and I´m going to glue the backplate to the tank with silicone to see if this fix the problem. ... yes, I know that is not the best solution but I don´t know what to do. Usd 18 for a new tank is to expensive...
Try black Permatex RTV gasket maker from the auto parts store.
Post  casalejuan Tue Sep 18, 2012 9:15 pm
Wink Wink Wink Wink
Last edited by RknRusty on Tue Sep 18, 2012 10:30 pm; edited 1 time in total (Reason for editing : fixed quote tag)
casalejuan
casalejuan
Bronze Member
Bronze Member
Post  coxaddicted Wed Sep 19, 2012 4:28 am
Wink Wink Wink Wink
If this is not available you can give ,,Elring Dirko HT'' a try. I don't know if it's available in your country but I know it works well in one of my engines. It can be removed without residues.
Whatever you use you shall be less plenty with this sealing compound.
coxaddicted
coxaddicted
Post  casalejuan Wed Sep 19, 2012 6:05 am
coxaddicted wrote:
Wink Wink Wink Wink
I found Black Permatex RTV gasket. I can´t find Elring Dirko HT.
Thanks for your help.
casalejuan
casalejuan
Bronze Member
Bronze Member
Post  casalejuan Wed Sep 19, 2012 6:07 am
RknRusty, do you know if Permatex RTV can be removed if I need so? in the specifications says that it gets hard as steel
casalejuan
casalejuan
Bronze Member
Bronze Member
Post  coxaddicted Wed Sep 19, 2012 6:26 am
I would prefer something ,,elastic'' which can be easily removed. BTW the dirko is expensive too. So if you need it only for the cox models I would look for a alternative.
coxaddicted
coxaddicted
Post  casalejuan Wed Sep 19, 2012 6:39 am
coxaddicted wrote:I would prefer something ,,elastic'' which can be easily removed. BTW the dirko is expensive too. So if you need it only for the cox models I would look for a alternative.
In Argentina, the Permatex RTV costs Usd 10.
casalejuan
casalejuan
Bronze Member
Bronze Member
Post  John Goddard Wed Sep 19, 2012 6:52 am
Silicon Bathroom sealant from your local DIY centre.
However be careful when using all these pastes because it's very easy
to block the fuel tube pick up in the bottom of the tank.
John Goddard
John Goddard
Post  SuperDave Wed Sep 19, 2012 9:53 am
The best 'cone (silicone) that I've found for this purpose is by Permatex and is used to seal car windshields. It's clear and reasonably fluid enough to flow into into leaking areas.
Don't have the part number at hand but if you wish, I can get it when I go out to our motorhome later today. Let me known Juan.
SuperDave
SuperDave
Post  RknRusty Wed Sep 19, 2012 10:42 am
The Permatex I use stays rubbery and tough. It sticks tight but never hardens, just turns to rubber. Could you have misread it? Try a dab on a test area and see what it does. It's as hard as it will get after 24 hours.
http://en.wikipedia.org/wiki/RTV_silicone
http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_makers/auto_Permatex_Ultra_Black_Maximum_Oil_Resistance_RTV_Silicone_Gasket_Maker.htm
That sounds like what you have, though I don't recall it being called "Ultra."
Post  casalejuan Wed Sep 19, 2012 11:02 am
RknRusty wrote:The Permatex I use stays rubbery and tough. It sticks tight but never hardens, just turns to rubber. Could you have misread it? Try a dab on a test area and see what it does. It's as hard as it will get after 24 hours.
Well I´m going to buy it but if is something elastic what I need, I have in my house three types of silicone. I am dedicated to making silicone molds and I have a lot of variety of it. Maybe silicone can work.
casalejuan
casalejuan
Bronze Member
Bronze Member
Post  RknRusty Wed Sep 19, 2012 11:14 am
I have sealed all sorts of gaskets on car engines with it. It holds back gasoline, oil and water at all temperatures. I think you'll like it and find many uses for it. RTV stands for Room Temperature Vulcanization.
Post  casalejuan Sat Sep 29, 2012 9:13 am
Hiiiiiiiiiiiii!!!!!!!!!!!!! Good News!!!!!!!!!!!! Flying My tee Dee started!!
I changed the plastic carb body for an aluminum carb body and I bought a Glow Starter Plug Igniter Rechargeable.
Those things made the difference. Here is a video of my Tee Dee starting.
Thanks to all of you for your help.
Juan Airplane
casalejuan
casalejuan
Bronze Member
Bronze Member
Post  SuperDave Sat Sep 29, 2012 9:33 am
I LOVE happy endings! Wink Wink Wink
SuperDave
SuperDave
