Varnish seize?
Varnish seize?
Was running a #1 cylinder last nite that had alot of varnish buildup on the piston top ( almost black) and on the plug(dark brown). After the run a great deal of varnish was removed from the piston but the fit is now extremely tight. Could that much varnish build up on the walls in one run? Was testing an enlarged Venturi backplate and it did lean way out for about ten seconds. Could I have warped the cylinder? It is tight immeadiatley at the top of the exhaust port.
JPvelo- Diamond Member
Re: Varnish seize?
The varnish that melted off the top of the piston could have re-deposited on the cylinder wall. If it added to an already varnished cylinder, it might be enough to stiffen it up. Was the plug and head cleaner looking after the run?JPvelo wrote:Was running a #1 cylinder last nite that had alot of varnish buildup on the piston top ( almost black) and on the plug(dark brown). After the run a great deal of varnish was removed from the piston but the fit is now extremely tight. Could that much varnish build up on the walls in one run? Was testing an enlarged Venturi backplate and it did lean way out for about ten seconds. Could I have warped the cylinder? It is tight immeadiatley at the top of the exhaust port.
If it leaned out long enough to get really hot, I suppose some of the imbedded castor varnish could have expressed out of the cylinder wall. If I understand correctly, it is leaded steel, so it could conceivably hold enough varnish(like bronze absorbs oil) to melt and move out onto the surface of the wall. That's a guess, I'm not a chemist. My son is, but he isn't here to lecture me on the subject.
You didn't remove the cylinder from the crankcase with the exhaust port wrench did you? If not, for future reference, and for anyone reading this, the way to use that tool is to trap it in a vice so it can't deform as you unscrew the cylinder. Otherwise you get a burr on the port edge that makes it stiff until you find and remove the burr.
Re: Varnish seize?
A Davis Diesel brush is probably the next best tool to the reset tool. It quickly removes the varnish and places micro scratches in the cylinder walls in a cross hatch pattern which does increase rpm's. Run the brush a few times in the cylinder and wash with soapy hot water. An old toothbrush with the sides slighty rounded allows it to get inside the cylinder to really scrub it well. Ken
Re: Varnish seize?
Brass .45 cal. brush from a gun store works very well. Use Hoppes #9 solvent also available at gun shops or sports centers.
jsesere- Rest In Peace
Re: Varnish seize?
My wager would be with Rusty particularly in view of where the
'tight' spot is.. The wrench has burred the bore.
Just to confirm, I have burred a bore in this manner in the
Past
Past
John Goddard- Diamond Member
Re: Varnish seize?
In the event the bore did indeed get burr, it can be fixed. I've repaired many that had the wrench treatment where the cylinder had no flats and the wrench caused the damage. If you use K&S 3/8 tubing, I cut a piece about 6" long. You then wrap Scotch tape around the tube once sometimes twice. I find the blue painters tape to work with one wrap as well. Insert the brass tubing through the cylinder with the tape exiting the bottom of the cylinder. The inside of the piston skirt is tapered. Put the conrod into the tube and push the piston skirt onto the tube and the tape will hold it pretty snug. While drawing the piston up into the cylinder, it will be upside down in the bore with the skirt coming up to the glow plug landing. I mix a slurry of rottenstone and oil and place a drop or two onto the skirt via the exhaust slots. You can use Brasso or even mild polish like Dupont "7 Rubbing compound or even A fine chrome polish. You turn the brass tube while working it up and down bringing the skirt not to high in the bore as your just using the skirt to rid the cylinder of the burr. The skirt has very little value other than keeping the piston running true in the bore. Relieving a bit of the skirt will even possibly give you a higher performance. I do this with many of my speed planes. If the tube comes out while attempting this, wrap another layer of tape on the tube. Make sure all is washed real well in hot soapy water. The 3 items I described above will breakdown using water. I've saved many cylinders this way. Chrome polish is a bit harder to rid the cylinder of for example, Mother's. I use a nylon bristle brush to scrub all media out and this is a must as it can retain itself on the cylinder walls creating a lapping compound. The area of attention is the bypass ports as they can load with the polish. Ken
Re: Varnish seize?
Rottenstone? What is it and where do I find it?
Re: Varnish seize?
My supply was given to me by Larry Scarinzi. Duke Fox had given him a considerable amount back in the 60's. A few of us actually had asked for some and he filled up some 35 mm film canisters with it. In fact, this may be true to this day, When Fox tests their engines prior to sale, they use a fine powder with a brand name Lusterox. I believe this is what I have. It's a very fine abrasive and when the engine was running they dusted a bit into the intake to expedite break in. I've seen this done with Cox Tee Dee's as well back in the early 80's the combat guys were doing this. I've used the Dupont rubbing compound repeatedly and it has worked real well. I find it abrasive enough to do the job and not abrasive enough to over do the job. Seeing that the cylinder in question is already in not so up to par quality, I would certainly give it a try. I did Google rottenstone and it revealed the abrasive powder. Ken
Re: Varnish seize?
Varnish yields well to Hoppe's #9 Gun-Cleaning sovent.
Give your engine a good soaking/cleaning then see how it runs after.
SuperDave- Rest In Peace
Re: Varnish seize?
JPvelo wrote:Rottenstone? What is it and where do I find it?
Rotten Stone is a fine polishing compound when mixed with oil or water that is used for wood.
A finer form is known as Tripoli and is used to polish soft metals. It is available dry or in a wax and/or grease mix.
There is a very dark form in hard wax used to "charge" buffing wheels.
If you use this make VERY sure you remove all traces of it or it will continue polishing when you run the engine.
if you use some synthetic along with castor, varnish will not form as easily.
gcb- Platinum Member
Re: Varnish seize?
[quote="RknRusty"]
really wish i would have read this 2 hours ago... now in sanding that burr out by handJPvelo wrote: Otherwise you get a burr on the port edge that makes it stiff until you find and remove the burr.
Apollo Kenney- Moderate Poster
Solved
Hoppes #9 and a nylon .45 caliber brush. Thanks guys.
Re: Varnish seize?
Buy your Hoppe's #9 by the quart and save yourself some $$$$. I use it for all sorts of cleaning task. I buy mine in-store at Cabela's.
Besides going to Cabla's like going to a candy store for boys.
Re: Varnish seize?
Okay, just had the same thing happen last night. Turns out I am mushrooming the piston when I use my reset tool. Have only used it twice and has happened with both pistons.
Re: Varnish seize?
I've ruined every piston I've tried. I was using a medium tack hammer on a flat anvil and tap-tap-tapping while rotating the piston. After 50 or so licks, nothing was happening so I increased my force. One that didn't mushroom, lost half of its SPI, as did some of the others. I quit doing it. Since then, I've been told to use a heavier hammer, but I haven't tried it yet.JPvelo wrote:Okay, just had the same thing happen last night. Turns out I am mushrooming the piston when I use my reset tool. Have only used it twice and has happened with both pistons.
Since I don't run most of my engines over 20K RPM, I don't worry about it and they run fine. Over time I suppose it could wear through from lateral movement of the ball in the socket. Many people imagine it's an up and down slop, hammering during the piston stroke, but I don't think there is actually ever a time when the rod ball isn't being pushed tightly against the underside of the piston. Sure, the lateral motion is wasted energy but I doubt if it's ever even noticeable. I will try it again with a bigger hammer, but not on anything I treasure until I find I can do it successfully.
Okay everybody, you may pile on now.
Re: Varnish seize?
Rusty:
We've both been dealing with the same problem: seized engines.
Yesterday I received a brand-new TD .051 that was seized solid. An overnite soaking in Hoppe's and the application of mild heat from my Weller butane "mini-torch" this morning AND voila! The engine freed up fine, the cylinder loosened and ditto the backplate and cylinder head.
The mini-torch came as an accessory with my Weller soldering torch. At no point did I apply force to free these parts.
Re: Varnish seize?
Good, Dave. Glad you got it straightened out. I was addressing JP's last comment about his troubles with mushrooming pistons, as in the quote below. So I thought I'd toss in with my similar experiences. It's not a hijack since he's the OP.SuperDave wrote:Rusty:
Re: Varnish seize?
Rusty:
It's simply not possible for me to rave too much about the usfullness of my Weller butane soldering torch for modeling purposes. Some may balk at the $63 price but it has a miriad of useful purposes besides as a soldering tool.
Re: Varnish seize?
I have the same problem rusty. Lite taps to nothing but a good enough wallop to reset the socket deforms the piston. Anyone who has used a reset tool successfully feel free to chime in.
Re: Varnish seize?
Maybe we need to whack on it with one of Dave's soldering tools.
Just kidding, Dave.
Just kidding, Dave.
Re: Varnish seize?
Rusty:
You R a funny guy!
By no means to I subscribe the idea that mangling something is a good way to "fix" a problem.
You R a funny guy!
Re: Varnish seize?
Its got to be the tool, the one I have has a raised center so only the center of the piston rests in the cradle.
I use an 8oz ball-peen and tap it smartly 4 or 5 times. Done 10 or 12 so far with no problems.
crankbndr- Top Poster
Re: Varnish seize?
JPvelo wrote:I have the same problem rusty. Lite taps to nothing but a good enough wallop to reset the socket deforms the piston. Anyone who has used a reset tool successfully feel free to chime in.
This can happen if your anvil is not sitting on a SOLID surface. The surface should be hard and substantial like a large vise or patio block...wood is not good enough. The problem stems from the hammer force being transmitted through the piston and absorbed by a softer surface. A hard surface will make the force stay at the socket.
Not saying that this is your problem, but it MIGHT be your problem.
Re: Varnish seize?
I've freed a whole bunch of Cox engines that were stuck/frozen in my many years of enjoying them.
The curse may fall upon me but I've never damaged a piston or bore using Hoppe's and mild heat but the BIG trick is PATIENCE in liberal amounts. Rome wasn't built in a day nor was a stuck/frozen Cox freed in a minute.
Frustration is very often your largest enemy. It will cause you to do unreasonable things and damage valueable parts.
Re: Varnish seize?
gcb wrote:JPvelo wrote:I have the same problem rusty. Lite taps to nothing but a good enough wallop to reset the socket deforms the piston. Anyone who has used a reset tool successfully feel free to chime in.
Ditto to what George said. I was suffering about a 20% failure rate doing this on my tool box or small vise. When I moved it to a larger, more solid and stable surface I have been enjoying a 100% success rate. I am certain luck has something to do with it but the numbers did get better.
Good luck,
fit90- Diamond Member
» Glow Head Threads and Never-Seize
» Getting Rid of 'Old Man Varnish'
» paint and varnish
» How do I get the brown off my piston top?
» Varnish Fuel Proof?
» paint and varnish
