Baby Ringmaster 2012-2012 R.I.P - Page 2 Cox_ba12
Baby Ringmaster 2012-2012 R.I.P - Page 2 Pixel
by batjac Today at 9:47 pm
by roddie Today at 8:50 pm
by rdw777 Today at 5:07 pm
by rdw777 Today at 4:51 pm
by getback Today at 12:05 pm
Baby Ringmaster 2012-2012 R.I.P - Page 2 Empty
Page 2 of 2 Previous  1, 2
Baby Ringmaster 2012-2012 R.I.P - Page 2 Empty Re: Baby Ringmaster 2012-2012 R.I.P
Post  Cribbs74 Fri Sep 07, 2012 11:53 am
RknRusty wrote:Ron, I just thought of something. Have you ever noticed in my earlier videos I always had a streamer trailing the plane? I first put it there to help the camera and audience see it, and I thought it looked cool. But I'm pretty sure the drag made it easier for me to control it when I was learning to fly loops and 8s and such. I started out with red Christmas tissue like you stuff in gift bags. About 2" wide and 3 or 4' long. I tied it to a dacron string long enough to clear the airframe. After that I used a crepe paper ribbon, but it deteriorates faster and leaves a trail of bits.
It might be worth a try.
I have kinda been doing that already as I have been using a bit of kite string to tether the plane to the stooge pin. I bent the tail drag into a hook shape on the other end. I attached a small peice of flagging tape to the string as it usually falls away from the plane after a few loops and the orange tape allows me to find it in the grass. I could use tissue as you suggested to create a little drag and slow things down for me. Good idea! Thanks
Post  SuperDave Fri Sep 07, 2012 11:58 am
Ron:
My BR Brodak tank is the one recommended by Brodak, a (Perfect) Wedge #504 which has plenty of "juice" to auger you into the ground. Laughing If I get dizzy going "roundy round" I resort to a series of inside and outside loops to keep the twists out of the lines.
As I mentioned some time ago my BR is for a beam rather than radial mount so the tanking issue has more possibilities. I suspect for you a radical "stunt tank" like offered by the vendors might be an option.
Like we say in fly fishing, TIGHT LINES!
SuperDave
SuperDave
Post  gcb Sun Sep 09, 2012 11:22 am
lousyflyer wrote:A TeeDee .051 on a Baby Ringmaster? Yikes!
Remember that some of these planes were designed for an old Wasp (not the new one) or OK Cub, either of which had 1/4 to 1/3 the power of a TD. A more modern ship like a 1/2A Flite Streak is better matched to handle the power of a screaming TD.
If you are going to build one of these old planes from plans, and power it with a TD, perhaps enlarging the plan by 10% or 20% would help.
For learning other than round and round, try starting with a horizontal eight. After you learn the eight, stretch it out to make it wider...this is called a lazy eight. Eventually you will get to where you can complete a lap or more before doing the outside part. At this point you have also conquered inverted flight. Good luck.
One additional thought. The TD .051 was designed to have about the same power as the TD .049 so the same FF plane could be flown in both "1/2A" and "A" without trim adjustments.
gcb
gcb
Post  SuperDave Sun Sep 09, 2012 11:52 am
On my BR/TD .051 combo I prop the engine with a wooden 6X4 Tornado rather than a smaller prop. I'm not so sure that an under proped "screamer" generates the trust I need to do aerobatic manuvers.
In this case the prop must generate torque and not just high RPM. I my legthly model aviation experience I've seen stunt ships fail miserably because they were under proped.
SuperDave
SuperDave
Baby Ringmaster 2012-2012 R.I.P - Page 2 Empty babybee turn in
Post  eddieki Wed Mar 04, 2015 6:43 am
Kim wrote:Oh Shoot !!!!!!!!
Does it just not turn a tight-enough loop and hits the ground at the bottom, or does it roll in on you?  Man, hope you can get it going again without too much trouble!
Kim is now laying low for a while !!!!
just use a left hand prop and run the baby bee clockwise, it will help keep the lines tight.
O yea I use a pusher prop when on the front just run it cloclwise.
Last edited by eddieki on Wed Mar 04, 2015 6:49 am; edited 1 time in total (Reason for editing : To clarify useing pusher prop.)
eddieki
eddieki
New Member
New Member
Post  getback Wed Mar 04, 2015 7:56 am
I think I just got that BW from Ron , I am not outing that on my BRM for the Maiden lol! Ron will like seeing this old post Very Happy Eric Very Happy ( amazing what the hit done to the wing ) Jaw Drop
Post  Cribbs74 Wed Mar 04, 2015 10:06 am
Eric,
The damage seen is classic Ringmaster damage. The trailing edge likes to split at the seam. This can be cured by wrapping that seam with some epoxy soaked cloth.
That Widow in the picture is still in my posession. I think the spinner and cylinder I gave you is off of that one Eric.
Looking back through this I find it funny to re-read about how much trouble I was having. Those stunts seem so simple now that I don't understand why I was having a hard time. Practice I suppose, and a lot of crashed planes too!
Post  RknRusty Wed Mar 04, 2015 10:33 am
Look at Ron fly now
https://youtu.be/wdpTRjIvApE
Later I found it had a clogged needle valve, rather than sucking air, as I mentioned in the video.
https://youtu.be/EijgP3hqh0s
