my "twin bee"
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: my "twin bee"
No, it is the only one whom I built.The fuel is standard with 5% nitromethane, and this engine use a stock "reed".
Now I builds one 4 cylinders boxer of 16 cm3, 2 stroke
chris74100- Silver Member
Re: my "twin bee"
I am assuming a 4 cyl. will have a proportionately sized "rotary-valve" induction?chris74100 wrote:No, it is the only one whom I built.The fuel is standard with 5% nitromethane, and this engine use a stock "reed".
Did you increase the fuel/air-flow in the 1st 2 cylinder engine? (asked in my previous post) I am aware of the fuel restrictions/availability in your region... but your Cox engine components were designed to run on fuel with a nitro content of 3-times (minimum) of what your stated test-fuel has.
I would "personally" pay the shipping... "to and from" the U.S. to have one of our "engine people" here; run your 2 cylinder model, on "cox" fuel. You already have several people interested in your engine... and there's quite a large Cox community here in the U.S. You "may" be able to profit from a production-run, if the engine's performance is adequate.
We are all very envious of your skills!
Roddie
Re: my "twin bee"
Hi, Roddie, the fuel/air-flow is similar at the standard babee be. I'm not modified.
Maybe would be it better to put a carburetor
Re: my "twin bee"
Chris, in my opinion... a 4 cylinder should have a venturi size of a .15 to .20 engine (if using the Cox .049 cylinders) and large enough to bore-out, if there's still not enough air-flow.chris74100 wrote:Hi, Roddie, the fuel/air-flow is similar at the standard babee be. I'm not modified.
Maybe design a crankcase with the venturi in the "center"; equally feeding the 2 front and rear cylinders with a rotary-valve crankshaft supported with bearings?
There's always the consideration of the "mounting" provisions too. A "radial" mount would probably be better than "beam mounts". I've seen multi's with a "rear" intake... and this makes it difficult to mount the engine to a firewall.
I am sure that if "anyone" can build it... "you" can!
Roddie
Re: my "twin bee"
Lol, the 4 cylinders is 4x .20ci, (16cm3 in metric).
Re: my "twin bee"
Sorry Chris... I should have caught that in your previous post...chris74100 wrote:Lol, the 4 cylinders is 4x .20ci, (16cm3 in metric).
Re: my "twin bee"
This morning, I made a tap to fix cylinders
Re: my "twin bee"
I've never seen somebody make a tap himself - And of such a fine thread. Very nice job!
lieven
lieven
OVERLORD- Diamond Member
Re: my "twin bee"
Nice shop you have there! I ran a "Blake" grinder years ago, for a small local tap company. The machine was for grinding the "flutes" in the tap. The abrasive wheel was "diamond-dressed" down each side, to the proper thickness, and then a "radius" was dressed on; which was frequently "re-dressed" as needed. There was a "rhythm/technique" that had to be mastered while "feeding" into the wheel and then "retracting"... that produced a finish; free of chatter/burn. When completing a piece, the "lands" had to measure within .003" of each other in thickness. It could be a bear to set up... especially with small stuff such as 000-120 pitch. You could almost "see through" the wheel, after dressing it into thickness for these.
Keep us posted on the 4 cylinder's development!
Roddie
Roddie
Re: my "twin bee"
Thanks, but this tap can only aluminium tapping.
Re: my "twin bee"
Here is the beginning of the construction of my second " twin bee ".I wait for the parts of Canada to continue.
Re: my "twin bee"
Watching with fascination.
Re: my "twin bee"
yes. same here.RknRusty wrote:Watching with fascination.
Re: my "twin bee"
The Crankshaft is almost ended.
Re: my "twin bee"
That's my new stand of the new "twin bee"
And with the engine
And with the engine
Re: my "twin bee"
With "paint" and name, N° 0000 for the prototype, CBY.98 for the name and "capacity", and my name (Christian BaillY), the commercial engine will have n°0001
Re: my "twin bee"
Very clean, indeed. You've got talent.
Re: my "twin bee"
Very thanks
Re: my "twin bee"
The new engine is finished. It remains to start it and I would sell it
» rod/piston connecting
» .020 V-Twin
» Yet another twin.
» Schroeder Opposed .020 Twin EBAY
» Cox Simple .020 Twin By Roger J Schroeder on RCG
» .020 V-Twin
» Yet another twin.
Page 3 of 4
