my "twin bee"
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: my "twin bee"
Excellent!
lousyflyer- Gold Member
Re: my "twin bee"
Good deal, did I read that right 9K RPM?
Re: my "twin bee"
Congratulations! Great work.
Re: my "twin bee"
absolutly auwsome well done
it incurrages me to finish mine
ekitten2- Gold Member
Re: my "twin bee"
Chris, was that a rich break-in run or were you leaning it out? When it was running, did it look like both cylinders were getting equal fuel? How is the fuel air mixture getting past the rear crankshaft web and into the front of the crankcase to feed the second cylinder? I keep looking at the pictures, I'm sure it's obvious.
EDIT: DUH! Through the hole in the rear web.
Re: my "twin bee"
cribbs74 wrote:Good deal, did I read that right 9K RPM?
Yes , 9 KRPM, but it is a bit weak, I thought that he would turn more quickly
chris74100- Silver Member
Re: my "twin bee"
Very nice work you've done, and very quickly too.
What props size do you have in the video?
(an 8x6 at 9000rpm would certainly be excellent)
Re: my "twin bee"
No, the prop is a 7x4
Re: my "twin bee"
Excellent Chris very well done.
Try and get yourself a Cox 7x3.5
I know it's not much difference but it will
Really wake the engine up when you start
To lean it down.
To lean it down.
John Goddard- Diamond Member
Re: my "twin bee"
The "twin cox" with her stand. It's finished..............
Re: my "twin bee"
A 7x3 prop might work a little better but the main thing holding it back is likely the restricted intake. Twice the engine size on the same intake as a regular cox babe bee, doesn't sound right. The cox queen bee at .074 has a much larger intake, venturi, and reed-valve compared to a .049.
Re: my "twin bee"
Très beau travail.
Bientôt une production en série limitée ?
Fantastic job.
Available soon ?
Rémy
Fantastic job.
Available soon ?
Rémy
navion34- Gold Member
Re: my "twin bee"
Je te remercie, mais non, même pas un 2eme exemplaire de prévu, j'aime que me moteurs restent "uniques"
Re: my "twin bee"
How about a second one with a backplate and carb from a Queen Bee?
That would be unique enough in my book...
Re: my "twin bee"
<< agrees that would be auwsome
Re: my "twin bee"
what did you end up using for the crank pins?
.106 spring wire?
.106 spring wire?
Shnitzl- Bronze Member
Re: my "twin bee"
hi, the crank pin is in "42cd4" machining and laping with the rod
Re: my "twin bee"
I didn't know what 42cd4 meant so I looked it up. It cross references in the USA as 4140 alloy steel.
Re: my "twin bee"
Isn't 4140 chrome moly?
fit90- Diamond Member
Re: my "twin bee"
http://www.steelstrip.co.uk/international_equivalents2.htmfit90 wrote:Isn't 4140 chrome moly?
4140 is down the page in the alloy steels group under USA. 42CD4 is on the same row in the French column. It doesn't give any more explanation, but I thought chrome moly was mostly molybendum and no steel.
Re: my "twin bee"
what little I know if any is correct.
chromium and molybdenum make up chro moly another word people refer to when asking for 41** steel.
which has allot of SAE ratings, more then I can tell you off hand. 4120,4130,4140,4150 and lots in between.
wonderfully used for rollcages or the barrels of rifles.
*edit, and yes I never really heard of 42cd4 so has to be european, and yes their always is a cross reference (< I dont know what that face is either haha)
thank you Chris, that will surely be a stout crank pin.
more effort then I did for mine.
Re: my "twin bee"
If I remember correctly, and this is a huge if, two of the numbers are for the alloy and the other two are for the Rockwell hardness. I couldn't say which are for what if I am even close to being right. If I get motivated I will look it up this weekend.
Re: my "twin bee"
Maybe this will help a little. Just for basic identification, nothing specific.
Re: my "twin bee"
Hi Chris, This is fascinating! Have you started building a 2nd one? (RE: your recent "Value..." thread) I am curious to know if you increased the "bore diameters" in the venturi tube, and/or fuel inlet nipple and used a larger i.d. fuel pick-up tubing inside the tank?chris74100 wrote:This day, first starting for my twin cox.
What have you run for fuel? Does the engine use a stock "reed"?
Really nice work Chris... I'll bet there's a lot less vibration with both pistons firing together.
» rod/piston connecting
» .020 V-Twin
» Yet another twin.
» Schroeder Opposed .020 Twin EBAY
» Cox Simple .020 Twin By Roger J Schroeder on RCG
» .020 V-Twin
» Yet another twin.
Page 2 of 4
