Elbow or Wrist? Cox_ba12
Elbow or Wrist? Pixel
by Ken Cook Today at 3:23 am
Elbow or Wrist? Empty
Elbow or Wrist?
Elbow or Wrist? Empty Elbow or Wrist?
Post  Cribbs74 Sun Aug 26, 2012 6:56 am
I hear that for proper CL control your supposed to use your arm only basically using your elbow as a pivot point to control the plane. I find this works OK, but I also find I can get more control/ elevator deflection when I snap my wrist. I know Rusty uses his wrist and he flies very well. Just trying to figure out the best way to control the plane without developing bad habits.
Elbow or Wrist? Empty Re: Elbow or Wrist?
Post  PV Pilot Sun Aug 26, 2012 7:02 am
Everyone fly's them differently. Whatever works the best for you.
PV Pilot
PV Pilot
High Tech Balsa Basher
Post  Cribbs74 Sun Aug 26, 2012 7:32 am
PV Pilot wrote:Everyone fly's them differently. Whatever works the best for you.
That's kinda what I figured. Just didn't want to develop a habit that may hinder me down the road. Currently I use both methods, just haven't mastered either one!
Post  gcb Sun Aug 26, 2012 1:33 pm
That elbow stuff is for those learning to fly.
gcb
gcb
Post  Godsey3.0 Sun Aug 26, 2012 1:47 pm
I had always heard to use your elbow when learning to fly. I did not do this as I was not told before I started learning. I just used my wrist and integrated my elbow if I needed more throw.
Rolla
Godsey3.0
Godsey3.0
Post  Cribbs74 Sun Aug 26, 2012 3:45 pm
gcb wrote:That elbow stuff is for those learning to fly.
Hey!!!! We all have to start somewhere. lol!
I guess I'm not wrong in using my wrist then.
Post  microflitedude Sun Aug 26, 2012 4:27 pm
To me, it feels like when you are using only your wrist, it is like flying with 100% rates and 0% exponential. When using your arm, it feels like 50% rates with 25% exponential.
microflitedude
microflitedude
Post  Mark Boesen Sun Aug 26, 2012 4:48 pm
it seemed like (flying AMA pattern) that I used mostly my arm, but on hourglass, square eights and cloverleaf, etc. i'd use some wrist...i think starting out you'd be a lot smoother with arm.
Post  RknRusty Sun Aug 26, 2012 6:28 pm
I always attributed my wrist-only style, as I was taught, for my retarded learning curve. I was probably on my second PT-19 before I was truly fun flying, climbs and dives, seeing how fast I could dive and pull out, touch and go, etc. My first plane was a total slag heap and probably never flew more than a lap. It was a black Stuka. Bad choice for a first plane.
Post  lousyflyer Sun Aug 26, 2012 6:32 pm
To me, the Stuka was the best looking Cox plane. Unfortunately not much of a flyer, especially for the beginner.
lousyflyer
lousyflyer
Post  gcb Mon Aug 27, 2012 8:13 pm
One of the things that will guide whether to use elbow or wrist is whether you have your controls set-up correctly.
At the plane you should have controls initially set-up to with the pushrod closest to the pivot (minimum) and the control horn farthest from the pivot (minimum). Make sure you can adjust the pushrod position on the control horn so you can increase deflection when you are ready to do maneuvers. If you have external controls you can also adjust the bellcrank.
Make sure the pushrod does not flex under compression. If it does, you can install a pushrod guide.
Make sure at no time the pushrod pushes enough to impose force on the rudder other than normal deflection. This sometimes happens when the bellcrank outer hole is used, especially when inner holes are used at the control horn. At least that has been my experience.
At the other end of the lines make sure your handle is set correctly. If you are using a 2" bellcrank, you should consider 2" spacing between the lines. Even less if you are just learning to fly. That's where many make a mistake. If your handle has a 4" spacing between the lines (with that 2" bellcrank) you have a bellcrank that deflects twice as much as your hand. This is where elbow pivoting is great because the controls are too sensitive for wrist control.
Hope this makes sense and helps someone.
gcb
gcb
Post  andrew Mon Aug 27, 2012 9:01 pm
+1 on George's comments.
If you watch the pattern C/L flyers, they usually fly with a straight arm and keep all their manuvers very precise and controlled, following where their arm is pointed. OTOH, I've watched the fast combat guys flying with a slightly bent arm and almost all control is with the wrist.
Post  Cribbs74 Mon Aug 27, 2012 9:25 pm
andrew wrote:+1 on George's comments.
Hmmm, so I guess you need to be proficient in both styles. If you want to be a diverse flyer. Thanks Andrew.
Post  gcb Tue Aug 28, 2012 10:38 am
andrew wrote: If you watch the pattern C/L flyers, they usually fly with a straight arm and keep all their manuvers very precise and controlled, following where their arm is pointed. OTOH, I've watched the fast combat guys flying with a slightly bent arm and almost all control is with the wrist.
Actually, Precision Aerobatic (stunt) flyers use their wrist.
There is more to it than that. Some hold their arm straight out but many also bend their arm a bit. Once you have established your arm position, you need to address handle position. Move your wrist up and down full comfortable deflection, then establish a center of movement. This will determine YOUR neutral position. That coupled with your favorite arm position will determine how your control handle should be set-up for neutral. If you prefer flying with your arm out straight you may want to consider a "biased" handle, that is, one that with the lines at neutral has your hand tilted down about 15 degrees. This is approximately the position that gives your hand equal up and down movement.
gcb
gcb
Elbow or Wrist? Empty Body english from an Englishman
Post  lousyflyer Tue Aug 28, 2012 11:56 am
Here's a never before seen photograph of the incomparable Joe Cocker wringing out a Flite Streak over the crowd at Woodstock in 1969. Note the bent elbow.
Elbow or Wrist? Flyin_10
lousyflyer
lousyflyer
Post  gcb Tue Aug 28, 2012 12:24 pm
lousyflyer wrote:Here's a never before seen photograph of the incomparable Joe Cocker wringing out a Flite Streak over the crowd at Woodstock in 1969. Note the bent elbow.
That was my 'Streak. Wondered what he wanted it for.
OK, OK, Hold the BS Repellant. I give up. lol!
gcb
gcb
Post  Cribbs74 Tue Aug 28, 2012 12:29 pm
Oh now that's funny.......
Post  fit90 Tue Aug 28, 2012 2:29 pm
I can't remember where, but I think I might have possibly seen that plane somewhere before, possibly around here.
fit90
fit90
Post  Cribbs74 Tue Aug 28, 2012 3:01 pm
fit90 wrote:I can't remember where, but I think I might have possibly seen that plane somewhere before, possibly around here.
I don't think Rusty will mind. Heck he is probably in that crowd somewhere!
I wish I knew how to photoshop. I think Roger Daltry swinging his microphone would make a good pose for a CL gag.
Post  fit90 Tue Aug 28, 2012 4:17 pm
I think Roger Daltry would look really good swinging a balck and yellow Queen Bee C/L plane! I know where we can get a picture of a really nice Queen Bee.
fit90
fit90
Post  lousyflyer Tue Aug 28, 2012 5:55 pm
Ok, the secret's out. That's the plane from Rusty's avatar.
But if Joe Cocker could fly, he would do it with a bent elbow. He's that good.
lousyflyer
lousyflyer
Post  RknRusty Tue Aug 28, 2012 5:58 pm
Yeah, I sing You are so beautiful, to Me e e e e to it before I close up the shop every night. lol!
Post  andrew Wed Aug 29, 2012 7:41 pm
I didn't mean to imply that they used the purely straight arm approach and relied only on the movement of their arm up and down. Centainly, on the square manuevers or those needing more deflection, the wrist movement is required for the additional control, but they usually follow their plane with their arm.
At the NATs, I was watching some of the fast combat flyers praciticing. In some situations, they flew with their arm at about a 80 degree bend and almost all of the control was wrist. I have always been amazed at how they can keep up with their plane. Most of the arm movement was just to maintain line tension.
Post  Ken Cook Wed Aug 29, 2012 8:36 pm
Here is a video of one of my club members Mike Palko flying at Brodak's this year. Mike is a innovator of electric control line stunt ships. He scratch built this P-51 (Miss Bardhal) and it's one of the most beautiful stunt ships out there.The entire plane is Sig dope. You can see in this video how Mike keeps himself as steady as possible and just clean well rounded maneuvers. Mike has taken several 1st's this year. https://www.youtube.com/watch?v=dBY2rOEzOJM Ken
Post  RknRusty Wed Aug 29, 2012 8:51 pm
Beautiful.
