» Modelsmodelsby Coxfledgling Today at 4:08 am
» 010 head stops glowing
by Cox International Yesterday at 10:50 pm
by Cox International Yesterday at 10:35 pm
» Unique Foxie partzie. Potential fishing line/paper weight or something else.
by rsv1cox Yesterday at 2:48 pm
by rsv1cox Yesterday at 2:42 pm
» Ignition Points for Ohlsson 23
by Ken Cook Yesterday at 1:58 pm
» Cox P-40 Clone Project - I just can’t leave well enough alone.
by akjgardner Yesterday at 10:32 am
» COX .020 RC PROJECT
by TD ABUSER Yesterday at 9:29 am
by roddie Tue Sep 17, 2024 6:51 pm
» some pics....
by roddie Tue Sep 17, 2024 6:21 pm
by GallopingGhostler Tue Sep 17, 2024 9:22 am
by sosam117 Tue Sep 17, 2024 8:58 am
golden bee running issue
hello, i have had a problem with my golden bee today.
It ran perfectly with one of Bernie's yellow safety props and gave no fits, and as i posted in another topic. I want to turn this engine into a mouse racing engine, and am doing so one step at a time
the things i used today was a apc 4.75x4 1/2a pylon prop with power master 30% nitro fuel and 20% oil.
the problem that i encountered to day is that the engine likes to "surge" at a certain nv setting, but if i lean out the engine when it is surging the problem goes away
also when the engine is surging it seems to have way more vibration as the engine seems to move back and forth about 1/4'' in every direction
what may cause this? im thinking a unbalanced prop may be contributing to this as the engine did not do this with the other prop
and also, i do not have a tach, so could someone tell me from previous experiance what a cox .049 will do rpm wise with a #6 cyl and piston, 30% nitro and a 4.75x4'' prop
thanks, the next mod i want todo with the engine is going to be, swapping out the #6 cylinder, with a #1 black widow cylinder and piston
many thanks in advance, MitchG95
mitchg95- Diamond Member
re: out of balance prop
mitchg95 wrote:hello, i have had a problem with my golden bee today.
mitch: did you try another prop of similar size after the vibration? i think you are right about an out of balance prop. happydad.
happydad- Rest In Peace
Re: golden bee running issue
I had the same issue with my Killer Bee. The threads in the crankshaft were offset, causing to vibrate badly. Once it peaked out, it stopped. Are you using a Killer crank? Swap out the prop screw too, that can do it. Most likely the prop as HD said.
You need a better mount if the engine can move 1/4".
Mitch,
The APC props are notorious for having vibration issues out of the box. Best thing to do is balance them, including blades and hub (they have had a habit of drilling the hubs off-center lately).
Regards, Matt
Regards, Matt
microflitedude wrote:I had the same issue with my Killer Bee. The threads in the crankshaft were offset, causing to vibrate badly. Once it peaked out, it stopped. Are you using a Killer crank? Swap out the prop screw too, that can do it. Most likely the prop as HD said.
i have no killer bee crank or the tool to do so, so i am using the stock babe bee crankshaft, i balanced the prop last night and is perfect i also made a new motortest stand on a 1x6'' hard wood with 1/4'' ply held in with 4 thick wood screws
ill test it again today and see if the problem is gone
does anyone have a used kb shaft that i can use?
mitchg95 wrote:does anyone have a used kb shaft that i can use?
I've got 4 of them, and 3 of those are screwed up. I just traded my last good spare to Ron.
microflitedude wrote:mitchg95 wrote:does anyone have a used kb shaft that i can use?
dang, whats whats wrong with em'?
mitchg95 wrote:microflitedude wrote:mitchg95 wrote:does anyone have a used kb shaft that i can use?
2 have the threads offset, and the other has oversized splines so that you can't install the drive plate.
microflitedude wrote:mitchg95 wrote:microflitedude wrote:mitchg95 wrote:does anyone have a used kb shaft that i can use?
dang, thanks man.
love the avatar lol
i got the golden bee running perfect yesterday. the unbalanced prop is the culprit, so i have all my 1/2a props balanced and ready togo now
thanks
thanks
I remember having and issue like this. The engine would rev up and down real bad. If it was dark enough you could see the red in the ports getting brighter and dimmer. The prop would have a wave appear in it as well. I believe it was a Yellow prop. I just switched props and problem was solved.
Godsey3.0- Platinum Member
Godsey3.0 wrote:I remember having and issue like this. The engine would rev up and down real bad. If it was dark enough you could see the red in the ports getting brighter and dimmer. The prop would have a wave appear in it as well. I believe it was a Yellow prop. I just switched props and problem was solved.
i noticed the prop flexing on my yellow prop to, it looks weird
ill get some pics of it running, maybe even a video
Happy to hear you solved the problem Mitch, I guess you know now the difference an unbalanced prop makes.
having trouble with video's on camera, so here are a couple static photos of the engine after i had it running
stupid camera wont open the file that it made, jeez hopefully a video soon
» The non-issue (to me) of engine RPM's
» 70s Golden Bee not running
» "Racket Is Golden" Bernie's Backplate on a Golden Bee
» Fox .29....issue
» Fox .29....issue
