Now available: Cox Black Widow II - Golden Bee II - Venom II
Finally, they are in stock and available for same-day shipment:
http://coxengines.ca/cox-.049-engine-black-widow-ii.html
http://coxengines.ca/cox-.049-engine-golden-bee-ii.html
http://coxengines.ca/cox-.049-engine-venom-ii.html
Those of you that pre-orderd/reserved; you will be contacted by Nichole this afternoon.
Re: Now available: Cox Black Widow II - Golden Bee II - Venom II
SWEET!! Now to save up for one!
Godsey3.0- Platinum Member
The anodized tanks are also available by themselves:
http://coxengines.ca/8cc-aluminum-fuel-tank-for-cox-049-black-widow-engine.html
http://coxengines.ca/8cc-aluminum-fuel-tank-for-cox-049-golden-bee-engine.html
and the Golden Bee crankcases will be listed as soon as I find some time to take pics and do so.
Golden Bee Crankcase
And here is the link to the Golden Bee crankcase:
http://coxengines.ca/cox-.049-crankcase-golden.html?&cat=44
Could you clarify what type of cylinder and piston that these come with?
Reworked surestarts with the center bar removed? With or without lowering of the port for SPI?
Well all three are interesting, but it only says high performance cylinders at the moment?
The Golden Bee looks like a surestart with the bar removed, but the others are hard to see.
It looks to me like the BW and GB have these on them http://coxengines.ca/cox-.049-black-widow-cylinder-and-piston.html and the venom has one of these.
http://coxengines.ca/cox-.049-cylinder-texaco-medallion-killer-bee.html
But maybe with SPI.
I would rather like to know for sure too!
But maybe with SPI.
Basically, each and every engine we sell has a "Surestart" cylinder; whether modified or not.
Please keep in mind that the Surestart cylinders are nothing else but a #4 Tee Dee cylinder with slit exhaust ports and the bottom port cut-out raised to negate SPI.
Inside they are 100% identical to the #4 TD cylinders Cox used on their later series Tee Dee engines. Try bolting a Surestart cylinder onto a Tee Dee engine and running it. You will see what I mean as there is very little RPM drop. Perhaps 200 for the slit exhaust and another 200 for the non-SPI (SPI makes little difference on rotary valve engines).
All we did was modify these cylinders by removing the bar and/or lowering the port cut-out and, bingo, we are back to a #4.
The Golden Bee and Black Widow engines will have an open port (non SPI) setup and the Venom will have the SPI setup.
Other engines of ours we achieved SPI by using a non-modified cylinder and shortening the piston.
nitroairplane wrote:It looks to me like the BW and GB have these on them http://coxengines.ca/cox-.049-black-widow-cylinder-and-piston.html and the venom has one of these.
But maybe with SPI.
Correct on the BW & GB but the Venom will have this setup:
http://coxengines.ca/cox-.049-tee-dee-cylinder-and-piston.html
Ah OK that is cool.Cox International wrote:nitroairplane wrote:It looks to me like the BW and GB have these on them http://coxengines.ca/cox-.049-black-widow-cylinder-and-piston.html and the venom has one of these.
But maybe with SPI.
Also will the venom come with the 'original' style round driveplate, that the original had, you know the thick round one?
Cool!Cox International wrote:Yes, thick round driveplate
Those are beauties Bernie. Thanks for bringing them back. And I'm thinking your RPM claims for the GB and BW with a 5x3 and 25% nitro are pretty conservative.
Psssst, I heard a rumor about Tee Dee .049s being resurrected. Any truth to that?
Well, we are using the non-SPI cylinder on the BW and GB so it's about 2,000 RPM less than the Venom.
And, yes, we are currently researching parts supply for a Tee Dee 049. Should be identical to OEM, except that we will go with an aluminum carb body.
If the project pans out it would be for Fall/Winter this year.
I just started my Christmas list.Cox International wrote:And, yes, we are currently researching parts supply for a Tee Dee 049. Should be identical to OEM, except that we will go with an aluminum carb body.
I want the venom..........guess I should stop buying used for a while. Do you have layaway Bernie?
I wonder how long a Venom will run at that blazing speed on 8cc of fuel. Probably 60 sec. My fastest Black Widow gets about 1:35.
New .049 Tee Dee's. That would be super. If you continue like this, it feels like Cox is back in action!
Hmmm. Might save my duckets for a couple new production Tee Dee's. Then again, maybe do a tri-fecta with all 3 of the latest offerings.
Decisions, decisions,,,,,
Will the alum carb body's have the raised rib between the cylinder and the threaded portion. It's the rib that locks the RC-05/09 oem muffler so it wont spin on the cylinder. Recently came across a couple nip Rc muffllers and was just curious. I know they are few and far between, but it would be nice to have that option if going thru the trouble of making alum bodies
cribbs74 wrote:I want the venom..........guess I should stop buying used for a while. Do you have layaway Bernie?
No need for a layaway as the engines will all be stock items for the forseeable future. Pricing may creep up but that's about it.
PV Pilot wrote:Hmmm. Might save my duckets for a couple new production Tee Dee's. Then again, maybe do a tri-fecta with all 3 of the latest offerings.
The plan is to have a "regular" carb body, such as we use on this product:
http://coxengines.ca/cox-.049-051-tee-dee-medallion-rc-conversion.html
Cox International wrote:]The plan is to have a "regular" carb body, such as we use on this product:
Well, that answers that.
Thanks for the reply Bernie.
» Cox .049 Texaco – Back Widow – Venom - Golden Bee - 8cc Tanks
» (Found) Black Widow/Golden Bee Backplate
» Venom Clone - Black Widow - Banana
» Wanted: Black Widow or Golden Bee
» Cox Golden Bee or Black Widow Wanted
