» Vintage Vornado fan projectby roddie Today at 3:28 pm
» AJ/JW .020 Firebaby Jr. Pretty neat
by rsv1cox Today at 2:58 pm
» Interesting ebay C/L carrier model w/Super Tiger
by rsv1cox Today at 2:34 pm
» *Cox Engine of The Month* Submit your pictures! -July 2024-
by sosam117 Today at 11:26 am
» The "Funky Bee"
by GallopingGhostler Yesterday at 8:46 pm
» Eye of the beholder - Two beautiful things
by rsv1cox Yesterday at 7:32 pm
» Internet buy
by Cribbs74 Yesterday at 4:45 pm
» Simple Gliders
by getback Yesterday at 11:57 am
» Set Up for Semi-Serious Stunt on Norvel .061 Big Mig
by DanMc Yesterday at 10:25 am
» Fox 07 R/C
by davidll1984 Yesterday at 7:12 am
» Scratch-Build 2021
by roddie Sat Jun 29, 2024 1:31 pm
I have been playing with some smaller models for a while and recently acquired a Doodlebug stunt model , designed by Wild Bill Netzeband and this model was built by the late Jim Wilson, who was a local modeler here in St. Louis and had several small models published in the magazines over the years. Jim was very good at operating diesel engines and I'm betting that is what he had on the model, but I wanted to try a Norvel .961 Big Mig for the extra power, since it is a large model and I had hopes of flying it on longish lines.
I have been having mixed results with the effort and have trouble getting consistent runs. Some flights are great, then a simple refuel and launch with out changing anything results in a flight that has the engine lean out and speed up, go rich and too slow, run along time on a measured amount of fuel , all over the place as far as performance. The engine has been broken in, and I have tried numerous props, fuel, and tanks. Sometimes it will go through 1 1/2 ounces of fuel , run like I want it to, and then keep running for 8 to 10 minutes. Lots of run away runs. I have tried standard tank, like a perfect #8 I think it is, and modified one with a better arranged pick up tube but still standard vent, and another one with a relocated pick up to better feed the engine with a shorter fuel line and a uniflow vent. This tank has shown the most promise but still no repeat consistency and have tried venting to atmosphere and muffler pressure. The muffler tend to work loose and wobble, since it's retained with a simple wire bale, and thinking this might be the source of the problem, I glued the muffler to the flange with a small amount of red silicone to seal it and replaced the spring wire bale with some safety wire attached in the grooves front and back and then twisted on the back side to really secure the muffler and the silicone to seal it. The first flight today was VERY promising and performed exactly as I had hoped, but the next flight went astray again!! Fuel has been experimented with ranging from 10% SIG type fuel to 15% all synthetic and 15% SIG type fuel but at 18% total oil. I planned on trying some 25% nitro fuel but forgot the bottle this morning. I know the more nitro I have will allow the needle to open more and hopefully a consistent run but results still vary. I have two head gaskets in the engine and wonder if I have to add more??
I have run these things for many hours on the TuffBaby trainers at Oshkosh, but that was just round and round training flights. My next thought with this is to get some supplies for bladder pressure and try a bladder on it and see what happens, and also go up the nitro ladder with 20% and 25% being in the que for the next flying session. So far, prop hasn't made a huge difference, but I'll keep experimenting. Does anyone have a set up that works well for them that I can try? One of my big problems is hearing the little booger!! I can't tell most time if it's slowing down because it's too lean or too rich?? Too rich will generally keep running. Too lean will usually quit. When things work correctly, this airplane flies pretty nice for a small model and my intensions are to just fly it like i do my other sport airplanes, but I gotta get a consistent run first.
Any suggestions for a set up for the Norvel Big Mig .061??
Type at you later,
Dan McEntee
Type at you later,
Dan McEntee
DanMc- Gold Member
Re: Set Up for Semi-Serious Stunt on Norvel .061 Big Mig
Hi Dan, Are you getting one good initial run from a cold-start? Wondering if the engine has its issues once it heats up? Which DoodleBug do you have? I'm no expert by any means.. but if it's the "330".. maybe it's too much airplane for that engine?
http://airfieldmodels.com/gallery_of_models/control_line/doodlebug_330/index.htm
(EDIT) Bill N. scaled the design down to 168 sq. in. for 1/2A. Is that the model you have?
Which cylinder technology do you have, ABN or revlite?
I feel that the revlite technology (ceramic) needs a full castor fuel. I run mine on 10% nitro and 20% all castor fuel and have not had any issues. They also like a small props, a 6x3 is about maximum load for it, they run much better on eg the APC 5.7x3 or 4.7x4 props.
I'm not totally convinced your tank isn't suspect. In addition, as I mentioned on the other forum in regards to what version your using. A Rev-Lite engine uses the bolt in venturi and it has a real POS o-ring under it. This can cause all kinds of problems if it's not sealing.This can be remedied by even using JB weld around the perimeter. I like to apply it and then clean it with rubbing alcohol as it removes it instantly and allows it to flow into crevices. This can easily be removed with a paint stripper style heat gun. I personally find most of the Norvel needle valves to also be sub par in regards to dialing one in. I prefer using Cox needle valve assemblies in mine. Take a postage stamp backplate 128 TPI spraybar and needle and remove it from the Cox backplate. The will require a bushing such as a piece of K&S 5/32" tubing and the Cox spraybar soldered inside of it. You need to file a break out hole in the tubing so that the hole in the spraybar aligns with the breakout hole. I then JB weld this assembly into the venturi.
As for the tank, I would certainly pressure test it first with a large syringe and insure that it's not leaking. I personally wouldn't use ANY Perfect tank without removing the back and insuring that the pickup tube is soldered in the correct spot. If the tank has been modified for uniflow, is the uniflow pipe properly spaced back off of the pick up tube?
Some of these issues certainly sound like vibration. Run away issues can typically be a result of the engine not getting enough fuel and it's off to the races. I would isolate the tank by possibly wrapping it with bubble wrap and then firmly attach it. I certainly wouldn't be opposed to adding a spritz of Armor All to the fuel as I've seen this produce magical results and it's a easy test. And for those that call me out as this is BS and it ruins plugs, please post your ruined plugs for the rest of us to see. My flying partner has been doing this for 25+ years and he's into the hundreds of hours in regards to flights every year. I personally never seen a single issue from doing so assuming you use Original formula Armor All.
I just posted this update to the thread I have on Stunthanger in the 1/2A section on that forum. Thanks to everyone for your input!! I'll update things once I get to test fly the airplane again.
Thanks for the input gentleman!! I've been thinking this through, replaying in my mind what I've experienced, and compared that to your responses. Like I said, I have hundreds of hours of experience with these Norvels in a trainer mode, and I can get just about any 1/2A engine, and others, to do what i want them to do. Cox, Fox, OS, ST, Enya, Saito, they are all in my engine footlockers and all get used at some point. This engine came out of my Norvel stash of both .049 and .061 engines, both Big Mig and AME versions. I'm gonna answer some of your question while I cool off from test running the engine in the drive way, and I see an improvement tonight while testing glow plugs.
Glow plugs: I have everything that has been recommended in the way of glow plugs, here and on the thread I posted on C.E.F . I have some Merlin plugs with their head, I have some of what I think are stock Norvel, I have both standard and TD Cox .049 glow heads, and I have both the Kamteknik and Galbreath heads for Nelson plugs with a good supply of Nelson plugs. Kenneth Cook: I compared the Merlin plug side by side to the Norvel plug. The merlin plugs I have look like they have a smaller coil, in a smaller hole in the chamber. The Norvel look much larger, on the order of what you see in a Cox head. I think that would make the Norvel a hotter plug, would it not? If things go well and it turns out my problems came from a boogered up spray bar and needle, I'll try them both later.
Props: I don't have a huge selection, and none of the 5" APCs that have been mentioned. I may trim one of the 5.7-3 props I have down and see how that goes. I have Cox 5-3 gray, some Tornado 5-3 three blade props like Larry Renger said he really likes, and some Tornado 5-3 two blade. I think I have some small MAS three blade in their new design that I have to dig out yet but not sure what size.
Tanks: the tanks I'm using start out as Perfect tanks, but I have pulled the end cap off and reworked the pick up tubes. Some of these are the #8 tank (I think) that is supposed to be a 2 ounce tank but really only holds about 1 3/4 ounce, and the pick up tube comes out the top of the tank about half way back from the front. On the ones I have taken apart, both pick up tubes were way high and like Ken said, not anchored at the back. I made one #8 tank that is standard vent with a new pick up tube that exits in the middle of the front end cap, and angles down to make fuel line routing better. All tubes are 1/8" copper. and I'm using medium fuel line to feed the engine. This idea comes from some stuff I have read and talked with people about flying the big tuned pipe engines and using bigger than normal pick up tubes and fuel line on their models. I am using the pink Prather fuel line. When the engine is running, I can really see what the fuel is flowing like.. I built up another #8 that is uniflow with a new pick up tube and the uniflow went is anchored about half way up the pick up tube, which exits about the same place the other tank does and turns 90 degrees down. I also have a Perfect tank that is a 1 1/4 ounce tank, standard vent, that is more or less brand new and I haven't opened up. In flying this airplane so far, all these tanks seem to run pretty much the same.. I started with a 2 ounce plastic tank, because it would fit, and I had one, but could never get it to run a whole tank of fuel out. I was figuring I would need a capacity of 1 to 13/4 ounces to do a full pattern comfortably on 42" to 44" length lines, and so far I have been in that range and will stick with these tanks and keep testing.
Fuel: I have tried standard SIG 10% Champion because I have run these on this before and it's my main go to fuel. Never had any problems. I have run 15% nitro Cool Power with some castor added with no real improvement or changes, and no obvious problems with it either. Before the last flying session, I had found a gallon of Byrons 15% nitro, 50/50 oil in my stash. I have a quart of Norvel brand fuel ( probably made by SIG, as it looks just like their mixes and they were the original importer of the engines) and it say 18% total oil on the label, so I added enough extra castor to get it up to that and maybe a bit more. I ran this fuel last time out, with a few drops of Amoral in it ( I have ALWAYS kept a small bottle in my flight supply bag and have never had any plug issues from it either) and I think the engine ran best on this mix so far, so I will continue with that. I'll try a few tanks of the 25% Norvel stuff next time, especially if things have improved, I have the supplies now to mix anything I want, also.
The Model; The airplane is a Wild Bill Netzeband Doodlebug. I am pretty sure it's the middle size airplane from the article he presented in the February 2003 Flying Models magazine called "The Doodlebug Brothers". it's about 25" span, and with a chord of 8.75" that puts it in the 200 sq.in. range which would be the middle model of the three sizes he presented in that article, with the smallest being for .049, the middle one intended for the .061, and the largest one is intended for the .074. It weighs 12 ounces I think, and when things have been right, the .061 pulls it just fine, with the engine running ( I think ) in the high 17,000 to 18,000 RPM range and it flies just fine on the 42 to 44ft fishing line I'm using.
The engine: I think it's a Norvel .061 Big Mig , with the bigger diameter head and cylinder. It may have come off a Bratco Sky Baby or Hexdrone airplane. It might also be a NV version. The needle valve goes back at an angle which I like. It has the bolt on venturi. I had an inverted landing early on in this project which bent the spray bar. I did not have a spare, so I had to straighten it out. NV engine didn't have any new ones in stock for a while. Sometime this year I saw they had complete venturi with the NVA in it so picked up a couple of those. I did a standard break in, which I am very familiar with, after all of them I have run and used at KidVenture, but this one had a bit of time on it and it was no trouble at all. Still has quite good compression, and only sticks at the top of the stroke when it's stone cold and no fuel in the cylinder. it starts right now with a 1/2 electric starter. I found a good deal on one of those long, black GlowBee battery powered starters with a charger on eBay once, and now it comes in handy with some new batteries. I solved the loose muffler issue by gluing it on with red silicone and replaced the wire bail that it comes with to hold it on with some safety wire on each end, then twisted the two ends on the back side of the engine to hold it tight. I have to run the muffler for the pressure fitting.
Last session, the last several flights all seemed to slow down from things going rich, just slow enough that I couldn't fly the pattern. It did it with the uniflow tank and with the 1 1/4 ounce tank, almost exactly the same each time. After reading everything you all have posted here and on C.E.F, and thinking about what I have done so far, I took the following actions. Today, I pulled the venturi off. It had never been off before and it feels like it's almost a friction fit in adding to the O-ring and bolt through the venturi to hold it in place. I was going to use a whole new assembly, but when I tried to put it in, it didn't fit well, and the spray bar went straight through so the needle was NOT swept back like the original. That made it really hard to put the fuel line on the nipple because the end of the muffler is in the way. So I just pulled the spray bar out of that venturi, and pout it in the old one, and used some red hi-temp silicone to help seal it when I put it back in. I also put a short length of fuel line on the threaded portion before putting the needle in, like we do on a lot of engine, to help seal the thread against air leaks. I had been running it like that the last few time out and it seems to help. Kenneth Cook : I have noted the idea of building up a one of these new venturis with the Cox needle valve assemble that you made mention of. I have all the stuff, but didn't want to get that deep into it tonight. I put everything back together and headed out to the driveway to test glow plugs.
I started out with what I thought would be the bottom rung of the ladder, and that was the stock Cox glow head, like 944_Jim suggested. ( Thanks Jim!!) I have run some of mine with these before and knew that would fit. Al Kelly clued me in that the Norvel, Cox and Testors heads would all interchange. The threads were really just ever so slightly different, but not enough to cross thread them or cause any problems and I have found that to be true. I used the same 15% Bryons fuel I spiked up with some extra castor. I shook the bottle and still no foam. Engine started easy as usual, needled it in slowly through 17,000 RPM and then about 17,500, it quit like it was over lean but really sounded like it had just got into a wet 2 stroke. I repeated this several times and it did it at the same tach reading , so I made note of that and moved on.
The next plug was a Cox TD high compression head. The only difference I can see in these is that the combustion chamber on the standard head is bigger, and the TD head is more flat across the bottom surface. I installed that, fired it up and got more RPM, into the 19,000 range and higher but didn't go so far as to see when it went over lean and quit. It seemed to run much better, much more steady that previous static runs. Before, it would seem to needle Ok , then hit a spot where the RPM would just take off, right about the high 17,000 range like I need it to be. I added a head gasket but that didn't seem to help at the time, and I left it in there, so there are two head gaskets still..
Next came the Galbreath/Nelson plug combination, again with two head gaskets. It seemed to pick up right where the Cox TD head left off, very similar run, but seemed to needle a bit better. I could put it anywhere I wanted between 17,500 and 18,200, which is where I think I want it. Run time on a full 1 1/4 ounce in the standard vent tank ran very smooth and consistent. Up to this point, I wonder how necessary uniflow is on these engines in this RPM range?? Flight tests will help answer that question. I can make more of these tanks with a uniflow vent in this capacity, maybe 1.5 ounces, if need be.. When running in these tests, I can see just a few bubbles , and I mean very few, ever now and then. The fuel line stays clear, almost like there is nothing in it. I have one of those small diameter fuel filter in the middle of the fuel line, after thinking that I needed that , plus filtering my fuel when getting a syringe full. I did not try the Kamtechnik head, because when compared side by side to the Galbreath head, the head surface and combustion chamber size looked the same, so I don't expect a big change, if any, when I use it. I'll try it after test flying a few flights.
One things came to me while I was typing out this diatribe!! I have some of those Wasp .061 R/C engines that Hobby People used to sell so cheap, and some one used to put out a replacement venturi for them that used a TD spray bar and needle. I am pretty sure there are some extensive threads on here on how some guys did their own modifications. I made up a couple of my own and installed them, but never ran them. If this engine continues to give me fits, I can just swap it out for the Wasp .061 really easy. I think I remember the engine getting good reviews for power and being pretty much like the Norvel. I'll dig one of those out and look it over. Maybe the muffler will interchange if I have to use these straight verturis from NV engines?? More experiments to come.
I have several 1/2A stunt kits in my stash, plus a whole pile of plans and other ideas to try. Now is the time to get to them!! I really liked the
Leprechaun Legends planes that I have plans for also. My first real 1/2A stunt model was a Gremlin, that I still have, that I blew the plans for it up out of Model Builder magazine and built it with the wood from the Admiral River Boat life preserver balsa wood!! I powered it with a TD .049 and it was the first C/L stunt airplane that I ever did any outside square loops with!! I may get that down off the wall, recover it and put it back in action!! Thanks a lot to all of you again for your input and suggestions. Dave Moritz : Thanks for the email with the engine information. I will save it to my computer and print out some hard copies for future reference. I again thank everyone for taking the time to respond and I will update after test flying again, possibly tomorrow.
Type at you later,
Dan McEntee
Type at you later,
Dan McEntee
DanMc- Gold Member
Dan, as you mentioned it becomes difficult without several test flights to determine needle due to muffler. I prefer no muffler but sometimes it becomes a necessity. As for uniflow, I run many of these on standard vent but as your aware of, this can go south in the end of the tank. However, if your going for the cloverleaf, as long as the engine is lean, this will get you out of trouble on the bottom end of the outsides. The real problem is the speed and rather than making nice loops, they tend to become egged because once it gets over the top it's screaming back for the ground.
I would opt for uniflow and you can always cap the uniflow and run standard vent if needed. As for determining Big Mig vs AME, this is simple. Appearance wise, it's very difficult to determine one from the other. Some used a needle just for the one particular version and then I started to see in the end that parts were being interchanged. Remember, at one time these were going out the door for under $20 and some with no box or box damaged were going for $10. I have at least 6 in the improper boxes.
To insure that you know your porting, remove the head. The liner will have 5 cutouts if it's a Big Mig and 3 large cutouts for a AME. The AME uses a very large venturi and this causes severe fuel draw issues on suction. It runs best on bladder but it will work with a good sealed muffler pressure setup or backplate pressure nipple. Using backplate pressure is not recommended. You would need a pinch off and a better needle and if you need to do that just use bladder. The outlet hole in all of the Norvel backplates use too large of a pressure nipple. You only need a hole of about .012"
I recently used the new MA 3 blade props and found them to be absolutely useless. They're also not inexpensive and they don't work. Who ever designed those needs to go back to school. Blades have no area and are thinner than a pencil. They look great as far as scale appearance, they do nothing because they offer no drive. I tried them on Cox engines and I didn't even get a 1/2 circle in before I ditched it in the high grass and immediately removed them. I've always found that one APC 5.5x2.5 to work terrific for .049 Big Mig's and the .061. Some have mentioned the 6x2 APC, I found that to beat the air to death and it sends the rpm's over the top.
The 5.7x3 APC has two different versions. My latest appears to what looks like a electric prop blade and the root area is so thin it almost looks scary to use. I have a older 5.7x3 which has broad blades and it looks like proper prop. These engines don't like pitch and seeing your wanting to stunt, you need drive and this is where the 5.5x2.5 works. The square eights can really taxi your plane and you need continuous speed. You ESPECIALLY don't need to lose speed in the overhead eights as well as this can be extremely problematic especially making the ascent to the overhead.
On another note, I prefer the Magnum black Tornado vs the white rubbery ones for Norvel use. What I've discovered more than once is how out of parallel the drive side of the prop is to the face side of the prop. I've tossed them into the lathe and trued up both sides prior to use. Of course this is only accurate if the hole is square to the blade but it certainly helped what I was experiencing. I'm not certain as to how your using the APC props to properly fit the prop screw. I developed a bushing for these and I used to sell them on EBAY. I certainly would like to make more of them and I will see if I have more in my stock. The bushing is a direct fit for certain props and it works in conjunction with the APC spacers on others. I developed this for the sole purpose of 1/2A combat. I didn't new to be screwing around with tubing for a quick prop change. These were something I made when I could and I had some complaints about the cost on EBAY. I can insure you I was making no money at making them and selling them.
Merlin used a very fine element wire, this glows white not even orange. As I mentioned before, they work but they can cause pre ignition especially using higher nitro or the day is hot. I prefer to only use them in a emergency. They work, they have fair duration. They're irreplaceable and this is one reason if your looking for back to back consistency not to use them. They tend to require a lot of head gaskets over the others and I don't care for that.
Thanks for the extra info Ken. I dug out the Wasp engine last night that I modified for the Cox venturi/needle valve, and while looking at the carb assembly, I took the needle out. It fits the Norvel spray bar, is about the same length, and is a much more tapered shape. I will do a test run with that sometime today. i can see chucking up a Norvel needle in a lathe or even a drill press and reshaping the taper on those. It really is pretty blunt and steep when you compare it to something else. I do the same thing with the last run of OS needle valves from OS that came in the blue and white header cards. No where near and sharp and tapered as the original FP needles were. If the Wasp needle is more effective, I wonder where there is a stash of parts? I still need to take the carb apart to see if the spray bar is removeable and useful to transplant some where else. I have 4 of these engine , so will make best use of them. I think I have both versions of the APC 5.7-3 that you are talking about. Gonne go through those and then hit the APC website and see what's available later today. keep me posted if you make any more of those adapter bushings. So far, I have been able to get decent fits with using standard plastic tubing. Weather today too windy for flying but tomorrow is looking good. This is what retirement is all about!!
Thanks again,
Dan McEntee
Thanks again,
Dan McEntee
DanMc- Gold Member
» SOLD Please Delete - Norvel .061 Big Mig stunt
» Any interest in a Semi-Scale TD-4?
» S.M.A.L.L. 2017 !! The Boys Are Back in Town !
» NORVEL .061
» NORVEL .061
