» music vids.. some of your favoritesby roddie Today at 12:29 pm
» Set Up for Semi-Serious Stunt on Norvel .061 Big Mig
by Ken Cook Today at 12:28 pm
» Internet buy
by bsadonkill Today at 12:27 pm
by roddie Today at 8:29 am
» Fox 07 R/C
by Surfer_kris Today at 7:29 am
» Cox PT-19 Trainer.
by roddie Yesterday at 10:26 am
» The Breezy Hill Flyers' "Chester Area Christian Food Pantry" Fun-Fly.
by roddie Yesterday at 9:24 am
» B-25 repaired
by rsv1cox Thu Jun 27, 2024 6:29 pm
» Wanted: O.S. Max .10 "Bow Tie" Engine for Parts
by Ken Cook Thu Jun 27, 2024 5:03 pm
» Simple Gliders
by rdw777 Thu Jun 27, 2024 12:16 pm
» **Black Lynx Engine Giveaway Jan-June 2024** Cox Engine of the Month
by roddie Thu Jun 27, 2024 8:44 am
by getback Thu Jun 27, 2024 6:58 am
Fox 07 R/C
Fox 07 R/C
Anyone got a set of operating instructions for one of these that you could scan and post? I picked up a couple of 07 R/Cs a few years back...but no boxes or paperwork. Its time i gave them a run-with a possible view to having one or both earn their keep in a model...!
What I'm really after is the detail on setting the throttle and idle mix-since it uses Fox's fairly unique (for the time) high and low speed adjustable jets. Its by no means certain that mine haven't been fiddled with by past owners, so I'd like to see the factory instructions regarding adjustment.... Note that the standard Fox 07 instructions will not have this info....and in any case the 07 r/c is a quite different motor..
ChrisM
'ffkiwi'
ChrisM
'ffkiwi'
ffkiwi- Gold Member
Re: Fox 07 R/C
Is this what your looking for >> https://sceptreflight.com/Model%20Engine%20Tests/Fox%2007%20RC.html
Re: Fox 07 R/C
No-that's the engine test-which I'm already familiar wirh...what I want is the actual operating instructions that would have come with the engine when purchased brand new.....normally a double sided pamphlet. Mecoa has most of them in archive form on their website-but they only go down to 09-as the rights to the 049 and 07 engines were sold off by Fox to Richard Rikel and his partner back in the early 90s...H&R Engines-the guys who reintroduced the Fox 049 FAI Special-long before Mecoa acquired the Fox line.... Of course the Fox 049/07 engine residue changed hands several times subsequently.
ChrisM
ffkiwi'
ChrisM
ffkiwi'
ffkiwi- Gold Member
Re: Fox 07 R/C
Hello ChrisM, I'm sorry I can't help, I'm just leaving my message to congratulate you on the acquisition, I didn't know about this engine and from the link Eric left, I see a beautiful R/C engine....congratulations and if you want it at some point, of gear to the engine, it will be a pleasure to see it working here. Thank you!
MauricioB- Top Poster
Re: Fox 07 R/C
MauricioB wrote:Hello ChrisM, I'm sorry I can't help, I'm just leaving my message to congratulate you on the acquisition, I didn't know about this engine and from the link Eric left, I see a beautiful R/C engine....congratulations and if you want it at some point, of gear to the engine, it will be a pleasure to see it working here. Thank you!
Mauricio-they don't crop up that often-but they do appear on Ebay from time to time....as does the standard 07...also known as the 'Fox compact stunt motor'....the 07 R/C being 15 years ahead of its time-and 25 years ahead of its time in terms of a throttle for its size category-we had to wait till the MP Jet 061 appeared to get a throttle of similar refinement.....its a pity there was no really lightweight gear around at the time-other than cascaded escapement type single channel-that would have allowed it to really make its mark. As the engine test noted-other than capacity, there was very little parts commonality between the 07 and the 07 R/C other than the P/C set and glowhead.
I haven't run either of mine yet-but want to have at least some written backup in the event that the throttle settings have been fiddled with-and Fox throttles-at least of this era -were adjusted a bit differently to modern types and I have to find the correct settings. Powerwise-according to the tests both versions are up there with a Cox Medallion 049 or Black Widow-but capable of turning larger props-7x3 or 7x4-which is no bad thing-about 16% more swept area-which ought to suit some of the classic 1/2A designs from the 60s and 70s. In any case I'm by no means short of throttled 1/2A engines-so if these get used in anger it will be in something period appropriate.
ChrisM
ffkiwi- Gold Member
Re: Fox 07 R/C
Sorry Chris , I didn't read the whole article till now and see there is no reference to what a starting point would bee for the adjustments . Sounds like a interesting engine to run hope you can get it figured out .
Re: Fox 07 R/C
(deleted) sorry... I posted the engine test same as Eric did..
![Embarassed](https://2img.net/i/fa/i/smiles/icon_redface.gif)
Last edited by roddie on Fri Jun 28, 2024 11:50 am; edited 1 time in total (Reason for editing : deleted redundant info.)
Re: Fox 07 R/C
getback wrote:Sorry Chris , I didn't read the whole article till now and see there is no reference to what a starting point would bee for the adjustments . Sounds like a interesting engine to run hope you can get it figured out .![]()
no biggie-Eric and Roddie-the test itself I looked up as soon as i acquired the two examples. I'm just taking precautions in the event that the settings have been fiddled with. If they had, without knowing what the factory suggestions are, any adjustment by me could make things worse rather than better......mainly as regards idle mixture.....the setup as noted in the engine test article is a bit different to what is normal these days-with the low speed jet always in use and the high speed only functioning at full throttle...
As I noted-many years of collecting and using engines have borne out the truism that if something can be unnecessarily fiddled with.....it will be....and especially with diesels. i've lost count of the number of engines that have passed through my hands with the liner in backwards, or the piston 180 degrees out..!
ChrisM
ffkiwi- Gold Member
Re: Fox 07 R/C
Chris, it's hard to believe this isn't a simple Google search but it isn't. Sadly, we no longer have Bill Mohrbacher to offer his manuals. Bill would immediately know what to do. I know some Fox carbs are much different then others whereas you adjust the low first and then the main. I'm not certain if the .07 carb requires this feature.
Re: Fox 07 R/C
Unfortunately I don't have any manual either...
You can get a rough check by blowing into the fuel line, a slight hiss usually works as a starting point. From what I remember the low end setting isn't very critical. Instead one would run the "low-end" well on the rich side, this gives a two-throttle setting, a rich low rpm setting a higher revving lean WOT. One should not expect a true proportional throttle like we have on more modern engines.
Here is a picture of one of my engines and the low-end setting:
![Fox 07 R/C Img_1111](https://i.servimg.com/u/f39/17/14/65/91/img_1111.jpg)
