After Run Oil Cox_ba12
After Run Oil Pixel
After Run Oil Empty
After Run Oil
After Run Oil Empty After Run Oil
Post  davehour Fri Oct 07, 2022 4:58 pm
Hi guys,
Searched for “after run oil” topics in the forum with zero results. Didn’t expect that, LOL.
I would like to know what are your preferences and why.
Thank you.
davehour
davehour
Bronze Member
Bronze Member
After Run Oil Empty Re: After Run Oil
Post  rsv1cox Fri Oct 07, 2022 5:19 pm
davehour wrote:Hi guys,
Thank you.
Oh, oh, always a debate point.
I have expressed my views here before.
WD-40 - For me a big NO NO.  Gummed up so many of my early engines until I wised up.
Flush with Remoil, blow out with compressed air, flip, flip, flip.  Blow out some more. Add a drop or two of Prather or Great Planes after run oil in the exhaust port and intake, flip some more CW CCW. Wipe dry.  Store.  You will never have a problem.
Post  Yabby Fri Oct 07, 2022 7:06 pm
lol! I Love This Forum! This Site Rocks! The ony argument area of disagreament over anything on this forum greater than "After Run Oil" is "SPI" and what it does/can do. lol!
I clean the venturi holes, Venturi, and NVA on my TD engines with Metholated Spirits, as it is so easy for one of the sprinkler holes to block, after each days flying. When I am flying through the season, I rarely use and form of after run oil as I use a fair bit of castor in my fuel (again for greatly disputed reasons. Lol. ) If my engine will be sitting around longer than about 3 weeks without running, then I flush the engine with Metholated spirits, and put a few drops of singer sewing machine oil down the venturi and work it through by flipping the engine. I dont always do that either, and have found my engines are fine. but with my TDs I always clean the Venturi, squirt through the sprinkler, NVA, clean the needle, and take the needle tubing that seals it off and clean that, as sometime stuff hides in there. Lol.
sunny Flying cheers
Yabby
Yabby
Yabby
Post  andrew Sat Oct 08, 2022 2:30 am
rsv1cox wrote:........
Agreed -- same for me.
For after run oil (if not flying for up to a month), I'll add a drop or two of Air Tool Oil -- it has some anti-rust properties.
For long term storage, a 50/50 mix of ATF and Marvel Mystery Oil. Give the engine a good dose, flip through to spread around and expel any excess, then into a plastic ziplock, squeeze out as much air as possible and zip up.
Post  Yabby Sat Oct 08, 2022 4:33 am
yep, Andrews approach is a pretty sound one to follow! Thumbs Up the WD-40 for after run purpose is evil. Lol. I like the air tool oil idea, as it gets in everywhere, (bit like auto trans fluid) and the idea of putting the engine in a zip lock bag with the air expelled is a good one. Maybe some of these ideas are a bit overkill as we dont do this stuff with bigger engines to the same extent, but then again, we can do it easily to the Cox engines, and it can only be beneficial, not do harm. Mind you, the zip lock bag means I would need to clean the outside of the engine properly. Lol. As it seems methanol, nitro, castor, seems to destroy zip lock bags. lol! but good protocol Old Bugger Thumbs Up especially as the Cox engines and their parts become harder and harder to source, five minutes of preventative maintenance becomes very worthwhile.
cheers Flying sunny
Yabby
Yabby
Yabby
Post  getback Sat Oct 08, 2022 7:15 am
Air tool oil because, it's what i have on hand all the time and it works with out failure. I should put some of my engines in plastic bags, period . Pumpkin Small Cox Logo Pumpkin
Post  balogh Sat Oct 08, 2022 7:27 am
https://coxengines.ca/field-gear/coxlube-after-run-oil.html
I have been using Bernie's oil for as long as I remember, with good results.
Because I use party balloon tanks almost exclusively, I evacuate the tank and fuel line up to and including the venturi by pulling on my fueling syringe with the fueling line attached.. The vacuum will clear the entire fuel tank and path including the very small venturi holes even in a TeeDee010. So castor will not stay anywhere it should not.
Then I remove the glow head and apply 2-3 drops of after run oil on the piston top on TDC, making sure the oil flows around the full piston circumference, and crank the prop a couple times so an oil film will form on the full cylinder and piston surface..screw the glow head back and wish the engine good night..
Post  rsv1cox Sat Oct 08, 2022 8:07 am
Air tool oil ranks high on my hit parade too, and I have both, Marvel and Campbell Hausfeld. But Remoil works best. However it has gotten crazy expensive so I have snuck air tool oil into my Remoil dispenser bottle.
After Run Oil P1014259
I think Marvel's air tool oil is mostly Marvel Mystery oil, looks the same and smells the same. Marvel and I go back many years, when I used my last can (not plastic) I cleaned it up and saved it right here next to my computer.
After Run Oil P1014260
One thing (for me the only thing) that WD-40 is good for is cleaning the crud off the top of 100,000 + mile pistons. Works great in that application.
After Run Oil Empty wd40 is better then nothing
Post  cmulder Sat Oct 08, 2022 8:29 am
I agree that wd40 gummes up over time but that time can be years depending on environment.
Advantage is its relative easy to buy and relative cheap.
It does protect engines from corrosion.
So if wd40 is all you have then go ahead and use it just be aware of its limitations.
Once you got a better oil then flush the engine with isopropyl alcohol and relubricate.
cmulder
cmulder
Post  andrew Sat Oct 08, 2022 9:34 am
rsv1cox wrote:..............But Remoil works best.  However it has gotten crazy expensive so I have snuck air tool oil into my Remoil dispenser bottle.
A man after my own heart.
I tell my friends I'm simply being frugal -- they tell my not to confuse frugal with being a cheap SOB.
Post  rsv1cox Sat Oct 08, 2022 9:49 am
Smile Smile
Greenie Andrew.
Post  GallopingGhostler Sat Oct 08, 2022 11:03 am
andrew wrote:I tell my friends I'm simply being frugal -- they tell me not to confuse frugal with being a cheap SOB.
I am perhaps some of both. Doh! There is a limit to expenditures. I have learned that it is more important to have fun and enjoy yourself, than follow the crowd and spend beyond your means (especially if it means to accumulate debt) just to please them.
RC Plane There is more fun for me flying a single channel R/C aircraft even without motor control, Very Happy than I would with a 4+ channel .40 pattern plane. Laughing About the only thing more fun is a .35+ control line aircraft on 60+ feet of line. There, going big is better. Tired w/ Coffee Read Smoking
Regarding tool oil, I believe that this is simply mineral oil, which is about as simple and unadulterated as one can get. Surprised I have used it to supplement my hydraulic jacks and other lubricating uses.
Post  Marleysky Sat Oct 08, 2022 11:58 am
Thank you.
Well ya got a few responses anyway... Change your search term to "after run" and check the Google box and it'll bring up a few more conversations from the way-back machine:  2017
https://www.coxengineforum.com/t11220-maintenance-after-run-and-storage
Post  davehour Sat Oct 08, 2022 2:14 pm
Thank you guys for those great and informative posts. Please keep them coming.
Funny, searched for “after run” too and no return. Didn’t get the thread link given above which has “after run” on its title.
davehour
davehour
Bronze Member
Bronze Member
Post  davehour Sat Oct 08, 2022 2:16 pm
Thank you.
Thanks for the tip!
davehour
davehour
Bronze Member
Bronze Member
Post  davehour Sat Oct 08, 2022 2:22 pm
I was using Corrosion X as an ARO as it’s said to be one of the best rust inhibitors, lubricants and penetrants oils. I just started using Marvel Air Tool oil. I like it.
Any comments about Corrosion X?
davehour
davehour
Bronze Member
Bronze Member
Post  Ken Cook Sat Oct 08, 2022 2:42 pm
I use Marvel air tool oil also and I've been using it for about 6 years now. I like the fact it doesn't inhibit starting. Use caution if you put it in a diesel because it will fire off when flipped.
Post  davehour Sat Oct 08, 2022 3:03 pm
Thank you.
Thanks for the tip!
I wasn’t getting the advanced search window when I pressed the search icon in the home screen. Now that you mentioned it, I worked out and did get it.
davehour
davehour
Bronze Member
Bronze Member
Post  Marleysky Mon Oct 10, 2022 11:06 am
This is the "view" from the Classic web page, you might not have that if on a phone or tablet.  But I'm glad you found it.
After Run Oil Scree209
