Cox PeeWee Micro Speeder - Page 3 Cox_ba12
Cox PeeWee Micro Speeder - Page 3 Pixel
by TD ABUSER Today at 12:38 am
Cox PeeWee Micro Speeder - Page 3 Empty
Page 3 of 4 Previous  1, 2, 3, 4  Next
Cox PeeWee Micro Speeder - Page 3 Empty Re: Cox PeeWee Micro Speeder
Post  rdw777 Fri Jun 24, 2022 7:11 am
Plus one more on helping the young man Very Happy …. Plus I like reading your stats and data…. Keep putting it up compadre ….
Post  Woody Fri Jun 24, 2022 4:13 pm
This is just great.
Helping each other!!!
You are doing a grand job Mr Speed!
If I may help as well?
I am a very light builder and purposely so the planes fly nicer.
If you don't mind me saying, your fuse bottom seems to be 3mm thick.
On a tiny plane like that, 1.5mm is plenty.
Only trying to help.
Don't despair...it will not take long to make a new one.
Keep it light.
Also when you make a fuse bottom and top, the wood grain should fall at 90% to the fuse length.
The opposite to how you have it.
This is to give more strength.
When you squeeze the fuse or hold it too hard ready to launch it, you cannot crush it because of the wood grain direction!
Keep at it mate.
Woody.
Woody
Woody
Post  1/2A Nut Fri Jun 24, 2022 4:43 pm
Thank you for the thumbs up Robert and Eric, happy to see Tobaiies .020 speed projects!  Very Happy
Small Cox Logo  RC Plane  Thumbs Up
Post  Tobaiies Sat Jun 25, 2022 11:41 am
Thanks for the kind words and the support!
There's always an error creeping in…But I think that's where you learn the most Smile
The fuselage sides are made of 1.5mm balsa, the top and bottom are 1mm.
Maybe I can finish it today in a night shift and test it tomorrow Very Happy
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  1/2A Nut Sat Jun 25, 2022 11:01 pm
Found out today the Kamtechnik prop plate adapter works with the carbon Cam 4.7x4 speed prop.
Has a snap fit for precision centering, note the stud bolt has a end point socket head uses a .050
allen wrench to lock it down and to avoid seized threads. The grade #8 black oxide bolt sits snug
in the threads with less slop than the stock bolt that came with the valentine .020 spinner nut.
The prop as is should work with the .020 engine with it's constant pitch blades, lower weight and
less bulky at the hub compared to the APC 4.1x4.1. Cam 4x3 does not work with the thrust plate adapter.
The Cam 4.7x4 certainly as a cut down speed prop will do 100+ Left alone will generate notable thrust.
Cox PeeWee Micro Speeder - Page 3 20220613
Cox PeeWee Micro Speeder - Page 3 20220612
Cox PeeWee Micro Speeder - Page 3 20220611
Cox PeeWee Micro Speeder - Page 3 20220614
Small Cox Logo Thumbs Up
Post  Tobaiies Mon Jul 11, 2022 3:10 pm
Had some time to build again. I still have to get the wing ready and hope for the first flight on wednesday. Nice to see the development of the models, seems a bit faster than at the beginning. WinkCox PeeWee Micro Speeder - Page 3 06963f10
Cox PeeWee Micro Speeder - Page 3 Cf160b10
Cox PeeWee Micro Speeder - Page 3 9e3b7910
Cox PeeWee Micro Speeder - Page 3 97b4df10
Cox PeeWee Micro Speeder - Page 3 477b6210
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  getback Tue Jul 12, 2022 7:06 am
Yes getting Better , nice sleek front end / less drag , Looking Good ! Look forward to the flight . RC Plane Very Happy
Post  1/2A Nut Tue Jul 12, 2022 12:43 pm
Thank you for posting the pics! Thumbs Up
Small Cox Logo Popcorn
Post  Tobaiies Tue Jul 12, 2022 2:12 pm
All right, I finished the model. Will test it tomorrow, I'm excited to test the model in combination with the new glow plug. I'm quite happy with the final result. Very Happy Cox PeeWee Micro Speeder - Page 3 25224610
Cox PeeWee Micro Speeder - Page 3 F7e10e10
Cox PeeWee Micro Speeder - Page 3 15a91510
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  1/2A Nut Tue Jul 12, 2022 3:27 pm
Very nice, good looking speeder, how is the weight with gps?
Each build / tested shows a path to the next honed down version to fly faster.
Cox PeeWee Micro Speeder - Page 3 F7e1d010
Post  Tobaiies Wed Jul 13, 2022 3:55 pm
Here the first flights.
I'm not that excited yet. The flight characteristics are ingenious and have improved.
But I will probably make the wing screwable again to reduce the air resistance of the rubber bands. I will also test the hotter glow plug, I'm not sure if it even had more power than with an original one.
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  balogh Wed Jul 13, 2022 4:13 pm
Nice flights especially the first one, but the 020 TeeDee is capable of much higher rpm-s with the stock COX head..
I am also having ambivalent experience with Kamtechnik head only on 020 size TeeDee-s ..while this head blows the door off the 049 and 09 size TeeDee-s, it brings my 020 with the stock 3-bladed COX prop to peaks only near 21...22k, while with the stock COX head my 020 TeeDee spins the stock 3-bladed near 25k on the bench and near 27k when unloading in the air.....I tried adding more gaskets under the Kamtechnik head but it did not improve the output..maybe Brad aka 1/2A Nut can chime in here with a to-do to let the Kamtechnik head do the wonders it does on larger COX engines..?
Post  1/2A Nut Wed Jul 13, 2022 5:21 pm
The plane flew great, the cooler glow plug tested made 4x3 / 28,670 rpm best noted peak.
CAM 4x3 best peak hit 29,063 rpm with the other plane and stock plug.
For the .020 I use hot plugs and 25% nitro.
What is the ready to fly weight of this version?
I oil the plug threads and adapter threads to help seal from leaks when assembling.
The stock APC 4.1x4.1 will need some backcut or can try extra head shims.
I like rubber bands to protect the wing in a crash or bad tumble.
3 bladed prop -  what turbo plug heat range tested best?
Post  balogh Wed Jul 13, 2022 5:46 pm
Brad I used medium hot turbo plug, 20% nitro and 2 then 3 shims, and was never able to approach the tpm-s with stock COX heads...strangely, the Kamtechnik heads are superb in all larger COX engines, better than Nelson..
Post  1/2A Nut Wed Jul 13, 2022 11:03 pm
How did 1 shim do?
Any tests with 2 blade props?
Post  balogh Thu Jul 14, 2022 8:52 am
Brad I have only the COX 2 bladed props for 020 size engines (my APC-s are larger)  that the TD spins way slower than the 3-bladed. So my benchmark is set by the 3-bladed and I compare the heads using that prop only.
Post  1/2A Nut Thu Jul 14, 2022 9:11 am
balogh wrote:Brad I have only the COX 2 bladed props for 020 size engines (my APC-s are larger)  that the TD spins way slower than the 3-bladed. So my benchmark is set by the 3-bladed and I compare the heads using that prop only.
Try 1 shim for more rpm Cool
The adapter was set up and tested for the more widely used Cox 4.5x2 prop.
The compression was adjusted to serve with one head shim as many folks
may not have spare shims to add.
Absolutely did not give up or settle with numerous prototypes tested until the adapter
was honed to make more rpm than stock. Same engine and prop saved for only testing.
Post  Tobaiies Thu Jul 14, 2022 4:02 pm
I have now made the wing screwable.
RTF weight is 90g.Cox PeeWee Micro Speeder - Page 3 5f45c010
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  balogh Thu Jul 14, 2022 4:47 pm
Tobaiies, is the wing made of hard balsa plank that you sanded to an airfoil? Did you use any template or just sanded it by instinct?
That 90 grams is impressive.. way below the 160 grams that our idiotic drone laws set as the max. weight of a plane without mandatory registration, insurance, airfield permit etc..all my planes are heavier than 160 grams so I fly as an outlaw..
Post  balogh Fri Jul 15, 2022 12:20 pm
1/2A Nut wrote:The plane flew great, the cooler glow plug tested made 4x3 / 28,670 rpm best noted peak.
Brad I suppose the 020 Kamtechnik head was designed with consideration of the larger volume of glow filament cavity of a turbo plug, than in a stock head? The cavity in a turbo plug seems to have much larger volume than the COX head..the dome in the Kamtechnik head is flatter though, so the combination of the two volumes i.e. cavity and dome may end up in identical combustion chamber volumes in the Kam and COX heads?
Post  1/2A Nut Fri Jul 15, 2022 10:24 pm
Yes the volume from the glow plug element hole makes an impact.
Some glow plug designs have larger holes than others, some are really bad.
I use OS Gold Plugs to insure good elements and conductivity for starting.
Key is to ensure you have a good seal and the seat for the glow plug
has conformed to the plug manufactures design. I double check after
the engine has been heated up from running.
Sometimes the element needs to be plucked up out of the hole some.
I use a needle to carefully raise it up.
Cox PeeWee Micro Speeder - Page 3 Imag9912
Cox PeeWee Micro Speeder - Page 3 20190929
Post  Tobaiies Sat Jul 16, 2022 5:22 pm
Exactly, the wing is made from one piece of balsa and simply sanded down by feel, but with a few auxiliary lines.
I edited the APC 4.1*4.1, you can clearly see the difference!
At the end I tested the Kamtechnik adapter with a hot glow plug. And this time the engine really has even more power than with the original head! Clapping
I think those are the fastest flights so far.
I tried to measure something with the GPS but the measurements seems wrong. (I think Huh... tongue )
Cox PeeWee Micro Speeder - Page 3 Img_3313
Cox PeeWee Micro Speeder - Page 3 Img_3410
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  1/2A Nut Sun Jul 17, 2022 12:59 am
Congratulations the plane has indeed made a faster pass!
Do you have a photo of the prop with back cut?
To reach 222kmh / 138 mph would need a prop pitch rpm of 35,560 rpm not counting prop slip or if down wind pass.
At 1:53 minutes the best pass hit 28,262 rpm making a prop pitch speed of 110 mph or 177 kmh
20% castor and 35% nitro should keep the rpms on point throughout the flight. Beats your old record
of 156 kmh / 97 mph pass + 21 kmh / 13 mph with the new design thus far.
Engine starts off strong but then something happens dropping rpm, some possible reasons:
Cooling down in flight creating a rich fuel state.
NV is moving (opening up a bit due to vibrations) can seal and hold with fuel line.
Setting NV quick to peak rpm with the plane level and launching before it heats to peak thermal state prompting
a richer NV setting to hold peak rpm in the hand. If launched before it peaks and sags will cool down in the air enough
to balance / set for best thermal state / rpm in flight.
Castor oil helps stabilize the peak thermal state on the ground so there is less flux between in flight additional air
cooling and thermal state on the ground. 1/2A fuel helps reduce hunting for the best NV setting for in flight rpm.
Post  Tobaiies Sun Jul 17, 2022 4:29 am
So thats just the prop pitch speed right?
Here the comparison to the original prop.Cox PeeWee Micro Speeder - Page 3 A369a210
Cox PeeWee Micro Speeder - Page 3 9b5ea810
Cox PeeWee Micro Speeder - Page 3 F3012410
Tobaiies
Tobaiies
Silver Member
Silver Member
Post  getback Sun Jul 17, 2022 6:24 am
Interesting facts Brad , if he follows your advice this thing will fly the wings off LOL I see you don't have a fuel line seal over the NVA for a better seal , that's were i would start and what ever our friend suggest Wink  Popcorn  I am just watching and learning some thing even the ones i don't all understand . What? Small Cox Logo What?
