» Free Flight Radio Assist by rdw777 Today at 9:24 am
by rdw777 Today at 9:17 am
by getback Today at 7:24 am
Adapting an Enya .049 or .06/.08 silencer to a Cox Tee Dee .09
Adapting an Enya .049 muffler to a Cox Tee Dee .09 engine
Items needed to adapt Enya 049 muffler to Cox Tee Dee .09:
Enya .049 muffler (part number M492) normal muffler
Dremel tool
Drill press with spindle stop and 1“ square steel block (length doesn’t matter)
Two Dremel “burr” bits (one square and one square with round end)
The square “burr” bit is 7mm (.25”) high and wide.
The other bit doesn’t mater on the length, the diameter is also 7mm (.25”)
From arts & craft store, a circle template.
Now I have done this on some Cox Tee Dee .049 and .050 engines, and it has worked out well.
The one thing that is critical is the hole on the underneath side of the muffler that will grip the outer diameter of the cylinder. If the hole is too larger then you’ll have a muffler that will leak and will rotate and that is not what “we” want. It is best to have the underneath side hole of the silencer a little undersize and carefully make it fit the cylinder to where it is a tight fit.
I’m getting ahead of myself. Just remember what was above when it come to the underneath hole on the silencer.
Now 1st thing.
Using the circle template use the 9/16” circle and draw the circle on the top side of the silencer. The top side of The Enya silencer will be the smaller of the two holes. The one side of the 9/16” circle should line up to the front side of the silencer. There is just enough clearance on the front of the hole to clear the Cox engines fins.
Make sure the circle is on the center line of the silencer where it comes apart! The circle template should have line on it on the circles for the correct locations to line it up.
Now carefully, using the Dremel tool with the rounded end bit, remove the aluminum to where you remove the black line. Removing to the black line should give us enough clearance to go around the cylinder head.
Next is to do the same on the larger hole on the silencer, the underneath side of the silencer.
Remember the paragraph before? We want to have this hole undersized!
So, using the ¾” hole on the circle template do the same as you did on the upper hole for marking the larger hole position.
Now carefully, using the Dremel tool with the rounded end bit, remove the aluminum to where you leave the black line and maybe a little more. We want to leave extra material on this hole to carefully make a good seal and a tight fit!
Bottom hole material removed ---- but the hole is undersized
Moving on,
The top surface of the silencer has to be thinned down so that it can slip between the fins for positioning.
The silencer top surface is currently thinned down to 1.4mm.
We need to get it down to 1.0mm to fit into the Cox cylinder head. This is where we use the square burring bit.
Setting up the drill press to where it is 1mm off the 1” square block I have, I removed the aluminum to a height of 1.0mm and I used the shaft of the bit as my gage for a depth stop and carefully moved the top muffler (both side – left and right) and removed the aluminum. You have to be really careful at the ends of the muffler.
I also had the drill press at the lowest speed (about 550RPM).
After that was completed was the trial fit of the silencer to the Cox Tee Dee .09 engine.
The silencer almost fit up perfectly but was not quite coming all the way together.
Now remember, I had the underneath hole on the silencer a little undersized so that I could get a nice seal on the Cox cylinder and where the silencer also will tighten down on the cylinder as well.
This is the critical part.
With the cylinder off the engine, carefully file the lower hole to where you get a good tight fit when the silencer is screwed together. Take your time getting this done.
If done correctly, the fit is perfect to the cylinder and when the silencer screw is tightened up, the silencer clamps down on the cylinder and doesn’t move.
Now you have a well fitted silencer to you Cox Tee Dee .09
Last edited by sosam117 on Sun May 01, 2022 7:47 am; edited 1 time in total (Reason for editing : spelling mistakes)
sosam117- Diamond Member
Re: Adapting an Enya .049 or .06/.08 silencer to a Cox Tee Dee .09
Cool that's a good idea simple modification and efective and if i was To use this trick I believe that I will open the two ends of the muffler to connect two pipes It would be a good setup in a cowls compartment.
davidll1984- Diamond Member
davidll1984 wrote:Cool that's a good idea simple modification and efective and if i was To use this trick I believe that I will open the two ends of the muffler to connect two pipes It would be a good setup in a cowls compartment.
One end is for the exhaust and the other end (with the screw in it) is used for pressure.
Yes I know but you know that I like to experiment with the different systems I believe that there are different possibilities To try with this piece Although I don't know if the system itself reduces or changes the performance very much. But I tink its a cool stuf To explorer
Fledgling
Wonderfull bit of work, an inspiration for people wishing to RC and silence td09's.
Don't have a milling machine but that jam jar is filling bit by bit. Maybe a proxon one is affordable, will check them out.
Coxfledgling- Gold Member
Coxfledgling wrote:Wonderfull bit of work, an inspiration for people wishing to RC and silence td09's.
I did not use a milling machine on this project.
Just used my trusty old drill press with a depth stop on the spindle and removed the aluminum from the inside face freehand.
» Translated Engine instructions for Enya .049-II / Enya .06-II / Enya .08 and Enya .10
» Adapting a Guillow's kit for RC
» Most expensive Enya in my collection -- Enya 60XLF -GM- SB ring Rear Exhaust
» Vintage Tiger muffler/silencer for the Enya .09 or Enya .09-II engine.
» *** UPDATE *** Received my Enya parts order --- NOT EXACTLY ENYA'S TOP QUALITY?
