» **VOTE-ON-THE-NEXT-COX-ENGINE-OF-THE-MONTH** (September 2024)by F4D Phantom II Today at 9:06 pm
» Thrust Washer
by roddie Today at 6:22 pm
by rsv1cox Today at 5:20 pm
» Jim Walker Bonanza etc.
by rsv1cox Today at 12:16 pm
» WILLY NILLY
by balogh Today at 2:05 am
» A Quick and Dirty CA Hinge Installation
by balogh Today at 12:29 am
» safety thongs
by TD ABUSER Mon Sep 09, 2024 8:55 am
by Mark Boesen Sun Sep 08, 2024 11:35 pm
» TD .049 Scratch Build
by GallopingGhostler Sun Sep 08, 2024 9:33 pm
by Admin Sun Sep 08, 2024 8:20 pm
» willies nillies
by MANDALAY Sun Sep 08, 2024 7:57 pm
» Betty Skelton
by GallopingGhostler Sun Sep 08, 2024 3:27 pm
August-2024
.15 tee dee tap and die dimensions difrent size info
What would be the right dimension of die or tap to make the right threads? On the base of the cylinder or the crankcase I know it's possible to use one or the other Alternatively also with a cutting tool for the correct thread pitch on a lathe I would like to do it as simply as possible If I manage to make this part it would be great because it could solve the difficulty of obtaining new cylinders for the .15. The cylinder prototype that I want to manufacture could be sold as an upgrade to modify this engine. I would like to know what you think of my idea also know yours if you have any suggestions
![Babe Bee .049](/users/3015/29/34/60/smiles/976416.png)
![RC Plane](/users/3015/29/34/60/smiles/1702820958.gif)
![Small Cox Logo](/users/3015/29/34/60/smiles/7356.png)
davidll1984- Diamond Member
Fledgling
Hi David, I have seen on here screw thread info, will browse the tech info section ...
Coxfledgling- Gold Member
Fledgling
Well I am convinced I saw thread info for Cox engines on here but do you think I can find it now ???
Re: .15 tee dee tap and die dimensions difrent size info
I searched a bit but I found only for .049
Coxfledgling wrote:Well I am convinced I saw thread info for Cox engines on here but do you think I can find it now ???
At the very bottom of the page of instruction sheets, other sites :
![.15 tee dee tap and die dimensions difrent size info Scree111](https://i.servimg.com/u/f89/19/10/39/29/scree111.png)
go to Martins "Homepage" from the link at the very bottom of first page, then to "techinial info" on left hand side of page:
![.15 tee dee tap and die dimensions difrent size info Scree112](https://i.servimg.com/u/f89/19/10/39/29/scree112.png)
TA-DAA ! 3/4-32
Thank you very much I'm sure I'll be still looking you saved me precious time As I said this cylinder is different from other normal ones It is thicker and wider Here I take another cylinder that I screw it on the different one the older medallion fit on the glow head Not the crankcase is To large ![.15 tee dee tap and die dimensions difrent size info 16423910](https://i.servimg.com/u/f58/20/16/70/92/16423910.jpg)
It's a little normal that I wonder with the other model tee dee or medallion we can screw the heads on the crankcase Not this one only its cap fit and is also bigger wil Not fit on a difrent engine than the mk|| .15 i tink take a look à this I don't understand why Cox did that?![.15 tee dee tap and die dimensions difrent size info 16423911](https://i.servimg.com/u/f58/20/16/70/92/16423911.jpg)
Its Not 3\4_32 That's what I meant it's not the same only this cylinder made on this crankcase Not the glow head or the normal cylinder Which usually is the same size as the threads of the rest of the engine parts wit normale engine the head use To fit crankcase Not this one is larger
Ok now Does anyone have a .15 crankcase that you can screw a glow head onto the cylinder part? Or the rear cap this model engine fit m'y spare .15 engine parts I would like to find a crankcase maybe with another crankcase it would solve my problème help .15 older medallion crankcase wit rear cap ?? I just found that the sportsman Intake valve is the same size ![.15 tee dee tap and die dimensions difrent size info 16423912](https://i.servimg.com/u/f58/20/16/70/92/16423912.jpg)
![Doh!](/users/3015/29/34/60/smiles/874384962.gif)
![Shocked](https://2img.net/i/fa/i/smiles/icon_eek.gif)
![confused](https://2img.net/i/fa/i/smiles/confused.png)
To avoid this problem for others, this information should be added clearly for others who, like me, could be asking why it doesn't fit. As its Not clear This information cannot be found anywhere.
on the spécial mk|| and tee dee spécial mk| The dimension is not shown here are the dimensions are the same as that of a sportsman rear valve or olimpic drum valve its should be 13/16_32 .Here someone could fill in the blanks for me plz
lets help other Share the info to prevent others from looking for nothing
![.15 tee dee tap and die dimensions difrent size info Scree134](https://i.servimg.com/u/f58/20/16/70/92/scree134.png)
![Computer Issues](/users/3015/29/34/60/smiles/1363920492.gif)
![Hand Shake](/users/3015/29/34/60/smiles/2887095414.gif)
crankbndr- Top Poster
The early TD .15 crank case has the same external dimensions for the cylinder as the Olympic and Sportsman. There was a problem with the cylinder cracking, so Cox redesigned everything to accommodate a stronger cylinder with thicker walls and a larger diameter mounting thread. They also got rid of the ball and socket piston/rod. If you have an early TD .15, I think it's a little rare as it was quickly taken off the market.
coxaddict- Gold Member
I'm working on several things at the same time, it's possible that I get mixed up A little like some of my engines As always, I'm looking for a different way to get to a radio controlled engine. To Have precise and effective control I like to modify thing This cylinder project made of aluminum is a bit crazy but I want to do it it would be a unique engine The possibility of using the best possible combination so that it is not only efficient but also very strong and durable I know that the model tee dee mk|| is a little different but with a single gas exhaust outlet I would be curious to take some measurements on one of this engine The trickiest is To set the correct Height but I wonder if I would be better off modifying the stroke of the piston to accommodate the air intake and exaust opening Earlier Barely a degree I fully intend to complete this project no matter how long it takes me no matter how complex it is.
You have great ideas and would love to see success in your projects as I have similar goals. I do have blank .049 cylinders that I want to cut my own ports. I have practiced milling ports on single port no. 2 cylinders with promising results. I wanted to make my own cylinders and pistons out of aluminum but would need aluminum with a high silicone content. Keep up the good work.
A.M.
A.M.
The trickiest thing is to immobilize it well, the cylinder must be immobilized and fixed very securely But I have already done freehand with a dremel tool Take the time, holding very firmly, my hands hurt after I noticed a difference in performance I had made it thinner less wide like a smal boost port
![Snowman](/users/3015/29/34/60/smiles/2872799019.gif)
I revisit this publication and realize that I did not publish the result I think I forgot The result is encouraging I believe that soon I will have another prototype to show you ![.15 tee dee tap and die dimensions difrent size info Img_2369](https://i.servimg.com/u/f58/20/16/70/92/img_2369.jpg)
![.15 tee dee tap and die dimensions difrent size info Img_2370](https://i.servimg.com/u/f58/20/16/70/92/img_2370.jpg)
I was very busy I was working on another project but I'm going to receive a tool that I had to have made and took a very long time I don't want to say too much but soon a new .049 will soon be born, made with my own hands, it will be a real little mechanical monster, a little different from what already exists.
» Tuned pipe experiment and difrent custom parts
» can anyone tell me the dimensions of the cox .020 engine
» Hi, please need helpto identify a "big" Cox engine
» Dimensions for a Cox PT-19?
» Confusion! (not ELO related)
