Building an Ohlsson & Rice test mount Cox_ba12
Building an Ohlsson & Rice test mount Pixel
by roddie Today at 1:34 pm
Building an Ohlsson & Rice test mount Empty
Building an Ohlsson & Rice test mount Empty Building an Ohlsson & Rice test mount
Post  rsv1cox Thu Jul 22, 2021 10:43 am
Couldn't get my commercial mounts to fit, so I built my own.
I seldom throw any board cut-off away, and found a nice castor oil soaked fuel tank mount from an old project among the left-overs.
Building an Ohlsson & Rice test mount P1011252
Not a perfect fit so it required a little modification.
Building an Ohlsson & Rice test mount P1011251
Building an Ohlsson & Rice test mount P1011253
Found a perfect shim in the cut-off box.
Building an Ohlsson & Rice test mount P1011254
Building an Ohlsson & Rice test mount P1011255
Paper clip works to position the needle, rinky dink but functional.
Building an Ohlsson & Rice test mount P1011256
Building an Ohlsson & Rice test mount P1011257
Still needs a fuel tank and massaging.  It's going to wind up as a display mount.
Building an Ohlsson & Rice test mount P1011259
Building an Ohlsson & Rice test mount Empty Re: Building an Ohlsson & Rice test mount
Post  Kim Thu Jul 22, 2021 11:06 am
"Let the Good Times Roll"!!!
Great re-purposing Bob!
Post  NEW222 Thu Jul 22, 2021 6:33 pm
Seeing that makes one wonder. If it does not fit a commercial test mount, how does one mount it to a plane????
Post  Ken Cook Thu Jul 22, 2021 6:52 pm
I have two test stands, one being a Tatone and the other a EZ-Just. The O&R's fit both. Neither of these stands were offered until 20 years later. The O&R protrudes a fair amount from the bottom of it's lugs. K&B essentially did the same with their early Torpedo's. In 1948 Duke Fox offered the sand cast Fox .35. The same year the glow plug was offered. He made the lug spacing, length and width the same as the O&R. He did this for a specific reason and it pretty much worked. You now have a engine with twice the power, no batteries, coils, condenser to haul around. This was reason enough not to buy the O&R engines and directly swap his units into.
Most planes that utilized O&R's used full bodies to facilitate the electronics and battery case. The front was generally wide allowing the case to hang down unseen with the cylinder sticking up. These are well before my time but they don't offer much power. Whenever I've seen them in use, it's always been a timid flyer such as a freeflight. model.
Post  rsv1cox Fri Jul 23, 2021 10:31 am
I couldn't get my .29 to fit on either Ken, but I have the small Tatone.
About ready to fuel this thing up.  Hooked up a temporary bracket and hot melted it on to the mount and the tank too hoping to reduce vibrations should this thing actually run.
Building an Ohlsson & Rice test mount P1011260
Glow plug is bad so I replaced it.  I have no idea as to the heat range or which one the O&R would require.  Cut and try.
Building an Ohlsson & Rice test mount P1011261
Building an Ohlsson & Rice test mount P1011262
Anyone ever think about making a display of vintage glow plugs?  I have been mulling it over.  Vertical with a mirror behind a drilled piece of Mahogany, or milled out horizontal at a slight up angle.
Building an Ohlsson & Rice test mount P1011263
Note to self - Next time do not put thumb in hot melt glue.......
Post  Ken Cook Fri Jul 23, 2021 4:14 pm
Use the hottest plug you have. These engines need lots of oil, oil = HOT. If you have a 6 pitch prop similar to what you have it will keep a better load on the engine. These don't generally like high rpm's.
The Arden plug you show in the pic ( Big ball top) is the period correct plug and is a good choice if it lights.
Post  rsv1cox Fri Jul 23, 2021 5:17 pm
I'm not familiar with these O&R engines, so I did a little research. Found an old thread (2012) right here on the forum. One contributor mentioned that the glow versions (remove the sparker mech and the plug) like 0% nitro and that they might have used Veco needle assemblies. So, I did wrong.
Secured the tank and using the filler blub from yesterdays excursion with the K&B filled it with Cox 25% before I noticed. Sucked some of it out and replaced with Traxx 10%. Primed it and first flip got a weak flutter of about four revolutions before it quit at about four turns out. Fooled around that setting getting strong runs of five or six revs and that's it, plenty of fire and strong fuel draw. Quit after last flip caught the back of my finger. Ouch.
I'm sure it will run, but what's the sense. Hate to give up, but it's not one of my two or three flip Enya's.
Building an Ohlsson & Rice test mount P1011264
Post  Ken Cook Fri Jul 23, 2021 5:39 pm
Running a O&R on 5-10% nitro is highly recommended. I don't putz with FAI  no nitro fuel, my engines have too low of compression to make that fuel work. Unless your Traxxas fuel has oil added to it, I wouldn't recommend running the O&R on it. The O&R needs 25-29% all castor fuel. The O&R has a needle bearing thrust washer in  it's bottom end that will probably not tolerate low oil content fuels.
           The only O&R's that I've ever witnessed blow their tops was the .60. The cylinders are spot welded on and when they let go, the just blows off of the top.
If you back flip the prop, you absolutely can't get hit in the finger. Most engines start easier this way and it's the only way to start a flooded engine.
Post  rsv1cox Fri Jul 23, 2021 6:29 pm
It will start Ken, just will not keep running.  Act's lean, but a a turn or two rich doesn't make much difference.  In defense of it, I haven't even removed the needle to wipe it off or clean the spray bar.  Guess I will do that, then try some back flips and maybe try one of those old plugs.
Hot melt glue gave up on the bracket, didn't separate completely, but I still had to mechanically attach it with a screw.  Tank is holding well.
Poor hunk of 2X4 has seen at least two gun racks in addition to that fuel tank mount.  Before that I don't know.  Has more holes in it than swiss cheese.  Eager to trim it up some into a display mount for that O&R.
Building an Ohlsson & Rice test mount P1011265
Looking for my .23 I found this little devil. Rear induction, weird plug, but I have two new cards of them. No NV when I got it, replaced with an Enya.
Building an Ohlsson & Rice test mount P1011266
Building an Ohlsson & Rice test mount P1011268
Building an Ohlsson & Rice test mount P1011267
Post  getback Sat Jul 24, 2021 7:14 am
Hello Bob , see your having some O&R Fun , after all the trouble to get it turning over and the cleaning involved I can't believe you didn't do this >> (In defense of it, I haven't even removed the needle to wipe it off or clean the spray bar. Guess I will do that,)) I think it will run after a good cleaning of the holes ... Good luck and bee careful with that noise maker Wink
