Diy   Anodizing  - Page 3 Cox_ba12
Diy   Anodizing  - Page 3 Pixel
by getback Today at 7:14 am
by getback Today at 7:02 am
Diy   Anodizing  - Page 3 Empty
Diy Anodizing
Page 3 of 3 Previous  1, 2, 3
SOLD! Re: Diy Anodizing
Post  MauricioB Wed Mar 17, 2021 9:49 pm
David, thanks for showing and sharing information.
I will be taking all this data and doing a trial as soon as I finish with other projects.
I will be consulting you to have precise data on some point. Surely then I will make a video and logically you will be the teacher!
Thank you, I am still attentive to any information you can provide us.
Post  davidll1984 Thu Mar 18, 2021 10:39 am
Sorry I must specify these 4 acid parts for very little water as the cars batry acid is Not pure acid wit pure acid Never add water directly to the acid and mix is 1 parts acid for 3 parts water slowly ad acid To water carful wit that pure acid is Not like cars batry is Dilute already Be very careful with these chemicals Never do this indoors in a well ventilated area once the parts fuly Clean of any contaminated stuf Never use metal just aluminum To hang the piece in the center of the container The part must be fixed on the positive side a large aluminum plate on the negative side start wit lower power like 9 v wit size of crankcase in one cup During the anodization the part becomes isolated from the current we must increase the voltage up to 12v 3 amps max
Post  davidll1984 Thu Mar 18, 2021 10:48 am
Diy   Anodizing  - Page 3 16160810
For coloring use pure dye or dilute very slightly It is possible to apply it in different ways I leave the choice to you y like To dab dip the parts in pure dye Then with a piece of cotton dip in the dye I rub the piece lightly for dark color
Post  NEW222 Thu Mar 18, 2021 9:21 pm
Thank you David.
Post  davidll1984 Fri Mar 19, 2021 3:12 am
Sometimes it is impossible to soak the too large part To color just Tap with the applicator pad direct on the part Diy   Anodizing  - Page 3 Img_2099
Leave excess drip in container Rub gently with a cloth Soak in the dye To get dye out the Bottle pierce the pad wit Somting just push Drill a hole on pad
Post  getback Fri Mar 19, 2021 7:46 am
Popcorn Your really getting into it and looking Good !! bounce
Post  davidll1984 Fri Mar 19, 2021 9:30 am
Here is a . 049 who would like to be a venom hd crank now 0 lose no play at al just Perfect fit after lots of modification inside crankcase y use som sort of Pipe cutter of som sort With this tool I was able to crush the front part Evenly over the entire circumference Then after adjusting the parts I anodize Now the crankshaft is very strong inside more loose Diy   Anodizing  - Page 3 Img_2100
Post  davidll1984 Thu Mar 25, 2021 5:58 pm
This is the jerobee engines from eBay Diy   Anodizing  - Page 3 Img_2120
Started wit this one the result Diy   Anodizing  - Page 3 Img_2121 Diy   Anodizing  - Page 3 Img_2122
Post  bakergw Fri Mar 26, 2021 3:50 pm
Great thread David! Thumbs Up Thanks for sharing all of this. I have learnt a lot from this thread, not just anodizing either, all kinds of little bits and pieces and tips and ideas. great posts by David and all contributors. This Site Rocks!
Cheers,
Gary
bakergw
Account Deactivated by Owner
Post  dckrsn Fri Mar 26, 2021 8:31 pm
David, merci pour ce sujet du forum. Très instructif.
Je l'ai téléchargé et imprimé.
David, thanks for this forum topic. Very infomative.
I have downloaded and printed it.
Post  davidll1984 Fri Mar 26, 2021 8:57 pm
Small reminder always protect your hands well wear clothes for this aifect a good mask with covid 19 easy to find lol! If you want to try the experiment yourself, try it with aluminum leftovers or other unimportant parts. It's harder than it seems It takes a few tries to master the technique. Do this out side important Not in direct sun light heat color litle help wit som color like red not wit blue best its cold
if its made correct color fix To the parts almost instantly It is a very satisfying work which improves the pieces at the same time
